01-11-2017, 04:53 AM | #81 |
Newbie Join Date: May 2015 Location: italia
| Re: 2017 Scale Rules
- hello! a question: these are still valid? 2015 scale rules discussion or question thead 2015 scale rules discussion or question thead 2015 scale rules discussion or question thead 2015 scale rules discussion or question thead thanks for your answer . Last edited by (marzo); 01-11-2017 at 07:14 AM. |
01-11-2017, 09:27 AM | #82 | |
Quarry Creeper Join Date: Nov 2005 Location: Italy
| Re: 2017 Scale Rules Quote:
A normal production white abs vacuumed body which starts as 060 sheet will not meet the overall finished product required thickness due to material stretching. We have had the same question in our local forum too Cheers | |
01-11-2017, 11:29 AM | #83 |
Quarry Creeper Join Date: May 2012 Location: Italy
| Re: 2017 Scale Rules |
01-13-2017, 05:10 AM | #84 |
Newbie Join Date: Jan 2017 Location: Italy
Hi guy. is it legal? https://www.youtube.com/watch?v=2ax_z4QpFvo https://www.youtube.com/watch?v=ZzvzRvctHoI the caliper brake like real one is bolt at the axle. this is one of the Championship Award 2016 (Liguria's sorrca championship) (Consegna premi campionato S.O.R.R.C.A. Liguria 2016 - Scalers & Crawlers) can our pilots mount legal this in 2017? thks for your great work! Last edited by devilman_76; 01-13-2017 at 05:18 AM. |
01-13-2017, 08:16 AM | #85 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
The disc brake rotors would be fine, but under the current rules you could not use the calipers that mount to the knuckle.
01-13-2017, 09:59 AM | #86 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
So basically wraith knucles are illegal because the steering arm is bolted to the knuckle and it has weight. Nice. |
01-13-2017, 10:43 AM | #87 |
Moderator Join Date: Jan 2004 Location: chicago
if those things were legal, i guarantee people would start making 'scale' brass caliper mounts that weigh 2oz on each end.
01-13-2017, 12:15 PM | #88 |
| Re: 2017 Scale Rules So basically no, a steering arm isn't illegal since a knuckle is worthless without the arm. A steering arm isn't weight, it's an essential part of the knuckle. Please don't try and cause trouble.
01-13-2017, 12:37 PM | #89 |
01-13-2017, 01:12 PM | #90 |
| Re: 2017 Scale Rules is it causing trouble to ask if i can use a aluminum tub from an rc10 for a tub-based veedub build? |
01-13-2017, 02:18 PM | #91 | |
Why do the rules limit the width of a spare tyre? Diameter I understand but why width? Maybe the spare could be scored like this: -1 if there is more than 1/4" difference to the drive tyres -2 if the difference is 1/4" or less -3 if the spare tyre is the same as the drive tyres | |
01-13-2017, 02:54 PM | #92 | |
01-14-2017, 10:22 AM | #93 |
Hi guy. Something about rock slider.. This is standard type: https://goo.gl/images/pbIXdQ But hiden type like this for discovery https://goo.gl/images/3SjYTc Can be payed? |
01-14-2017, 02:06 PM | #94 | |
01-17-2017, 12:27 PM | #95 |
Quarry Creeper Join Date: Aug 2015 Location: Ontario
You knew this was coming... So I take it when the rules say a "human" figure they mean a lifelike human, no skeletons, monsters, Freddie Krugers, nothing other than a plan Jane (or john)person? Sent from my SM-G935V using Tapatalk |
01-17-2017, 01:26 PM | #96 | ||
RCC Addict Join Date: May 2015 Location: Price Twp.
01-17-2017, 06:52 PM | #97 |
i was asking just because i was brainstorming on how to get to a hardbody out of a lexan body i think is cool. it didnt take long to realize it would be harder to strip styrene onto a body than it would be to just make one based off the lexan measurements.
01-17-2017, 07:45 PM | #98 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
Tin foil coated lexan body for the win. Pure Genius! |
01-17-2017, 09:31 PM | #99 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
First tumble or rock scrape and you'd be out of spec. Not sure about genius. |
01-18-2017, 07:55 AM | #100 | ||
You could go even further and simple hydro form baking tin over a mold, then glue it to the lexan. The point of mentioning it is that unless there is a "formula spec" there are always ways around rules. Back in the day we ran hard body slot cars, then resin bodies where allowed, then someone got the bright idea to add micro balloons to the resin. The there where fragile bodies that weighed a fraction of the stock bodies. Eventually everyone ran the same dam body, that would crumble in your hand if you weren't careful. For the record I could never drive well enough to gain any advantage trying any of that, and wouldn't bother. Id rather do some modeling and do up a nice store bought hardbody. On that note, would a fiberglass body be allowable? I could see using the inside of a lexan body as a mold for a hardbody not available. I have some kevlar and carbon fiber mat laying around, in need of a project. Last edited by Ditchrat; 01-18-2017 at 08:17 AM. | ||
2017 Scale Rules - Similar Threads | ||||
2017 rules and next year's scale nats location. ... | distinctive pd | Scale Comp Rules | 2 | 12-02-2016 04:00 PM |
