Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: RS10XT has programmable ESC
Old 04-09-2015, 08:45 AM   #1
Default RS10XT has programmable ESC
After having my RS10 for a bit it bothered me that I had to keep my throttle trim 13% to the rear so the truck wouldn't want to move forward. I was looking on redcats site today and found this: http://www.redcatracing.com/manuals/E401.pdf
Turns out you can set the throttle zero/ max points, voltage cutoff and heat cut offs through the ESC.
Everything else I've read about the little white button was just about the reverse brake. Turns out it's a program button.
I've since reprogrammed my throttle points ( which now have my trims at 0 ) and low voltage cutoff.
Hope this helps someone
Damion10 is offline   Reply With Quote
Old 04-09-2015, 06:15 PM   #2
Default Re: RS10XT has programmable ESC
so you finally read the instructions?
every thing needs to be calibrated, nothing comes fully ready from the factory
specially at the prices we are paying or these redcats
cabron is offline   Reply With Quote
Old 04-09-2015, 08:59 PM   #3
There was nothing in the instruction booklet that came with the truck about this. I was looking at the ESC in redcats parts and saw there was a pdf link. Clicked on it and found the ESC program info
Old 04-26-2015, 05:51 PM   #4
So all these years I could have had lips low voltage cutoff on my esc and didn't even realize it?!?!?! #%^*
The Jackalope is offline   Reply With Quote
Old 07-13-2015, 12:20 AM   #5
Has anyone tried this ESC running off a single motor? Because the same ESC appears to be used by HaiBoxing and I can pick one up locally for $AUD25.00. That's not bad for a programmable ESC with lipo cutoff etc.
honchojoe is offline   Reply With Quote
Old 07-13-2015, 07:18 PM   #6
The motor wires are wired parallel, so I would assume just using one set of wires wouldn't harm anything.
RS10XT has programmable ESC - Similar Threads
RS10xt ESC calibration question jim_w Redcat Crawlers 21 03-01-2015 10:52 AM
programmable ESC's romac Electronics 8 11-13-2012 10:31 AM
Is the esc programmable SpeedFreak675 Losi Micro-Rock Crawler 9 01-04-2010 02:20 AM
Mamba Max programmable at brushed Motor? Bruno Benzini Electronics 3 07-09-2009 09:57 AM
