01-09-2017, 05:36 PM | #1 |
Newbie Join Date: Jan 2017 Location: North Alabama
| Parts for E10
I just ordered two Everest 10's for me and my son. Have read that I'll probably need to replace the diff's. Looked at the "Iron Cross" parts and the HSP replacement diff. Is there any major reason to use one over the other? It would be cheaper to use the Cross since two come in a pack and I need four of them. Thanks, JC |
01-09-2017, 07:04 PM | #2 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Parts for E10
With the axial iron crosses the axle end need to be filed down to fit the the axial locker vs the hsp replacement is just that an metal replacement no filing needed. The axial locker also needs to plastic stock locker modified or a differential case for a axial Case part# Axial AX80002 SCX10 AX10 EXO Wraith Differential Case - Small: AX10 Scorpion Last edited by hillbillyrc; 01-09-2017 at 07:13 PM. |
01-10-2017, 06:47 AM | #3 |
Rock Stacker Join Date: Jan 2016 Location: farmington
| Re: Parts for E10
HSP is a better hop up for pretty much everything on this rig, axial stuff needs mods and not worth it
01-10-2017, 09:55 AM | #4 |
| Re: Parts for E10
I will order the hsp lockers. Thanks for the advise
01-10-2017, 01:44 PM | #5 | |
| Re: Parts for E10 Quote:
I'm building a rear everest axle with ud gears and hot racing spool because I'm putting in axial lockouts and one piece rear axle shafts. Which all work together and no worries about breaking filed down red cat axle shafts. Only modifying that needs done is to file down the nubs to fit the lockouts. | |
01-10-2017, 06:37 PM | #6 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
| Re: Parts for E10
HSP lockers are best if you don't want to modify anything else. You can get them pretty cheap from overseas if you don't mind waiting. My stock lockers held up ok while I was waiting for mine, but it would be pretty annoying if they broke and you still had a long wait. The axial lockers are cheaper and are available stateside, but they do require that you modify things for proper fitment. |
01-10-2017, 10:44 PM | #7 |
| Re: Parts for E10
I ordered 4 lockers and steel gears for the motors from China. About half price, but who knows how long the shipping will be. Hopefully the two E10's will be here Friday so we can try them out. Got my fingers crossed that we will not have any problems out of the box. Went ahead and ordered some wheel spacers and some hex wrenches from Amazon. That should have us some stuff to work on the steering with. My son is already trying to get me to order tires. They will have to wait. |
01-11-2017, 08:03 AM | #8 | |
its really such a great rig really... i had no probs out of the box, where as my rs10 was a nightmare out of the box, also the everest tires arent that bad , im giving my son my rs10 now that i got the everest where i wanted to | |
01-11-2017, 02:22 PM | #9 | |
Rock Stacker Join Date: Nov 2016 Location: North Jersey
01-13-2017, 01:56 AM | #10 |
| Re: Parts for E10
My trucks arrived a day early, but I didn't know it until I was leaving for work (night shift). At least my son got to do some crawling in the living room before he went to bed. I know there will be a fight to get him to get ready for school when I get home. Is it worth it to swap battery ends and move up to a better charger? I'm not even sure what ends the batteries have stock. I got a better charger for his Traxxas batteries already. Not sure if this is a cheaper hobby than shooting. |
01-13-2017, 06:14 AM | #11 |
| Re: Parts for E10
The truck comes with banana plugs. I know some people switch them out, but i dont see the need. I would say i have about 10 full charges and discharges on my stock battery and charger with zero issues. I have found that it takes about an hour to an hour and a half to charge them up. Then i get about 30-45 min of crawling time. The truck is pretty solid out of the box. My only recommendations would be trimming the tires and foams, and maybe add 4 wheel steering which is super easy on this truck.
01-13-2017, 10:00 AM | #12 |
| Re: Parts for E10
The stock battery connectors are fine if you plan to stick with the stock battery. I wouldn't bother with a new charger just to charge the stock batteries unless it was also capable of charging other battery technologies (lipo). That way you will be part way there if/when you decide to upgrade to a better battery technology.
01-13-2017, 01:13 PM | #13 |
| Re: Parts for E10
These trucks are fun. Driveshaft was loose on tranny end on one truck. Hard area to get to. I may just get a couple extra batteries and see how it goes from there. Thanks for all advice and I'm sure I'll be back with more questions soon
01-16-2017, 12:36 PM | #14 |
| Re: Parts for E10
Well my truck has been 3 wheel drive since the first afternoon but we have still been having fun. I set up a short course with some rocks and firewood logs and it is a challenge to stay on it for us. While waiting on parts, got some more questions. Is the consensus to outboard shocks on front and back? What size are the small hex nuts and the hex nuts on the wheel? I ended up getting some blue locktite for the set screw on my sons rear driveshaft. It fell out in the leaves and was hard to find. Also had to get more body clips, lost a few of those too. |
01-17-2017, 07:35 PM | #15 |
| Re: Parts for E10
I'd outboard the shocks as long as it doesn't cause them to rub at full steering lock.
Parts for E10 - Similar Threads | ||||
Free e10 | avanord | Redcat Crawlers | 18 | 12-13-2016 09:59 AM |
Basher E10 | hillbillyrc | Redcat Crawlers | 17 | 12-06-2016 06:56 AM |
e10 | Greger | Non Crawler RC's | 3 | 04-14-2013 03:20 PM |
e10 question | cameraman | Non Crawler RC's | 9 | 01-31-2012 05:09 AM |
