08-06-2009, 12:05 PM | #21 |
Yep, got mine installed this morning.....MUCH better than the RC4WD scaler shocks that were on my light truck to begin with. Yeah, these shocks need no instructions. Pull them out of the package, unscrew the top, fill it up with the oil listed on the back, cycle the shock to get the air out, replace the top and install. Simple. Just like ANY other shock... |
08-06-2009, 12:10 PM | #22 | |
I wanna be Dave Join Date: Jun 2006 Location: Ukiah
Right on guys keep us posted here once you get them on your truck and see how they perform | |
08-06-2009, 04:49 PM | #23 |
Built, not bought Join Date: Oct 2004 Location: Gresham
Just ordered mine. Hope you guys are right. |
08-06-2009, 05:09 PM | #24 | |
Rock Crawler Join Date: May 2007 Location: Glendora
08-06-2009, 05:31 PM | #25 |
08-06-2009, 08:18 PM | #26 |
These things look so scale to an air shock if you remove all the collars and springs... Here are some pics of them on a just recently declassified project..."dark matter". I'm sorry...but this is all that I am at liberty to reveal at this time. Last edited by Offroader5; 08-06-2009 at 08:28 PM. |
08-06-2009, 08:38 PM | #27 |
The shocks look awesome mounted without springs and the collar.
08-06-2009, 08:39 PM | #28 |
Here is my install on an SCX10.
08-06-2009, 09:08 PM | #29 |
08-07-2009, 07:51 AM | #30 |
Wow, thanks guys! :-D
08-12-2009, 07:57 PM | #31 |
Well, I took the plunge. Got my order placed tonight. Gotta give these a try. I have had the RC4WD Dual Spring shocks pull apart on me (2 different shocks)...once in a comp. Time to move to greener waters.
08-12-2009, 08:03 PM | #32 |
08-13-2009, 08:42 AM | #33 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
Those are looking so nice. Can someone take a picture next to the stock AX10 shocks, without the springs? Considering these for a droop setup. Anyone compared them to the Axial comp shocks or the axial scaler shocks |
08-13-2009, 04:33 PM | #34 | |
The Pro-lines (with the shorter rod ends) are about .100" shorter than the stock SCX10 shocks.They appear to have about the same amount of travel if you're using the rubber spacer on the SCX shocks. Hope this helps. Edit:Just realized you wanted them next to the AX10 shocks.Sorry. | |
08-13-2009, 06:55 PM | #35 |
Right on Pat |
08-13-2009, 07:10 PM | #36 |
Looks great to me, thanks for the pics anyway.
08-18-2009, 03:58 PM | #37 |
Got mine in today. They are some pretty easy shocks to build (guess just add oil). They did forget to add some washers so that a 3mm button head screw wouldn't pull through the upper shock cap. They are pretty darn smooth. |
06-09-2010, 08:11 AM | #38 |
Newbie Join Date: Jan 2009 Location: Ocean County
What weight oil are you running with these shocks?
06-09-2010, 09:52 AM | #39 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
Depends on what you want the shocks to do? Is your rig heavy, light? Typically you want heavier shock oil for heavier rigs, also you can control how fast/slow your shocks react during articulation cycles?! So with that being said, for most light crawlers, you can get away with 30-60WT and for heavier rigs, like heavy tubers/scalers, 80-100 works well.. Hope this helps! |
06-09-2010, 09:56 AM | #40 | |
