11-22-2013, 11:38 AM | #101 |
Rock Crawler Join Date: Mar 2010 Location: NRV
| Re: Wolf Creek/Speedweigand Garage/Service Station |
11-25-2013, 10:53 AM | #102 |
Can it be? My Pump is finished? Of course not. You wouldn't know it from these pictures but I still need to finish the glass on the other side but naturally, there is an A & B side... and the internet world is never going to see the B side. I do have a Lead warning sticker that goes on the side that I neglected to print & need to stick on but other than that & the B side, it's done. Oh! and front shell decals. I printed them on "clear" decal paper & the yellow side looks good but the red washed out the decal so... not sure. May try white decal paper. But for now, I just took the yellow side off. I rigged some rubber bands inside & put tension on the retract cables so they are actually functional. I went to a bit of effort to get 1/32” stainless steel 7x7 cable and then made them retract so you never see them… Pretty clever, don’t ya think? But I'm very pleased with the end result. Here is a detail of the retract cable rigging. |
12-01-2013, 09:12 PM | #103 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
very cool man. Great job! looks done to me
12-02-2013, 01:04 PM | #104 |
01-06-2014, 09:15 AM | #105 |
I've been working on the doors but I sort of posted my garage door panel technique at the beginning of the thread and well.... i doesn't make for real exciting updates but... I can see the light at the end of the tunnel and nothing like mocking up something... anything... to get you motivated to keep pushing... gluing little sticks together. The hinges have me a bit baffled but I want to make them fully functional with rails, springs, etc. I used the modeljunkyard technique and using sheet aluminum and a rivet, fabricated a hinge but... I'm not looking forward to another tedius task... thinking maybe of soldering some from brass??? dollhouse hinges? 3D Printing??, Duct tape? Anyway, I mocked things up & like the way it looks. |
01-06-2014, 09:39 AM | #106 |
Quarry Creeper Join Date: May 2007 Location: Euless Tx
They have model aircraft hinges that small. Sent from my HTC VLE_U using Tapatalk |
01-06-2014, 12:25 PM | #107 |
Any way to to make 1 long hinge then cut it up into small sections? ( Think- extrusion)
01-06-2014, 01:00 PM | #108 | |
| Re: Wolf Creek/Speedweigand Garage/Service Station Quote:
Isn't the intrusion? or implusion? LOL. the nylon aircraft hings are going to work I think. | |
01-06-2014, 02:32 PM | #109 |
I used to use them to hinge doors on 1/24 static models when I was a kid.. could work for this rather well, and probably work on hardbodys too. Sent from my HTC VLE_U using Tapatalk |
01-11-2014, 08:56 AM | #110 | |
Rock Crawler Join Date: Nov 2005 Location: Winchester
01-14-2014, 08:40 AM | #111 |
"Got those highway blues, can't you hear my motor runnin' Flyin' down the road with my foot on the floor" |
01-20-2014, 11:15 AM | #112 |
Well... slight change of plans. I still plan to build this for use in the outdoor scale park but after a recent photo shoot, I wanted to make it more user friendly for winter time, indoor, diorama like photo fun. I started on the transition this past weekend. I used some foam boards for the base since I already had them but really should have used some plywood. But I'll put some underneath & maybe carve some tire ruts in the foam. The Woodland scenic stuff is great but starting to get expensive so I developed my own brand of scale parking lot gravel. I’m working with a powerhouse distributor and was able to get it distributed throughout the United States almost overnight. I developed an odor control version hoping that it would remove lacquer fumes but no luck so far. I put plastic over the pump island so I could glue the gravel right up to it but still be able to remove the awning. Since my odor control landscaping ballast is not perfected yet, I raided my supply of left over interior latex. I settled on “Roasted Garlic”… It seemed like a good base coat and it will match our kitchen. A little tip for anyone in the USA, At Lowes, you can purchase pint size samples of interior latex for under $3 each. For something like this, a few basic earth tones and you can mix & come up with a lot of natural variations. |
01-20-2014, 11:15 AM | #113 |
Next, I’ve been making trees for my slot car track so I experimented with bumping the scale up. My wife has been quite pleased with my dedication to keeping the burning bush pruned. I used some foam I had lying around to fashion clusters of leaves. ...and then glued Woodland scenic clump foliage to it. Experimented with hot glue, white glue & found spray adhesive worked well. Really helps to make a little stand to work on it. |
01-20-2014, 11:16 AM | #114 |
I Googled “Small town main street” & found some high-res images & printed them out big and mounted them on foam board. The idea is rough at this point but I felt the initial results have a lot of potential. |
01-20-2014, 07:15 PM | #115 |
The base paint is a great way to get some ground cover glued to the surface, you can add more and glue it in place with a white glue/warm water and a few drops of dish detergent ( it helps to break up the water tension) Lot's of great reads about doing scenery in the model railroad forums. |
01-22-2014, 07:20 AM | #116 | |
Thanks everyone. Quote:
02-03-2014, 10:19 AM | #117 |
Well... we had a good hangout in the basement day. The weather was so nice... we actually went out and drove... which really screwed up my plan to take pics inside.... not really... here are a few good ones. |
02-03-2014, 11:02 AM | #118 |
Also, made this photo booth... for lack of a better word. |
02-03-2014, 02:31 PM | #119 |
02-04-2014, 06:52 AM | #120 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
Makes the stuff Jason and I built look like garbage. Haha. Great job. I'd love to see the whole park someday. Sent from my HTC6435LVW using Tapatalk |
Wolf Creek/Speedweigand Garage/Service Station - Similar Threads | ||||
Wolf Creek RC Scale Park | DRW-FJ40 | General Scale Talk | 253 | 02-06-2017 08:56 PM |
I went to Wolf Creek... | pardonmyn00b | Scale Videos! | 19 | 09-28-2012 08:32 PM |
Wolf Creek ORV Park | DRW-FJ40 | Tamiya CR-01 | 11 | 11-22-2011 06:22 AM |
My Hilux in Wolf Creek RC ORV Park | DRW-FJ40 | 1.9 Scale Rigs | 11 | 09-15-2011 10:08 AM |
My Honcho in the Wolf Creek RC ORV Park | DRW-FJ40 | Axial SCX-10 | 33 | 07-27-2011 07:29 AM |
