Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Thread: home made whip antenna
Old 08-01-2009, 12:10 PM   #1
IVE BEEN SZCZERBOTAGED!!
ROLANDROCKSHOP's Avatar
Default home made whip antenna
heres what i came up with this mornin
@ 5am(damn squirrels in my attic).Click the image to open in full size.!!!
alum hollow tube 1/16th
small dia. heat shrink tubing
traxxas shift springs #tra3184
traxxas screws #tra3290 only need 1.
ca glue
cut the tube to the length you want.
slide the spring over the tube,be sure to leave enough of the spring
so that the screw will have enough thread to hold it on.
ca glue the spring on the tube,several times. let set.
put the heat shrink on and heat it up!
now find your spot to install your new whip antenna!
drill your hole for your screw.
screw the spring onto the thread of the screw.
"the more distance between the tube and the screw the more springy
it will be"
i painted it flat black to hide the silver.
enjoy!
ROLANDROCKSHOP is online now   Reply With Quote
Old 08-01-2009, 03:42 PM   #2
Pretty cool idea. I would use a actual plastic antenna tube, so you get some flex out of it as well, but I like the way you pit it together. Nice work.
blackfoot is offline   Reply With Quote
Old 08-02-2009, 04:25 PM   #3
thats a way cool idea i like it i think i need one on my truck
Scoony is offline   Reply With Quote
Old 08-05-2009, 01:30 PM   #4
thank you!
the alum hollw tube makes a "bonk" sound when it hits the body.
Old 08-13-2009, 12:51 AM   #5
How about stretching the spring over the length of the tube then putting the heat shrink over both the spring and tube. It would look more like a real whip with the wire coiled around it.
http://www.wearecb.com/store/firesti...oot-p-203.html
Mutant_Xj is offline   Reply With Quote
Old 09-06-2009, 12:28 PM   #6
Great idea.!
I would try and use a stronger spring or lighter weight material for the antenna, so it springs stiffer like real ones.
I was also thinking you could use guitar strings but that would not look like a firestick type like you made.
either way, great idea and thanks for sharing.
4x4Crawler4LIFE is offline   Reply With Quote
