07-15-2011, 08:00 PM | #1 |
Rock Stacker Join Date: Feb 2011 Location: flathead
| rc4wd wirelEss winch
So do I hook up a second batery to poweR it or. Do I get An adApter To hook up to the regular bAtery???
07-15-2011, 08:15 PM | #2 |
Rock Crawler Join Date: Jun 2010 Location: Forsyth County, Georgia
I used a second battery. I moved the battery mount to the front of the chassis so you have the wieght of two batteries on the front which helps the climbing ability aswell as allows you to hook the winch up |
07-15-2011, 08:35 PM | #3 |
Rock Stacker Join Date: Jun 2011 Location: Kaneohe, Hawaii
I use a "Y" connector and use just one battery.
07-15-2011, 08:56 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
You can do either. I used a small 800 mah 2s and it nvr drains it.
07-15-2011, 09:47 PM | #5 |
ThAnks guys
07-16-2011, 07:43 AM | #6 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
I use a 2nd battery, but either way, make sure not to exceed 2cell.
07-17-2011, 11:19 PM | #7 |
So I just hooks my wires to my battery wires, an it's workn good but idk if my controller is alll good it mums out slow and winches in reel quick mitt burned it up wen I hooked the second battery, u guys got any input
08-09-2011, 01:36 PM | #8 |
Rock Stacker Join Date: Feb 2011 Location: Los Angeles
This is good to know. How well does it pull i.e... the rating? My rig is about 9 lbs and I donlt want to buy one if it burns out quickly? Any reviews would be helpful.
08-11-2011, 04:20 PM | #9 |
It sound all good, just remember to use a little throttle when wenching you're rig.
08-11-2011, 09:57 PM | #10 |
So I gOt a new winch controller anit works great my rig weighfs more than nine pounDs and it does Fine just remEmber to give it gas. My boyer trugey is like 12-15 lbs havnt wieghd it but it heAvy
08-13-2011, 08:30 PM | #11 |
You might want to look at this one than. New Quicksand 8274 Winches |
08-15-2011, 08:37 AM | #12 |
That's one bad winch!!! So its more scale an more pwerfull?
08-20-2011, 07:30 PM | #13 |
Rock Stacker Join Date: Sep 2010 Location: Medway
Could I use a nitro receiver pack to power the RC4WD winch?
