03-22-2017, 10:09 PM | #1 |
Newbie Join Date: Oct 2016 Location: Salina
| E10 Shock upgrade
Hey fellow crawlers I have a question about shocks and length I would like to keep the same length if possible not sure how to figure out what wouldn't kill my ground clearance looked at several shocks and not sure what would work length wise I don't comp crawl with it just something to run around with.
03-23-2017, 10:42 PM | #2 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: E10 Shock upgrade
You might not comp with it, but looking at some ax10 builds might give you an idea of what you can run. Since the e10 is a clone of the ax10 and depending on the performance your looking should help.
03-24-2017, 09:21 AM | #3 |
Pebble Pounder Join Date: Feb 2017 Location: Canada
I got some kings shocks that are very close in length but I was never able to find anything as long. After some research I learned the stock height is probably a little too high and the shock travel too long. So by getting shorter shocks you should only improve your crawling. I use shock spacers to further limit travel as well.
04-16-2017, 01:45 AM | #4 |
Newbie Join Date: Apr 2017 Location: Appleton
Just purchased some desert lizard internal spring shocks for my e10.went with a 110mm to lower my cg.have the shocks set up on droop so it sits much lower than stock.still has almost all of the stock articulation but with wheel weights and these shocks it is much harder to roll.
E10 Shock upgrade - Similar Threads | ||||
Shock Upgrade | Malazan | Axial Yeti | 7 | 11-16-2016 06:30 PM |
shock upgrade | yazholes | General Scale Talk | 2 | 12-05-2011 05:27 AM |
Shock upgrade | oko0913 | Axial SCX-10 | 6 | 12-04-2010 09:46 PM |
Best shock upgrade | bi_eep | General Crawlers | 2 | 06-27-2006 02:05 PM |
