Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Thread: How to Make your Own Scale Decals
Old 11-08-2006, 01:25 AM   #1
Default How to Make your Own Scale Decals
All you need is an InkJet colored Printer and a Good can of Clearcoat.
First find a good picture of what you are wanting to make into a Decal. I'll use the XJ grill and tail light I just made for an example.
Step 1: You will need to buy this and a can of Clear coat
Step 2: Find a picture that has a perfect angle you're looking for.
Step 3: Go into photoshop and remove everything but the Grill
Step 4: Scale to what size you need. You may need to print a couple of test decals on reguler paper to make sure you have the right size. Once you make sure you have that right. Put in the sticker paper. Print your decal and let it dry really good.
Step 5: When it dries. Spray a light coat of Clear coat on it. Let that dry. Cut out the decal and put it where you need it. The clear coat should keep the ink from washing off. At least for some time. You can always make another later.
It should look something like this when your done. Just repeat the same steps on other Decals. No more searching ot waiting for someone to make them for ya.
With this you can make Diamond plate panels, Door handles, hinges, Lights, Club Logo's, and etc.... Really the only thing stopping you to make anything is you.....So start making your own homemade decals...Have fun with it.
Old 11-08-2006, 01:30 AM   #2
i might have to try this... if you don't have any luck with it tomorrow. let me know how it goes. thanks.
4RunnerKid is offline   Reply With Quote
Old 11-08-2006, 01:31 AM   #3
I would like to just add. This is not the same way I make them to sale. I have complete sign shop that I get to use for making those. This was just an idea I had and wanted to see if it would work. The ones I make to sale are made for out door use. And are top notch.
Old 11-08-2006, 01:35 AM   #4
well that'd definitely be a little better. thanks for the heads up. i'll leave it up to you then.
Old 11-08-2006, 05:35 AM   #5
No Problem.
Old 11-08-2006, 03:25 PM   #6
Haters gonna Hate
1BadJeepBruiser's Avatar
seems pretty cool, would probably work good for the Bruiser dash decals and stuff. Nice tip If you dont mind, Ill add it to the tips and tricks
Mike
Old 11-08-2006, 03:35 PM   #7
Coolhand's Avatar
I have a suggestion, something I'm going to try ...
Get some XXX-Main Lexan Picture Glue and some kind of photo paper (not the sticker variety).
Print the labels exactly as r2j is suggesting (which I *hadn't* thought of, that's a damn good idea) on the photo paper ...
Add the glue and put it on the inside prior to painting. I'd haze the back with silver or white to be sure the color doesn't bleed through too much. Now you have internal decals; they should hold up longer and won't fade or get ripped.
Coolhand is offline   Reply With Quote
Old 11-08-2006, 03:40 PM   #8
great idea, does it matter what kind of clearcoat?
chino438 is offline   Reply With Quote
Old 11-08-2006, 03:58 PM   #9
Powered by Awesome
TwistedXT's Avatar
looks good.. but im going to pop your bubble... you put the tail lights on the wrong sides..... still looks great though... good idea!
TwistedXT is online now   Reply With Quote
Old 11-08-2006, 04:31 PM   #10
they look like chev lenses to me
OIT_TLT is offline   Reply With Quote
Old 11-08-2006, 04:33 PM   #11
Like a year ago I had done the same thing. I bought some sticker paper from wally world, and made them from that. I didn't have any clearcoat, so the ink kinda got smeared in the wet. I was thinking of just putting some of the clear packing tape ever the decal, then cut it out.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 11-08-2006, 04:37 PM   #12
Colt Python/SR9c
TwistedCreations's Avatar
JIA did this on the roof of his pleazer body.. not sure how he did his.. It's on the inside also I believe
TwistedCreations is offline   Reply With Quote
Old 11-08-2006, 05:46 PM   #13
I did the same thing a while back on my chevy build (grille and chevrolet sticker on windshield) but i used a sticky label sheet. Is that stuff you used Clear? I made a logo for on my truck and it would be a major pain to cut it out on the label sheet i used.
Racefan1115 is offline   Reply With Quote
Old 11-08-2006, 06:05 PM   #14
Coolhand's Avatar
XXX-Main Picture Glue. :-P
Old 11-08-2006, 06:57 PM   #15
This is awesome! I am going to try this.
NissanNut is offline   Reply With Quote
Old 11-08-2006, 10:43 PM   #16
What are the chances I could get someone to do this for me cause I have the crapiest printer in the world.
C_Money is offline   Reply With Quote
Old 11-09-2006, 01:11 AM   #17
what do ya'll think about a big piece of double sided tape. put decal on one side and cut it out and stick it on the inside of the body. this may allow for more intricate designs, you could cut inbetween text (like cut the inside of the 0 out) then paint over everything. does this sound reasonable? or not so much.
srfrkyle1234 is offline   Reply With Quote
Old 11-09-2006, 01:38 AM   #18
Give it a shot. Never hurts to try.
Old 11-09-2006, 03:47 AM   #19
Mike
Cool, Don't mind at all.
