04-25-2016, 12:57 PM | #1 |
Newbie Join Date: Apr 2016 Location: nh
| rs10 vs everest 10
Looking to pick up my first "real" crawler, im torn between the rs10 or the everest. What are yall's opinions? or any comparable vehicles in the same price area? <300$ Thanks For the help guys/gals |
04-25-2016, 05:48 PM | #2 |
RCC Addict Join Date: May 2011 Location: at home
| Re: rs10 vs everest 10
apples and oranges one main thing in common is they both allow for a lot of tuning and tweaking. both give you your money's worth and both do well on the trail. for just crawling I would say get the rs10, with a better radio and using two escs along with the 4ws you can have a lot of control. if you like the scale realistic look then the Everest seems to be an economical start for your build. you could get one of each and then let us know |
04-27-2016, 07:18 AM | #3 |
Thanks for the reply Cabron, ended up pulling the "trigger" so to speak for the rs10, should be here within the week. prepare to be bombarded with photos. I am currently driving a cheap maisto crawler from walmart with a 9.6v mod, cannot wait to see how this performs over that. though when i pass it on tp the 2 year old she sould be excited |
04-27-2016, 09:56 AM | #4 |
welcome a fun crawler that is easy to improve haha many build threads and lots of advice available. photos are always welcome |
04-29-2016, 04:11 PM | #5 |
Rock Stacker Join Date: Mar 2016 Location: US
I was really impressed by the rs10. To have so much you can do to it for so little to start was awesome. It was my first crawler as well. You shouldn't be disappointed Sent from my SAMSUNG-SM-G890A using Tapatalk |
05-03-2016, 09:20 AM | #6 |
Mine should be here by friday, im getting antsy just waiting, been beating the snot out of my maisto in the mean time.
05-04-2016, 07:50 PM | #7 |
Rock Stacker Join Date: May 2016 Location: seward
| Re: rs10 vs everest 10 They really are great! Mine keeps up with my friends Axial AX10 in perfect rhythm. It will even beat it in some crawling spaces. Make sure you order new steering servos because the stock ones break super easily. I ordered a kyosho inferno and it works great! http://www.amazon.com/Kyosho-Inferno...=AZC10Z4SLMKX9 It will be a huge upgrade from your maisto and you wont regret buying it. If you have any problems contact me as i will probably have had them to. Also if you decide to make any upgrades tell me how they work and i might try them myself.
05-05-2016, 02:00 PM | #8 |
so i got my truck last night (2 days early!!) first impressions are it is fairly well built for a "off brand" hobby grade rc. I charged the battery and went to take it for a rip, that was a fail. I have forwards and backwards, but no steering input from the tx. the servos are working, if i swap the servo with the esc it turns with the throttle, but it wont move with the "steering wheel". So i opened up the tx ( i know i know warranty" and noticed there doesnt appear to be an antenna wire coming from the circuit board. anyone else experiance this issue? know where i am supposed to solder the antenna lead? worst case; whats a "decent" stick tx that will allow me to keep my rear steer, a "plug and play" if you will. |
05-05-2016, 03:20 PM | #9 |
by any chance did you read the instructions? specially on selecting steering modes? might need to calibrate the transmitter, check the settings, endpoints, etc this being a 2.4 ghz there might not much of an antenna. I use a spectrum dx7 and the orangerx receivers from hobbyking, very happy with this combination. I have 5 crawlers with 4ws and 2 escs each. |
05-05-2016, 03:27 PM | #10 |
Newbie Join Date: May 2016 Location: STL
I love my rs10. I haven't done much intense crawling with it yet, just small rocks and trails but I like it so far. I'm pretty sure the everest. I got the rs10 mainly because it has two motors and four wheel steering.
05-05-2016, 07:26 PM | #11 |
It's alive!!!! I got frustrated and took it apart, put it back together and voila! Houston we have liftoff, the reciever wires must have been loose or something, took it out for a few minutes this evening, far more impressed with this rig tonight than I was last, now to not empty my wallet upgrading this thing
06-30-2016, 11:47 PM | #12 |
where'd you get that body?
07-01-2016, 01:38 AM | #13 |
busted good you got it going again. once you get more familiar with your rc it gets easier to troubleshoot and fix problems. it will not hurt to check as many of the screws to make sure they are tight. good tools will make life easier specially the allen wrenches. getting the 3 good allens that are used most is better than buying a big set of cheaper quality ones. for sure get ready to replace servos. get two at least, if you have a spare the others will not break. haha metal gears for sure, the higher torque the better. there are many servos out there that are capable but they come in many prices from 10.00ish to way over 100.00. shop around get at least 12kg, 20kg is better. (170oz/in and 249oz/in) found this servo comparison site Advanced Servo Search Results to help see what is available I am cheap, I use tower pro mg946 from hobbyking. out of 15, 3 became unusable. in 8 years there are better ones out there haha look at pro modelers they look quite tuff, this is the one I want though I have to buy in pairs haha 420oz-in v3 pictures to keep us amused there are many threads in here showing what people have done to their rs10s enjoy Last edited by cabron; 07-01-2016 at 01:48 AM. |
07-02-2016, 08:47 AM | #14 |
| Re: rs10 vs everest 10 |
07-02-2016, 08:55 AM | #15 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
the modeler servos are awsome i have had one on several of my rigs no regrets other than pricey but u can move em up with you as you upgrade |
07-02-2016, 06:35 PM | #16 |
I've had pretty good luck with the power HD servos. They're 25kg and pretty cheap but sturdy. I found it on eBay for around $25 Sent from my SAMSUNG-SM-G890A using Tapatalk |
07-06-2016, 03:09 PM | #17 |
Rock Crawler Join Date: May 2016 Location: SoWIs
For future viewers, I'd recommend the E10 if you're cheap or have a tendency to upgrade like mad. It can use a lot of Axial parts. The RS10 is great if you want a great crawler but don't feel like any modding. I highly recommend 3S & a uBEC for both models.
09-02-2016, 02:53 PM | #18 |
Newbie Join Date: Jan 2011 Location: San Jose
Why the Ubec? I have a Everest 10 (not 4WS... yet, still not understanding why I was told not to use a y harness on stock receiver)
09-02-2016, 04:47 PM | #19 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
I didn't make the post, but I assume he's recommending a ubec because you can give your servo 6 volts instead of 5 and get a little more torque and servo speed that way. Also, although the stock ESC is rated for 3S, it's more extra voltage that the linear BEC it includes has to turn into heat which is theoretically harder on it.
09-03-2016, 06:32 PM | #20 |
Newbie Join Date: Sep 2015 Location: west boylston
I wired my two servos together on my everest 10 and because they face different directions the rear steer works perfect. Stock everything I only bought a few links and the servo plate and a servo I took off my twin hammers Sent from my SM-G920V using Tapatalk |
rs10 vs everest 10 - Similar Threads | ||||
Everest-10 | rodney m | Redcat Crawlers | 1 | 08-13-2015 07:17 AM |
how to make strong RS10 axles? or everest 10? | dirtman71 | Redcat Crawlers | 12 | 07-22-2015 09:01 PM |
Project: Smooth Operator (RS10 EVEREST) | tony91723 | Redcat Crawlers | 25 | 06-24-2015 12:00 AM |
