Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Redcat RS10
Thread: ive read somewhere...
Old 04-25-2013, 08:13 PM   #1
Default ive read somewhere...
Ive read somewhere to put the motor pinion smaller or bigger at the rear....wich one is it please and please explainthe reason to do so...
cheers ;)
virusdunil is offline   Reply With Quote
Old 04-25-2013, 08:31 PM   #2
Default Re: ive read somewhere...
either you decide will work. larger in the front or smaller in the rear. the object is to speed the front axle up.
FATBOYrs10 is offline   Reply With Quote
Old 04-26-2013, 08:18 AM   #3
^^^ Exactly. I run 8T pinion in the rear and 10T pinion in the front. Faster speed up front helps suck the truck to the ground while the rear has more torq.
LostFedExMan is offline   Reply With Quote
Old 04-26-2013, 08:25 AM   #4
Never did that cross my mind. I still run stock electronics and get clod stall I would have thought about making the rear go faster. But you guys make sense. That's why I love this forum I learn new things all the time.
riskyjedi is offline   Reply With Quote
Old 04-26-2013, 08:56 AM   #5
It also helps in turning radius when you lock out the rear steer. The faster front end will tend to help pull the front around.
Old 04-30-2013, 02:41 PM   #6
I did not know that! cheers!
The Jackalope is offline   Reply With Quote
Old 04-30-2013, 03:07 PM   #7
Putting an 8t in the rear will also help will climbing obstacles. As the slower rear will have less push and therefore have less tendency to want to drive under and back flip you. Over/under driveing the axles is what almost all the scale and sportsman drivers do, it is a quick way to simulate proportional mixing that is achieved buy useing two esc's on a twin moa truck. I personally run dual esc with proportional mixing and dual dig and it is awesome, some of the things I can climb now...
d_j_stockton is online now   Reply With Quote
Old 04-30-2013, 05:55 PM   #8
As D_J_ tell you the best way to go is upgrade to dual esc wtih proportional mixing if you 'r realy want to crawle
I'm runing a M2 novak who give you proportional and dual dig
OLI972 is offline   Reply With Quote
ive read somewhere... - Similar Threads
need help guys ive ive chopped everything up blade smc 5.5 build tpurdin Micro Scale Rigs 12 11-09-2012 12:32 PM
ive searched and searched and read now the question what grease to use in a ax10 tran 89lxmorepower Axial AX-10 Scorpion 23 09-16-2012 10:09 AM
so this is what ive gotten so far cartronicshn Tamiya Clod Buster 74 07-22-2006 10:34 AM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
