10-15-2016, 03:20 PM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| CC01 transfer case points?
So does a Tamiya CC01 get transfercase points? It looks like a married style to me.
10-16-2016, 01:11 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
| Re: CC01 transfer case points?
If the scx10-2 gets the points then the cc01 should too.
10-16-2016, 01:46 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
It doesn't really have a traditional transfer case. It has a case with one output to the rear axle and a bunch of gears built into the chassis that drive the front IFS. Not exactly a transfer case so unless someone can show me a 1:1 rig with something like that, no t-case points.
10-16-2016, 11:33 PM | #4 |
Almost every single modern FWD passenger car with a transverse mounted engine that has a AWD version of the model. Including Honda cr-v, Toyota rav4, Nissan x-trail and many others. Last edited by Scrap; 10-16-2016 at 11:48 PM. Reason: Because I'm worth it. |
10-17-2016, 08:45 AM | #5 | |
| Re: CC01 transfer case points? Quote:
Really? Last edited by War Pig; 10-17-2016 at 10:09 AM. | |
10-17-2016, 11:33 AM | #6 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
Not exactly the same, but they are in effect a transaxle with gears going directly from the engine/motor to the front output similar to the CC, and with a transfercase bolted on to the side/rear.
10-17-2016, 01:59 PM | #7 |
Show me a real 4x4 on which a humongous electric motor is bolted to the side of the transmission that is married to the transfercase and mounted backwards. Forgot the Landrover Freelander from that list. Usually the transfercase is part of the same molding that houses the front differential. The power to the rear wheels is taken from the front differential. There is usually a clutch pack at the front or rear differential that activates when the front wheels lose traction. |
10-17-2016, 05:42 PM | #8 |
You're asking for extra scale points for something that doesn't exist in the 1:1 world. You don't get scale points for an electric motor. It's not even close to the transmission/transfer case on the new SCX-2. The answer is no.
CC01 transfer case points? - Similar Threads | ||||
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case | Crawln Coles | Scale Accessories | 215 | 02-02-2009 03:31 PM |
transfer case | Bronco | Chit Chat | 4 | 12-20-2006 04:29 PM |
