10-04-2020, 09:40 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
| Scale dimple tool
Yes, the easiest way to make a scale dimple.. Using : - 8mm Deep Socket Nut Bit. - 6mm flat countersunk screw. - 6mm drill bit for making hole. - Any size vise needed. Socket nut, screw and drill bit just my preference, you can choose your own favorite size. The cons is the sheet will slightly bend, I still need to figure out to make more flat. deephis |
10-04-2020, 10:36 PM | #2 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Scale dimple tool
Amazing!! Maybe try heat so it only bends at the simple? Soften it up? Maye thicker sheet too? I really like this technique! The dimples on the enduro sliders always make me with they were real. |
10-05-2020, 12:46 AM | #3 |
I did similar on a bumper I made a year or 2 ago, but instead of using a socket, I made a counter sunk hole in a piece of wood as 1/2 of the die with a 6mm countersunk bolt being the other 1/2. All you have to do then is put a nut on the bolt and tighten it down to form the dimple. It still distorts a bit, but even using machined dimple dies in a hydraulic press, my 1/4" plate distorted a little... nothing the press (or in the case of the thin materials used in rc, a ball peen hammer) couldn't handle. Works on lexan too!
10-06-2020, 06:54 PM | #4 | ||
| Re: Scale dimple tool Quote:
It can be straighten out by bend here and there, it's more work but not much. I haven't tried with heat but it sounds interesting. Quote:
Scale dimple tool - Similar Threads | ||||
Scale bolt tool | Turtlejon | Tires and Wheels | 5 | 12-22-2014 12:52 AM |
Simple dimple | jeepinkid83 | Scale Accessories | 6 | 10-14-2011 08:40 AM |
HP/ ROVER WHITE/ROCK dimple | yoda4rock | Tires and Wheels | 5 | 03-28-2010 06:51 AM |
Scale tool box | Mechanicalbob | Scale Accessories | 3 | 06-02-2009 05:13 AM |
Dimple Die's? | area51caraudio | Tools, and Procedures | 14 | 11-06-2008 02:29 PM |
