11-16-2017, 04:03 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Prospect park
| No $ mods gen 7 crawler |
11-17-2017, 12:04 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: No $ mods gen 7 crawler
Good job figuring out the issues and coming up with solutions! |
11-17-2017, 07:53 AM | #3 |
| Re: No $ mods gen 7 crawler |
11-17-2017, 10:17 AM | #4 |
Do the front dogbone complain about the increased steering mod? If so then you could upgrade to CVD's/CVS/universals that come with the Pro version. They'll look something like this: |
11-17-2017, 12:39 PM | #5 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
In my steering video I went through steering upgrades and showed the limitations of the dogbones along with the increased angles with the CVAs. You do get more steering angle out of the CVAs, but not a ton. I managed to max out the CVAs too. Down the road I may try some aftermarket CVAs to get more steering. https://youtu.be/OOMPsHpXpbg Last edited by Jim85IROC; 11-17-2017 at 12:49 PM. |
11-17-2017, 01:55 PM | #6 |
| Re: No $ mods gen 7 crawler Hi I have no problems at all with the stock dog bones everything is working great. |
11-17-2017, 01:58 PM | #7 | |
| Re: No $ mods gen 7 crawler Quote:
Here is mine worked out great no problems and no extra $ to spend...and yes you can see goop glue dabbed on the bottom shock spring holders a trick I do so you cant lose them. Last edited by shenlonco; 11-17-2017 at 03:15 PM. | |
11-17-2017, 10:01 PM | #8 | |
1) How much did the CVA universals run you? 2) Where'd you buy them? 3) In the comments you said "I think the whole axle assembly and steering components are the same (as the EVEREST-10)". If I'm reading the manuals right, the part numbers for the dogbones are different. Can you please verify these will work? If so, peeps can use GENERIC $8 CVD universals from the Scx10 OG for their Gen7s by just grinding down the ends a hair to fit into the stock lockers. | |
11-17-2017, 10:05 PM | #9 | |
11-18-2017, 04:59 AM | #10 | |
https://www.youtube.com/watch?v=dg1X...dxaokOQHG8PHg9 But here is just one of them. | |
11-18-2017, 05:55 AM | #11 |
That's great news for those who bought the Sport model and don't want to pay more for increased steering. Did you clearance the front of your c-hubs and use countersunk screws like Jim, or does your steering still hit the button screw that holds the c-hub on in the front? Refer to the screw below the saxophone: Last edited by StomperCrawler; 11-18-2017 at 06:02 AM. |
11-18-2017, 09:10 AM | #12 | |
when you turn the wheel all the way you can see the spot the screw your speaking of it's outside half hits the steering knuckle by the ground nib you cut off you can mark the spot where the outside of the screw hits and then simply make a hair more notch in the steering knuckle deeper where it hits the screw it will then let it turn a bit more because the outside half of the screw head really is only hitting the steering knuckle there stopping it from turning a bit more.. I wont countersink that screw Tires will probably rub like crazy when your going on rocks and the axle flexes... I am leaving mine as is all stock and works great Last edited by shenlonco; 11-18-2017 at 09:16 AM. | |
11-18-2017, 09:28 AM | #13 |
Makes sense to me. There's something to be said for not having to buy extra parts to get a rig to work right. More than that, it's fun to tinker a bit and get better performance without paying a dime! |
11-18-2017, 11:34 AM | #14 |
11-18-2017, 02:24 PM | #15 | |
I can't say eith 100% certainty that the E10 parts are the same, but the chubs and knuckles are the same, and I believe the axle housings are too, so I don’t know why the dogbones would differ. I believe that you can use SCX10 axles, but you need compatible lockers. The SCX10 shafts are smaller where they interface with the lockers. Last edited by Jim85IROC; 11-18-2017 at 02:27 PM. | |
11-19-2017, 06:26 AM | #16 |
Cool; $20 isn't too bad. If you do ever get to test the Scx10 axles in it, please let us know. |
11-19-2017, 02:39 PM | #17 |
If I break the Redcat CVAs I'll look elsewhere, but I'm not too hard on my crawlers, so I'm hoping that these will survive.
No $ mods gen 7 crawler - Similar Threads | ||||
More redcat gen 7 mods! | shenlonco | Redcat Crawlers | 2 | 11-27-2017 08:46 PM |
gen. 1 xmods crawler! :D | RCMFMaxxMan | General Crawlers | 0 | 11-27-2007 05:58 PM |
Gen 2 REVO Based Crawler | RevoRacer | Traxxas Crawlers | 29 | 03-26-2006 04:17 PM |
