07-21-2016, 10:33 PM | #81 |
Quarry Creeper Join Date: Mar 2007 Location: Who Knows
| Re: Sloski's attempt at Styrene |
07-24-2016, 01:19 PM | #82 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
got a bit more done....... i cut these kinda scale snap-on stickers... thanx for lookin........... Last edited by roksloski; 07-24-2016 at 03:47 PM. |
07-25-2016, 02:57 PM | #83 |
and a little more....... still needs casters.. thanx for lookin ............ |
07-28-2016, 07:54 PM | #84 |
While i'm trying to figure out what to use for castors...... Upper shop cabinets.......... and have to figure out how to hinge them.......... held open with a tooth pick, so ya can see the inside.......... thanx for lookin........... Last edited by roksloski; 07-31-2016 at 08:12 AM. |
07-28-2016, 09:44 PM | #85 |
NICE what ever you figure out for hinges make / get / rob get extra for the blast cab. |
07-29-2016, 07:22 AM | #86 |
Pebble Pounder Join Date: Nov 2015 Location: Gilsum, NH
You are turning out some of the very best stuff I've come across. Learned a lot just from studying your builds. Thanks for posting your work, Mr Roksloski. Partly inspired by you, I recently started messing around with Styrene and bumped into these the other day. With the off chance you're not privy to them, DIY hinges. |
07-29-2016, 09:55 PM | #87 |
| Re: Sloski's attempt at Styrene Quote: Thanx... how would one use those DIY hinges??? |
07-30-2016, 08:33 AM | #88 |
I picked them up here: https://www.youtube.com/watch?v=1iMyDD1nZQc He does a great job explaining how to make and how one could go about using them. My Example: With some playing around I modified one of the designs to fit my personal needs. I needed something to work with a boxed in door for a cubby. It allowed not only swing but lift as well to clear the flooring. The "U" shaped design can also work just like a car door hinge. Giving the door a box to open into or swinging out to clear the side panel, depending how you set it up. Hope that helped a bit and wan't too much. Also, I was wondering how you go about gluing two painted pieces together? Everything I have used seems to wanna strip the paint off in the process. |
07-30-2016, 10:11 AM | #89 |
Hey thank you for that...... 99% of my stuff is painted after it is built... for the other 1% i will scrape the paint off..... like the tool box drawer's, i scrape the paint out of the center where it is going to go.... |
07-30-2016, 11:00 AM | #90 |
You're verdy welcome! I had thought that was the proper way to go about painting but the toolbox did throw me for a loop. Thanks a bunch for clarifying that for me |
07-30-2016, 11:58 AM | #91 |
LOL the 1st tool box i did, i painted it all at once then when dried i painted the silver drawer part....... 2nd one i painted the drawers separately, made painting the silver a lot easier.... thanx again.... off to the store to get supplys to make hinges.... |
07-30-2016, 07:05 PM | #92 |
Ok so here we go....... i made some mock up hinges so i could see how they work and if they will work for my needs........ you throw a cabinet face frame in the mix and, man i was scratching my head........ i Think i got it figured out............. to make it easy on myself, i used the paperclip loops instead of bending my own.. it works... thats all i can say.... next time i need to make them longer........ and a handle......... thanx for lookin............ Last edited by roksloski; 07-30-2016 at 07:07 PM. |
07-31-2016, 06:05 PM | #93 |
Done with the cabinets........ all 4 doors are hinged.........what a PITA....... On to the next projects........ thanx for lookin.... |
07-31-2016, 07:07 PM | #94 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
Your styrene skills are vast and mighty, Sir. Following this thread has been very educational and inspiring. WELL DONE !! Thank you for sharing and explaining. |
07-31-2016, 10:16 PM | #95 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Ok, im here... Hi Mike! |
08-01-2016, 06:59 PM | #96 |
08-01-2016, 08:12 PM | #97 | |
Why, thank you very much........ if there is any questions on this i will try my best to help or explain... next up industrial 3cyl. compressor..... been thinkin tire machine.... Last edited by roksloski; 08-01-2016 at 08:16 PM. | |
08-01-2016, 08:35 PM | #98 |
Start with end cap's and a coupler..... i only used a bit over 1/2 of the coupler epoxyed them all together.......... a little puddy and sanding and you get this........ the Block layed out for the pump housing...... platform for pump and motor its getting there........ Last edited by roksloski; 08-01-2016 at 09:06 PM. |
08-02-2016, 05:41 PM | #99 |
Abit more progress........ To me, this part takes a lot of time, i wittled on the cylinders and housing a bunch of times till i thought they looked ok......... thanx for lookin............ |
08-05-2016, 06:13 PM | #100 |
| Re: Sloski's attempt at Styrene thanx for lookin......... Last edited by roksloski; 08-07-2016 at 10:27 AM. |
Sloski's attempt at Styrene - Similar Threads | ||||
Sloski's simple berg build | roksloski | EnRoute Berg | 293 | 03-08-2019 11:35 AM |
Sloski's CVD's for berg's | roksloski | Axles, Trannys, T-case | 11 | 11-04-2017 05:59 PM |
Sloski's attempt at a scaler | roksloski | Axial SCX-10 | 96 | 07-13-2016 06:51 AM |
