Pre-tech thread Time to pre-tech your truck here.... Please post a picture or two and any questions you have. Hopefully you can print out this scale point sheet. Fill it out for each truck and bring it with you to the event for quick tech. https://docs.google.com/open?id=0B_E...W5wTHUzMXdYelU SWEET! It worked! (sorry not very tech savvy) |
Re: Pre-tech thread I can't see it without being logged into Google Tim. I have a Google account so it's no big deal, but others may not so just a heads up. |
Re: Pre-tech thread Same here, no can see and no have google account. |
Re: Pre-tech thread It's telling me I need permission from you to view the file |
Re: Pre-tech thread Sorry guys, I'll see if I can fix it when I get home. |
Re: Pre-tech thread Everyone should have access now. Sorry about that. Please print the scale point sheet out and fill it out for each of your trucks. Let me know if you have any troubles with it. Thanks, Tim. |
Re: Pre-tech thread Got it, thanks Tim! "thumbsup" |
Re: Pre-tech thread What's the minimum points to pass tech? this is my first time at Scale Nats. Bringing a C2 and C3 trucks, thanks! |
Re: Pre-tech thread No minimum mate - run what ya brung. |
Re: Pre-tech thread I'm pretty sure it's 20 points minimum and 60 points maximum. |
WarPig!!!! I can't remember what thread me and hotwheels asked. |
No minimum, 80 max class 1, other 2 are 60 max! Edited to reflect actual requirments |
Re: Pre-tech thread Ah, ok. War Pig said 20 points minimum for TTC so I assumed that was for everything. My bad. |
Re: Pre-tech thread No Min in the C1, C2 and C3 classes C1 max is 80 C2 max is 60 C3 max is 60 |
Re: Pre-tech thread Devlin is right.... |
Re: Pre-tech thread Thanks guys! I will have at least a dozen for sure!"thumbsup" |
Re: Pre-tech thread thanks Tim, all three printed up and filled out. "thumbsup" |
Re: Pre-tech thread All filled out. "thumbsup" |
Re: Pre-tech thread Do i need a scale sheet if im doing king of lucia 2.2????? |
Re: Pre-tech thread Do electronics smoking count as scale points? :x |
