05-29-2017, 12:46 PM | #1 |
Newbie Join Date: May 2017 Location: Orlando
| E10. Gear box upgrade/swap
I broke the shaft coming out of the gearbox that the spur gear calls home. I can only find the full gear box as a set not the individual internal parts. Is there better gear box that will drop in to the stock location with out to much fabrication.thanks in advance
05-29-2017, 02:28 PM | #2 |
| Re: E10. Gear box upgrade/swap
You could switch to an scx10/ax10 transmission without too much trouble. I believe you'd just need to drill 2 new holes in your skidplate to make it work. My son stripped the top gear in his e10 trans so he just bought another complete redcat transmission for ~$20. I should have checked to see if the axial top gear would work, in which case, I bet an axial top shaft could work too?
05-30-2017, 06:46 PM | #3 |
Rock Stacker Join Date: Jun 2016 Location: Squaw Valley
What u do is just buy scx10 gears. No modding needed. Use the same gear box. Everest center tranny is a clone of the scx10. I am using hot racing scx10 hardened aluminum gears in my everest tranny right now. You have to use the scx10 outdrives as well. Sent from my SAMSUNG-SM-N900A using Tapatalk |
05-31-2017, 05:04 PM | #4 | |
| Re: E10. Gear box upgrade/swap Quote:
E10. Gear box upgrade/swap - Similar Threads | ||||
Axial overdrive gear fitment for E10 | Smokin' Joe | Redcat Crawlers | 7 | 02-06-2018 09:58 AM |
E10 Shock upgrade | Stangman66$ | Redcat Crawlers | 3 | 04-16-2017 01:45 AM |
pinion gear and steel gear upgrade question (in the middle of installing, pleasehelp) | Sloalty | Redcat Crawlers | 3 | 05-23-2016 08:48 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
txt traxxas gear box swap | sid | Tamiya Txt-1 and Juggernaut | 1 | 11-07-2006 10:47 AM |
