Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Thread: Trailer build
Old 02-10-2018, 04:59 PM   #1
Default Trailer build
Brass stock using self fluxing solder.
For the axle housing I used thin brass sheet wrapped around the bearings then soldered shut. The full length axle is for alignment only and so if things go to plan And there isn't to much slop in the swing arms it will have independent suspension. Bearings, shock and wheels are donated from a HSP piece of rubbish buggy that's stuffed. I have new alloy bead locks coming for my TRX4 so I might used the original wheels and tyres.Hope you like it so far...
https://www.dropbox.com/s/o5klp763uwjiozk/1.jpg?dl=0
https://www.dropbox.com/s/eh9eprzuqhex3o1/2.jpg?dl=0
Davo1966 is offline   Reply With Quote
Trailer build - Similar Threads
Trailer build. toka100 Scale Accessories 4 11-20-2017 04:55 PM
First rc trailer build. snapon boy Scale Accessories 9 10-27-2015 10:00 AM
trailer build timgreen82 1.9 Scale Rigs 4 07-16-2014 12:45 PM
Trailer build pardonmyn00b Scale Accessories 40 09-09-2011 11:00 AM
want to build a trailer roy 2 Scale Accessories 12 08-23-2009 10:41 AM
