Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Thread: Light Weight Spare Tyre
Old 01-28-2020, 01:11 AM   #1
Default Light Weight Spare Tyre
Since I've become more friendly with the sewing machine I decided to make a couple of these fake spare tyres for our trucks. Instead of running with a real tyre with the weight of 200 plus grams mounted high we found these to be great to lower the center of gravity since they only wheigh 25 grams each.
They are made of a sewn outer bag in which I put some foam inserts.
I'm still not that comfortable doing needlework but from a distance it looks quite good
https://youtu.be/-XvVKrLFlvM
Esseaux is offline   Reply With Quote
Old 01-28-2020, 06:34 AM   #2
Default Re: Light Weight Spare Tyre
Thank you very much!
Yes, the main reason was to reduce weight and still have that scale look. I could have used lighter fabric and foam but at 25 grams I feel it's ok.
Old 01-28-2020, 09:27 AM   #3
Go Buckeyes!
B-MOW71's Avatar
Great job on the design!
It turned out great! Great idea to keep the weight down!
B-MOW71 is offline   Reply With Quote
Old 01-28-2020, 09:29 AM   #4
Thanks!
At least the weight up top is reduced a lot with it.
Old 01-28-2020, 12:11 PM   #5
Thanks!
This is a one size only and not intended to cover a "real" wheel so there is no need for different sizes. My first thought was to do such a cover but as you say there are so many tyre-sizes available so I can understand Prolines decision to stop making them.
Old 02-02-2020, 09:09 AM   #6
thats a great idea just dont get it wet the foam will suck up much water it will be twice as heavy as a actual tire unless its closed cell foam
ferp420 is offline   Reply With Quote
Old 02-02-2020, 10:14 AM   #7
We stay away from water as much as possible when we are out crawling but using closed cell foam instead of what we use now might be a good idea.
Thanks for the comment
Light Weight Spare Tyre - Similar Threads
Weight of wheel/tyre assemblies IntrepidMercians Axial RR10 Bomber 6 08-14-2018 02:10 PM
Spare tyre cover Zombi Tires and Wheels 0 10-03-2014 06:52 AM
Drilled Light Weight RC4WD Gears vs. Axial Light weight gears. OFFROADRCKOREA Axial XR10 1 12-12-2012 08:10 PM
Light weight spare option CarterFab Tires and Wheels 3 03-31-2012 09:16 AM
