![]() | #21 | |
| ![]() Quote:
We are getting into "intent" vs. "wording". Sometimes, "What you say vs. what you meant" create other issues. I will "guess" the question raised in this thread fulfills the "intent" of the rules but NOT the "wording". In my mind, I don't give a rats butt where the motor is mounted, since it goes through the other bits BEFORE going to an axle it fulfills the "intent" of the rules. The "intent" (in my eyes) is to prevent mounting a motor on an axle AND DRIVING that axle and somehow also driving the other axle. I am not on the rules commitee, so I have NO final say. | |
![]() | #22 | |
Old guy ![]() Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
| ![]() Quote:
![]() | #23 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I don't see the issue as what the motor is doing, I see it as sprung VS. unsprung weight. Scale to me is about all that weight located on the chassis, not on the axles, which is why batteries were not allowed to be mounted on the axle. |
![]() | #24 |
![]() | #25 | |
SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: Cedar Park
| ![]() Quote:
![]() | #26 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| ![]() or did they not want the batteries to be seen. I don't think weight is the issue. You can add as much weight as you want to an axle and be within the rules.
![]() | #27 |
Rock Crawler ![]() Join Date: Nov 2010 Location: the 'burgh'
C'mon guys, what is the problem or issuue here?! We all know that this is not the MOA that was meant to be kept out of the scale world! It's starting to sound like a bunch of lawyers speaking legalese crap! ![]() The man has his motor/tranny going to a t-case and a drive shafts to the fr. & rr. axles, sounds good to me! I mean some don't even incorperate a t-case on their builds! Judist Preist!....this should be a non-issue. ![]() |
![]() | #28 |
Show us a 1:1 set up like this. I like the band Judist Preist........... |
![]() | #29 | |
| ![]() Quote:
![]() Just for giggles, the description of following link describes a 4wd MOA buggy(golf cart) http://www.brushcountrybadboybuggies..._Boy_Buggy.htm So, would a scale version of this be legal becuase it's done in 1:1? No, becuase it is MOA and can act as a dig setup. Would it be scale? Yes. Last edited by skid; 04-17-2011 at 01:15 PM. | |
![]() | #30 | |
| ![]() Quote:
I will be one of the events following SORCCA rules. I just talking out loud, not trying to start a fight. ![]() Still would like to see a 1:1 MOTOA (MOTOR ON TRANNY ON AXLE) SET UP. ![]() | |
![]() | #31 |
Were did I put that popcorn. ![]() |
![]() | #32 | |
| ![]() Quote:
It's a motor, on an axle. The rules are pretty clear. I don't see it passing tech at the Nats. Even at a local event I'd make you put the battery on the roof, or something. | |
![]() | #33 |
![]() | #34 | |
| ![]() Quote:
I do believe the biggest reduction in torque twist on a comp MOA is the direction of motor rotation doesn't have to turn a 90. Except for a losi MOA, which is reduced by a 20 something to 1 gear reduction in the axle and worm drive. As for the O.P., he will still have symtoms of torque twist exerted from the rear axle. Last edited by skid; 04-17-2011 at 07:52 PM. | |
![]() | #35 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| ![]() Thank you. For the rest thanks for the input weather it helps the decision or not. I honestly don't think it's going to prevent torque twist at all because the power to the axles is still coming from the center of the chassis. My goal is to keep the weight off the springs cause they are weak and sagging from the weight of the chassis alone. Pretty sure after the body, electronics, and tube work it's gonna bottom out and act as full droop. Using the mrc axles doesn't give me any room for shocks to add springs to help the issue either. I'm just trying to keep the motor weight off the springs. The way I understood the rule was to prevent moa axles that remove torque twist and run independantly of each other. |
![]() | #36 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
ami the only one seeing a tone of logistical problems with this set up? you will have all three drive shafts constantly moving when on that rocks no one else see's any problems there?
![]() | #37 |
![]() | #38 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Official response... Although the truck design is unique and not the traditional MOA design, by the letter of the rules it would not be legal. We are reveiwing the rules for next year though.
![]() | #39 | |
| ![]() Quote:
![]() Now that is out of the way, technical question for the masses. Would this setup actually reduce torque twist, not change it or make it worse? I start thinking about it, and for the motor to tranfer power, the motor housing is pushing against the axle housing, through the links to the chassis, then to the axles. I invision the chassis/ tcase as kind of a worn out carrier bearing now. Just it is supported by shocks now. Depending on rotation of the motor versus axle drivelines, I' think this could make things worse if they spin the same rotation, or better if they oppose direction? | |
![]() | #40 |
Quarry Creeper Join Date: May 2009 Location: melbourne/palm bay
can i chime in? flip the bracket over and its motor on leaf spring ![]() either way....Nice Project! Last edited by rybredd; 04-23-2011 at 10:29 PM. |
