03-07-2010, 02:09 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: VIRGINIA BEACH
| scale lighting system from rc4wd
was wondering if there was a way to use all the lights without the two flashing when going forward
03-08-2010, 03:47 PM | #2 |
guess no one knows ill see if i can figure something out
03-08-2010, 06:35 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
What do you mean the lights flash?
03-09-2010, 03:43 AM | #4 |
never mind im sending it back but two of the lights on it flash while going forward this is not why im sending back though
03-14-2010, 04:12 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
All you had to do was unplug those two lights.
03-31-2010, 02:59 PM | #6 |
Rock Stacker Join Date: Jan 2010 Location: Hollywood, CA
I was considering getting this but I want to know if there's a way to have the "turn signal" lights stay on and not flash. I don't know about you guys, but I've never seen turn signals used offroad........ Also, after watching videos of the light kit in action, it appears the tail lights only operate as brake lights, ie, they turn off when the rig is in motion. Can anyone confirm if they can be set to stay on? http://www.youtube.com/watch?v=Cs3y6...ayer_embedded# |
03-31-2010, 05:40 PM | #7 |
You are correct about the taillights I ended up hard wiring two radio shack LEDs directly to the battery so they stay on all the time. Than use the brake lights, turn signals, headlights, and reverse lights from the kit.
04-01-2010, 05:32 PM | #8 |
What's a good lighting system then? One that has full-time headlights, tail lights and amber parking lights, but also operational brake and reverse lights.
04-01-2010, 06:00 PM | #9 |
may want to look into the axialn nvs system
04-02-2010, 05:39 AM | #10 |
Quarry Creeper Join Date: Jan 2005 Location: UK
| Or even the 3Racing light system |
04-02-2010, 07:56 AM | #11 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
Punk RC has a new one in development that looks promising. It should be fully customizable.
04-06-2010, 06:14 AM | #12 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Is there a link to the Punk light system?
04-06-2010, 09:19 AM | #13 |
Rock Crawler Join Date: Apr 2008 Location: Albany
Check out this lighting system. A bit more money but read what it is capable of. Amazing Evan |
04-06-2010, 02:10 PM | #14 |
04-07-2010, 05:48 PM | #15 |
Pebble Pounder Join Date: May 2009 Location: Bakersfield
I just found out the RC4WD SLS is not compatible with my Spektrum DX3R. I dont know if it is not compatible with all 2.4ghz systems but I know it didnt work with mine. Does anyone know of a good lighting system that does with with 2.4ghz and one I can purchase in the US?
04-07-2010, 07:45 PM | #16 |
| Sorry about that josh http://www.dimensionengineering.com/...tarterKit.html This lighting system is very in depth. You can program it from your pc. For example: if you are working on a jet and you have your LEDs setup for your afterburner effects but only coming on at 80% of throttle. Very cool Evan Evan |
04-08-2010, 03:24 PM | #17 | |
04-08-2010, 05:44 PM | #18 |
Doesn't make sense to me either. Its just two plugs. I figured the rx receptical from a Spektrum SR3100 would be like any other rx. You have two plugs that connect to the rx like a servo or esc would and you have 2 females that connect your esc and servo. Both my esc and servo worked fine with the SLS in place so I know I was getting both power and signal between the SLS system. I just wasn't getting signal lights to work or the brake lights to turn off unless I was almost at full throttle. My endpoints were correct as well as expo settings. Also the the signal loss setting where all the lights flash didnt work either maybe due to the internal failsafe built into the radio. They would flash for a half second and shut off when I would simulate radio signal loss. I sent it back to the hobby shop and they were the ones who tested it out and said, we couldn't get this to work on the 2.4ghz system they had in stock so they were still checking to see if it was all 2.4 or just some 2.4 systems. |
03-02-2012, 02:15 AM | #19 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
| Re: scale lighting system from rc4wd
Does anyone have a pic of this? I am new to plugin in accessories. The 4 leads that plug into are not labeled. Which one plugs into the servo. Do I need additional splitters? Thought it'd come with instructions of some kind. Thank you for the help I have the futaba rcvr and 4ch txmtr. |
03-02-2012, 06:11 PM | #20 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
Axial NVS....little pricey but it will do what you are describing, like I said lotta $$$ for something you can build yourself with a little research and basic soldering skills
