Fuel filler neck cap (rock bouncer) Looking for something to use for a fuel neck cap on my bomber fuel cell filler hose. No luck with Google. What are people using on their scale rock rigs? |
Re: Fuel filler neck cap (rock bouncer) I know bilinvic used a GMade scale hub for his if you want a metal filler. I've used one of the fake shock reservoirs that came in the Axial kits. I cut it down and painted it silver. Here's a photo of mine. Sorry, I don't have a close-up photo. You can also see the clear Lexan piece I cut to hold the fuel line in place. https://farm6.staticflickr.com/5565/...88c2249c_b.jpg |
Re: Fuel filler neck cap (rock bouncer) thanks for the idea guys. Rigged something up for the temporary with a cable clip by drilling out where the screw went through, and inserting a shouldered chrome screw into the hose. https://i.imgur.com/hFgQD29h.jpg https://i.imgur.com/DKIEizfh.jpg |
Re: Fuel filler neck cap (rock bouncer) If you had side panels you could use an flush mount axial light pod to create a mount, not sure about a fuel cap |
Re: Fuel filler neck cap (rock bouncer) I have used a air needle for inflating balls. I cut off the needle part and used the part that screws to the air hose. |
Re: Fuel filler neck cap (rock bouncer) I used a few bike shifter cable ends and some tubing. http://www3.telus.net/devenstone/Min...ition=download http://www3.telus.net/devenstone/Min...ition=download |
Re: Fuel filler neck cap (rock bouncer) Did mine with aluminum rod turned down on a mini-lathe. https://uploads.tapatalk-cdn.com/201...dde7b29424.jpg SENT from THE DARK SIDE of THE MOON |
Re: Fuel filler neck cap (rock bouncer) Did my one with an allen screw https://uploads.tapatalk-cdn.com/201...a7314f4ee7.jpghttps://uploads.tapatalk-cdn.com/201...c466d949dc.jpg Verstuurd vanaf mijn SM-A505FN met Tapatalk |
