05-05-2017, 02:23 PM | #1 |
Newbie Join Date: Oct 2016 Location: Salina
| New rock ring
I'm am looking at some aftermarket bead lock ring and not sure what will work. I am wanting to keep the same wheels just a more scale look I heard locked up rings will work I am not sure what to do
05-18-2017, 09:44 PM | #2 |
Rock Stacker Join Date: May 2016 Location: seward
| Re: New rock ring
im not sure what you mean by locked ring??? What i think you mean you want is new beadlock wheels? or just the rings? if you get all new wheels, Assuming you get a good deal ita bout 60-70$ but if your getting just rings like these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 its only about 15$ Is this what you meant or did i completely misunderstand you? |
05-18-2017, 11:09 PM | #3 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: New rock ring
What redcat are you talking about?
05-22-2017, 08:16 AM | #4 |
| Re: New rock ring
Everest 10 and the outer and inner ring bead lock ring
05-22-2017, 09:19 AM | #5 |
| Re: New rock ring
As far as I know the is no aftermarket ring that works. Everest wheels are a 7 hole ring and most aftermarket are based on axial 6 hole ring. You could use some washers that are big enough or find some cheap wheels. Edit: Rockslide's bead lock rings and they bolt right on to Axial wheels. Just found this info on another site so the reverse would be the same axial style beadlocks on rockslide wheels. Last edited by hillbillyrc; 05-22-2017 at 09:26 AM. |
05-23-2017, 11:16 AM | #6 |
| Re: New rock ring
Just best to get different rims then thanks for the help what are the widest rims that i can buy with out spending a ton of money and work well
New rock ring - Similar Threads | ||||
~The Scale Shop~ Rock Ring Blowout Sale! + introducing new 1.9 "Rock Stomper" Ring | STANG KILLA SS | Vendors Tires and wheels | 11 | 10-08-2007 09:30 PM |
Rock ring ?'s | atvdude775 | Tires and Wheels | 2 | 06-21-2007 03:43 PM |
Axial 2.2 Rock Beadlock as Rock Ring? | CoolManLance | Tires and Wheels | 5 | 03-21-2007 11:59 AM |
$14 for 4 Rock Rings!!!! TheCrawlerStore 2.2 Rock Ring Giveaway | kevinlongisland | Tamiya TLT Crawlers | 156 | 02-12-2007 09:21 PM |
