02-17-2016, 06:58 PM | #41 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Sloski's attempt at Styrene
got a little bit done today......... the pump motor and hydro tank..... Last edited by roksloski; 06-02-2018 at 09:42 AM. |
02-17-2016, 08:20 PM | #42 |
painted and mounted........... Last edited by roksloski; 06-12-2019 at 07:20 AM. |
02-17-2016, 08:36 PM | #43 |
Quarry Creeper Join Date: Mar 2007 Location: Who Knows
maybe a parts washer next...... Hey it's a new shop lets not blow the budget yet lets see what I've got room wise first |
02-17-2016, 08:40 PM | #44 |
ill see what i can do........ |
02-17-2016, 08:53 PM | #45 |
these go to one of the first projects..... 1/8 styrene rod with a 1.6mm hole drilled in it..... then a servo female connector pushed in to it....... any idea what im going to use it for...???? Last edited by roksloski; 06-02-2018 at 09:44 AM. |
02-18-2016, 10:48 AM | #46 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Looks like the male end of an air fitting.....just needs the hose added.
02-18-2016, 10:55 AM | #47 | |
| Re: Sloski's attempt at Styrene Quote:
it will get pushed in till it is almost flush...... it will go with post#6........ Last edited by roksloski; 02-18-2016 at 10:58 AM. | |
02-18-2016, 11:00 AM | #48 |
| Re: Sloski's attempt at Styrene |
02-18-2016, 11:04 AM | #49 |
| Re: Sloski's attempt at Styrene little stuff is hard to wittle out........ |
02-18-2016, 02:29 PM | #50 |
| Re: Sloski's attempt at Styrene working on ramps now, and some other stuff.......... |
02-18-2016, 03:24 PM | #51 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
Where are you getting your decals from? They definitely finish off the build.
02-18-2016, 03:49 PM | #52 |
02-18-2016, 08:19 PM | #53 | |
You don't want to know Last edited by THX_138; 02-19-2016 at 09:19 AM. | |
02-18-2016, 08:35 PM | #54 |
| Re: Sloski's attempt at Styrene Bingo....... should work just nicely... drill an 1/8' hole in the welder at the front, and push that whole piece in till i like it..... then the welder cable will get the other servo connector that plug in to that..... your right , but i know any way....... Last edited by roksloski; 02-18-2016 at 09:06 PM. |
02-19-2016, 08:39 AM | #55 |
needs a bit more work and paint..... |
02-19-2016, 09:04 AM | #56 |
Bend a piece of solid 16 gauge wire for the spray tube and a cut down model paint brush for the cleaning tool, and you're ready to go |
02-19-2016, 09:05 AM | #57 |
02-19-2016, 10:38 AM | #58 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Frank better finish his build once he has a full scale garage, there's no excuse if he has all the tools for the job! |
02-19-2016, 12:47 PM | #59 |
dang youd think it was winter and snowed in with all the styrene work youre doing lol. lift looks good - parts washer is nice touch too |
02-19-2016, 01:06 PM | #60 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Wow looking great Mike, a Painting and Styrene guru. What with all of the paint and glue vapors...........someone said "those painters are all weird" Very nice.
Sloski's attempt at Styrene - Similar Threads | ||||
Sloski's simple berg build | roksloski | EnRoute Berg | 293 | 03-08-2019 11:35 AM |
Sloski's CVD's for berg's | roksloski | Axles, Trannys, T-case | 11 | 11-04-2017 05:59 PM |
Sloski's attempt at a scaler | roksloski | Axial SCX-10 | 96 | 07-13-2016 06:51 AM |
