Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Thread: Tiny Iny Bulbs....check these out
Old 11-28-2006, 11:02 PM   #1
Haters gonna Hate
1BadJeepBruiser's Avatar
Default Tiny Iny Bulbs....check these out
These arrived in the mail today, so I took some pics, I think these are perfect for an endless amount of ideas. The are ULTRA TINY and the smallest bulb that I can find.
Here is a comparison shot next to a beadlock screw
Now here is an example of what you can use them for
Drill a Tiny whole in the marker light and let it just barely poke through, itll barely be visable untill you turn it on
They light up pretty good too
last one shown in a Bruiser lens, gives it some good light.
I got them from miniatronics.com, they are actually a few towns over from me so delivery was quick They make various different lights and they are based around around train use but are great for RC.
They operate on just 1.5 volts so only a single double A is needed and they have a avg life of 1000 hours, not to bad. They come in a bag of 10 for 10$
- Mike
BTW they make them in amber, red, white, blue, green etc
Old 11-28-2006, 11:05 PM   #2
fokai's Avatar
those are awesome! i need to get me some of those for my upcoming build
fokai is offline   Reply With Quote
Old 11-28-2006, 11:09 PM   #3
Yeah, those little bulbs are pretty neat. I've gotten some at a local Dollar Store before. I've heard them be referred to as "rice lights" before due to their size/shape.
FYI - the ones I got were multiple colors, originally designed for miniature Christmas trees. I found you can use some rubbing alcohol to remove the colored coating on the bulb if you want clear ones (not sure if this is the same for these ones or not).
Mad Scientist is offline   Reply With Quote
Old 11-28-2006, 11:49 PM   #4
Hmmm...... Maybe some nice High Lift roof lights.
4u2nv is offline   Reply With Quote
Old 11-29-2006, 08:36 AM   #5
Actual bulbs, or LED's?
Mirage is offline   Reply With Quote
Old 11-29-2006, 08:44 AM   #6
Haters gonna Hate
These are bulbs, I dont even know if its possible to get an LED this small
Old 11-29-2006, 08:54 AM   #7
Oh my yes, Many LED's, like what can be found in cell phones and other small electronic devices are so small you cant really tell what they are unless they are lit up. They like like tiny little resistors. Ever see the LED lights than have a magnetic backing so you can attach it to your shirt like a button, or even a regular button that flashes, shaped like things such as the american flag, or stars, etc... those are micro LED's.
Anyway, cool find. Those would make for some awesome marker lights on truck roof's, and for around trailors.
Old 11-29-2006, 09:03 AM   #8
Yes theres LEDs that are almost microscopic. LED's can be made A LOT smaller then bulds because they don't use a filiment. I think the LEDs I have in my jeep are just a tad bit bigger than those, and they're much brighter. Check them out: cheap LEDs at target
ILoveRCRockCrawlin is offline   Reply With Quote
Old 11-29-2006, 09:11 AM   #9
Haters gonna Hate
o wow, I never thought about it that way... learn something new everyday right?
Well these should work good for the stuff like you said, they wouldnt make good head lights because they arent bright enough but they are cool for other little details, wait to you see how I use them on my high lift its going to require some machining but its going to be the ultimate scale touch
Mike
Old 11-29-2006, 09:13 AM   #10
Haters gonna Hate
I saw that post, those things are nice and cheap but WAY TO BIG for what I wanted to do
Does anyone have a link to a place that sells the micro LEDs? Id want them to be 1.5mm just like these bulbs I got.
Mike
Old 11-29-2006, 09:27 AM   #11
Mike
Try google, Im sure that would turn something up... problem is, you will probably have trouble wiring up LED's that are that small. They will most likely be shaped a bit different like a flat resistor on a circut board of some sort, so May not be possible to use them, but the size of bulbs you have, there should be something somewhere.
Old 11-29-2006, 09:32 AM   #12
AKA TOKEN
ColquittCustom405's Avatar
Nice find mike looks pretty cool.
ColquittCustom405 is offline   Reply With Quote
