| | #1 |
| Rock Stacker Join Date: Jul 2008 Location: Austin
| Finally pulled the trigger on a torch. I used my berzo torch a few times, but didn't care for it, hard to pinpoint the heat. I like it better as a BBQ grill lighter. Opted for the Swisstorch, it's such a slick piece. The bumper is so so, top bar on the driver's side is taller then the other by about a 16th. You can kind of see the slope in the pic. Still getting used to doing compound bends and getting it to all be symmetrical. ![]() The base is a piece of 1/4" solid stock, all I had at the time. Had a hard time getting my temps right btwn the 1/4" and 1/8" pieces. The rest was pretty easy, ugly but easy. Figure the next time around I will use tubing. It was my first time doing all this so it should get a bit easier with time. The lights and winch or just resting on the bumper, I am going to get the mounts done tonight. Then sand blast it and paint. Hope to get the rear bumper bent up soon. |
| Sponsored Links | |
| | #2 |
| Fumb Ducker ![]() Join Date: Apr 2009 Location: United States of the Offended
| Looks pretty darn good for a first try. |
| | #3 |
| Rock Crawler Join Date: Dec 2006 Location: Flatwoods
| | #4 |
| Team * ![]() Join Date: Oct 2004 Location: Hellifiknow
| Looks pretty good.Especially for a first try. How about a little info on the torch? |
| | #5 | |
| Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
http://www.lacywest.com/12solder.htm#swisstorch they looks like a slick system | |
| | #6 | |
I opted for the Swisstorch instead. Figure if I am gonna pay $100 why not $100 more and not wonder what if... I am using the microhead attachment with propane/oxy(bernzo) tanks. I used mapp/oxy first but it was a bit hot, got too hot too fast for me (beginner) I am picking up a peanut torch set off craigslist tomorrow so I can have a larger oxy tank and real regulators. But the berzno stuff works just fine if one was so inclined to use just that. It's a really nice torch. I was able to weld the 1/4" solid rod and 16ga plate tonight much easier with it than using the old bernzo mapp torch. Easier to pinpoint the heat to the rod then over to the plate. The flame is about the diameter of a #2 pencil lead. Last edited by dps50; 09-25-2009 at 10:44 PM. | |
| | #7 |
| Shot some pics real quick. Yes, those are zipties, it's low pressure. I wasn't that impressed by the plastic handle, it had some casting flash on it. For what I paid, it should have been taken care of. The one thing I really like about this design over the Smith/Gentec is how the valves can be controlled by your thumb. You can't do this with the other torches. These valves are very smooth, they are knurled alum. which makes for a sure grip. I can crack them open with one hand and hit the striker with the other. Very slick. Worth the extra money, probably not, but it is a very comfortable setup. Only thing I don't like is the hoses. They are from the Bernzo oxy/mapp kit. I bought it for the tank regulators. The hoses are very stiff. I will probably try some surgical tubing, it's lightweight and very flexible, BUT not compatible with propane for the long term. Must switch out the hose about once a year and inspect the connection at the fittings for deterioration. Action shot of the flame. |
| | #8 |
| Rock Stacker Join Date: Jun 2009 Location: Chester
| Looks good to me, man! I didnt notice the difference until you said something. Practice makes perfect! I need to get a welder and practice welding! lol |
| | #9 |
| | #10 |
| High Plains Drifter... ![]() Join Date: Oct 2006 Location: Sterling VA
| Not bad at all for a first shot. That little torch is pretty sweet, it looks perfect for this scale of work. I've been using my Victor oxy/acetelyne rig with the smallest brazing tip I have, even turned down to minimum I have to be careful not to overheat. And it's pretty clunky to handle (but not as clunky as a MAPP bottle though) I just started tube work myself, and I quickly figured out that accurate compound bends were next to impossible, especially if you're having trouble keeping tubing from sliding in your bender as you bend it like I was. Any mark you make on the tube to designate where to place it in the bender becomes instantly moot if the shoe grabs the tubing and slides it in the tool as it bends, instead of the shoe sliding across the tubing as it bends like it's supposed to. I started doing the compound bends in multiple sections and then pinning them together and brazing them into one solid piece. This allows you to place bends in precise places by being able to adjust the length between the bends and to rotate tubes to nail the angles exactly. You can't do this as easily with solid rod though, I'm using rod for the pins. 1/8" fits inside 3/16" tubing and 3/16" fits inside 1/4" tubing. I guess you could do solid rod if you could figure out a way to jig it together straight while you braze it... |
| | #11 |
| Rock Crawler Join Date: Jul 2009 Location: talladega AL.
| Holy crap thats nice. Gotta see a pic of it mounted up. |
| | #12 | ||
| Thread Tools | |
| Display Modes | |
