01-07-2011, 07:37 PM | #81 |
Tint the windows if you don't want to use an interior. Hidden just means you can't see it.
01-07-2011, 07:57 PM | #82 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| It didn't shoot down anything, just made you have to do a little more work. Nothing a little bit of painted lexan or styrene can't fix. If you don't want to take the time to hide things, then just have doors or an enclosed cab .
01-07-2011, 10:41 PM | #83 |
I wanna be Dave Join Date: May 2006 Location: akron
01-07-2011, 11:22 PM | #84 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| me too! Covering up the electronics is not a hard thing to do, and an interior is a lot of work and we know that not everyone is capable of pulling that off. but it's not unreasonable to ask of someone to at least hide the Trans and motor on an open cab truck. even if its a flat piece of plastic painted black that sits between the door windows |
01-07-2011, 11:29 PM | #85 | |
01-07-2011, 11:35 PM | #86 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Just measured the Hummer Buggy, and it's 4.5" tall... damn. If I add a roof light bar to the top, does that count toward the 5" (it would be welded/brazed on the roof, and part of the structure of the tube)? |
01-08-2011, 12:19 AM | #87 | |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Not sure that would work for your though. | |
01-08-2011, 08:59 AM | #88 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Although integrated to a roll bar/cage, it's added on and not part of the main structure. It's actually scored differently too (roof top light bar -1). I'd see what you can do about lowering the skid. Maybe use something like an SCX10 kid that drop down a bit? | |
01-08-2011, 09:07 AM | #89 | |
01-08-2011, 09:09 AM | #90 | |
I'm sure I am not the only one in this boat, but rules are rules. | |
01-08-2011, 09:46 AM | #91 | |
Bumpers are scored different in class 2 but are used as a measuring point.. Maybe we need to clarify this section a little better. | |
01-08-2011, 10:30 AM | #92 | |
I was also looking at XR10 skids, but not sure they give the 1/2" that I need... will probably just make my own though. Rules: Quote:
The wording "tallest point on the body" makes me think that an integrated light bar would count, but I would think that it should only be counted if it were welded/brazed on (if it can be removed, the vehicle becomes out of spec when it is removed... right?) Clarification on this might bring some borderline rigs back into spec, or help someone get into spec by adding in the roof bar. C2 rigs are measured to the top of the cage, and if that just happens to be the top of the light bar, it's in spec, so why not allow it for C3 rigs too? Also wanted to clarify that even though chassis like the Xtrail and Cross Canyon are two plates of material that happen to be mounted vertically with a skid and cross braces, they don't count as a TVP, and thus are legal, because of the ladder-style braces? This rule is intended to prevent comp chassis with frame extensions from being used right? What about someone that makes their own chassis out of flat plate material, but still resembles the shape of a 1:1 ladder frame chassis? Last edited by monkeyracer; 01-08-2011 at 10:33 AM. | |
01-08-2011, 10:37 AM | #93 | ||
Rock Crawler Join Date: Oct 2007 Location: North Empire
01-08-2011, 12:12 PM | #94 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Eric113: on the point of interiors. I agree it's not everyones cup of tea. For example I bet its probably hard to hide a summit tranny in a ttc tuber, but why not run a "2d" interior like what is in a dingo body? Aside from that I have a few questions about the rules. Is there really a maximum size? For example can you run something that is closer to 1/8 scale as long as you meet all the requirements? On suspension: Is it kind of a free for all. Can you run all types like forced articulation, air shock, droop and winch on axle? I really like the scale points and the option for multi axle builds. I think rules like these encourage people to build and modify even if its a little bit instead of just taking a truck out of the box and running it. |
01-08-2011, 01:19 PM | #95 | |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
| Comments in Green Quote:
01-08-2011, 06:44 PM | #96 |
Quarry Creeper Join Date: Feb 2009 Location: maple valley, WA
Are scale points awarded for leaf springs "per axle"?
01-08-2011, 06:53 PM | #97 |
Pebble Pounder Join Date: Oct 2006 Location: Maple Valley
Great job on the rules guy's.I'm looking foward to the new builds that come out as a direct result of the changes. One question I do have is about the 50% fender rule in class 2.What about the JK bodies where the front fender is more of a flare than a fender and many guys have cut them off.are they eligal rigs now?I also run a mostley fenderless TJ in 1.9 class right now,with some small tube like fenders.You see alot of 1:1 rigs like this running the trailes here in the PNW.Are those eligal rigs now also?It just seems like a problem with jeep bodies.Most other bodies are pretty cut and dry when it comes to 50% of the fenders. Thanks again for all the hard work on these rules fellas. Last edited by Craig cw; 01-09-2011 at 12:37 AM. |
01-08-2011, 07:00 PM | #98 | |
| Suspension/Drive train/Steering: ‐Leaf springs (front/rear): ‐3 ea, ‐7 both. Quote:
Picture helps. | |
01-08-2011, 07:10 PM | #99 |
I don't see a max stated, if you have a 6x6 or 8x8 wouldn't you get nor points for the leafs on each axle?
01-08-2011, 07:23 PM | #100 |
For some reason I Knew You would be the first person to respond to this post Keven.lol.Here is a pic of mt little TJ. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/scale-comp-rules/290744-sorrca-competition-rules-release-class-specs-scale-points.html | ||||
Official new scale rules 2011 - Nostr Forums | This thread | Refback | 10-07-2011 06:20 AM |
