Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Thread: tlt kit leftover fairlead.
Old 01-06-2007, 11:20 AM   #1
I had the hottest girlfriend at the MSD Nats
Default tlt kit leftover fairlead.
not sure if this is scale but im using it. this is what i stayed up last night making and its really easy.
i just used some parts i had leftover and i dont know waht they are or if they are important. i just built my axles and shocks and all this is leftover
if youve already seen it or done it good for you!
check it out.
its really easy. it took two tries and about 30 minutes of trial and error but it should be faster with pictures.other than the tlt parts you need:
metal
tinsnips or something to cut the metal with.
pliers or something to bend with
punch to center the drill bit. i used phillips screwdriver
dremel or something to drill with
_____
this is what i used. i hope you have these parts. i used two nylon locknuts and four regular nuts instead.
its just some flatstock metal i had laying around. about 7.5 cm x 1.5 cm i had already started bending it before i took the picture. those two long rods are the medium sized rods at roughtly 4.5cm
_____
i started before i took pics so imagine...
i just drilled a hole very close to the edge. (be sure to use a punch type thing so your bit doesnt walk all over the place. i used a small phillips srewdriver.) leave enough to fit the silver cylinder with a little room. measured the height of the silver cylinder and bent it with a set of BIG pliers. hold it in the pliers and then bang or hammer it into a 90* angle.
mock up for fitment.
_____
then i used the spur gear as a template for hole placements. turns out its near perfect. find two holes on the spur gear and mark your metal piece with a marker or something. this is how i did it
mock it all up to be sure things dont hit eachother or your holes wont line up on the other side.
_____
this is what you probably have now.
measure your brass things and spacers. just baaarely over 3cm. mark your measurement. see that wee green mark i used. you may want to drill the other holes now as its flat. i didnt but it may be a good idea or not. its really up to you.
____
i bent it at last step and i had this
i also drilled a hole for the silver cylinder just like i did the other side. mock it up to be sure it wont hit the side and look funny crooked
then i said oh! does it even fit? did i bend it right? and i mocked it up with the brass things.
nice fit!
again i used the spur gear to find proper hole placement and drilled. then i bent the last bend and drilled the last hole. easy! i assembled and viola! i was proud of myself. (it was veeeery late)
heres what you should have
obijuan is offline   Reply With Quote
Old 01-06-2007, 11:24 AM   #2
that looks really slick. what are the dimensions?
gooba is offline   Reply With Quote
Old 01-06-2007, 11:26 AM   #3
roughly 1.5cm tall x 3.2cm wide x 1.25cm deep. not including the screws. the black screws are your mounting screws and the sliver ones you can probably cut off.
Old 01-06-2007, 09:24 PM   #4
what is it
Project_TLT is offline   Reply With Quote
Old 01-06-2007, 09:56 PM   #5
2006 2.2 National Champ
BENDER's Avatar
Originally Posted by Project_TLT
what is it
A roller fairlead for a winch.
Nice work using stock parts obijuan.
BENDER is offline   Reply With Quote
Old 01-06-2007, 10:12 PM   #6
oh i wasnt sure i knew it was something for the front of the truck
Old 01-06-2007, 10:26 PM   #7
Like to see people take the time to make a fairlead
Heres mine.
The_Green_Mennie is offline   Reply With Quote
Old 10-21-2007, 12:47 PM   #8
Any chance you can repost the pics from the first post, they don't seem to be working anymore.
metomwhou is offline   Reply With Quote
Old 10-21-2007, 02:38 PM   #9
whoa this was one of my first posts, wierd. unfortunately i dont think i have these photos anymore.
Old 10-21-2007, 03:17 PM   #10
I lost my vendor privileges
you suck Matt. nah. i would like to see these also. i missed the process.:-(
clodstall is offline   Reply With Quote
Old 10-21-2007, 03:21 PM   #11
it was pretty crude and didnt look all that great. i have it complete still so ill snap a pic for you. its very self explanitory.
Old 10-21-2007, 03:25 PM   #12
cool thanks Matt. i have one on my rig. just didnt make it.
Old 10-21-2007, 03:58 PM   #13
here it is and its pretty crappy. i never dinished it or installed it. pretend those silver ones are screwed in.
Old 10-21-2007, 05:57 PM   #14
Thanks for the pic, it doesn't look that bad! I made one out of styrene and parts tree's. Its not funtional but it looks like a fairlead. I think once I paint it silver it will look better. Its still pretty rough but I'll post up a pic when i can. Hey Clodstall, where'd you get yours?
Old 10-21-2007, 06:29 PM   #15
heres the one im actually using, its from charlie at privateerengineering.com.
Old 10-22-2007, 08:12 PM   #16
In between.
SACCO's Avatar
here is my tlt leftovers fairlead. I like the one from privateer much better though
SACCO is offline   Reply With Quote
