| | #1 |
| RCC Addict Join Date: Dec 2004 Location: HELL.....
| ok i know its simple, but for some reason i'm just not thibking i'm correct. granted its been 15 plus years since electronics class. i have LED's rated @ 3.6v and i am powering them with a 4.5v supply. what size resistor do i need? i wanna say 25 ohm-ish |
| Sponsored Links | |
| | #2 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| This might help http://www.electronics2000.co.uk/calc/calcled.htm What is the forward current of them? |
| | #3 |
| I wanna be Dave Join Date: Apr 2005 Location: Kennewick
| 125-150---175 ohms, depending on the brightness. ^.....^......^ Low mid-Hi Ultra brite Id say go 150ohm resistor (I did science last year in eight grade and we studied on resistors and ohms for a long time!) |
| | #4 |
| Quarry Creeper Join Date: Jan 2006 Location: Orlando
| For the sake of learning, here's how it's done: Supply Voltage - LED Forward Voltage = Voltage Drop Across Resistor Voltage Drop Across Resistor / LED Forward Current = Resistor Value (In Ohms) So, if the LED you are using is say 20mA of forward current, it goes: 4.5 - 3.6 = 0.9 0.9 / 0.020 = 45 ohms A 25ohm resistor would come out to 36mA. Typically, the more current, the brighter the LED, so long as you're within the limits of the LED. |
| | #5 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| here ya go....... easy and simple.. click wiring diagram and it will tell ya how to wire them up http://led.linear1.org/led.wiz |
| | #6 | |
| | #7 |
| ya thats what i was looking for...an idiot calculator. its funny i came across my old electronics notebook from YEARS ago and its amazing all that i have forgotten. it sucks getting old! |
| | #8 |
| Rock Stacker Join Date: Nov 2006 Location: Winston Salem
| It also depends on supply voltage. Alot of the leds are just over 1 volt but others are 3 volts and some are 6 volts. You can buy them that the impedience is already set for a 12 volt system. I have used alot and majored in electronics design. The 3800's I used in my truck are for 1.3 volt and running off a 9 volt battery. The resister I am using is a 470 ohm. You could probibly get by with a 400 but I dont like having to redo stuff because I over amped it and the led blew up or shorted. Although when you overvoltage one and it blows up its cool. Just my 2 pennys for what its worth. Just check your specs when you buy them. Jameco is an online company that has killer prices on things like that. Radio shack 5 resistors 2 bucks and change. Jameco 100 for a buck and some pennys. |
| | #9 |
| RCC Addict Join Date: Apr 2005 Location: Seattle
| post something like that without giving us a link!!! It's funny, I logged on today specifically to ask this exact question! |
| | #10 |
| I bought all mine from LSdiodes.com |
| | #11 |
| Twisted, you rock! I paid $28 for 5 bright whites 5mm at Radio Shack today, I am ordering 20 for $15 from LSD! Good thing I haven't opened the RS ones yet! |
| | #12 |
| radio cracks prices blow. They dont have a selection like they used to either. It should be called Home electronics, cell phone shack lol |
| | #13 | |
| Thread Tools | |
| Display Modes | |
