| | #1 |
| RCC Addict ![]() Join Date: Dec 2006 Location: RENO
| Recently in to CKRC is the new Komodo crawler line of kits and parts. Check out the 1.9 and 2.2 scale versions ***HERE*** The 2 trucks currently offered in the Komodo line of vehicles feature common componentry for easy interchangeability and upgradeability as well as ease of adaptability to other vehicles. For example the axles will fit many other vehicles such as the Tamiya High Lift series, Axial AX10, HPI Wheelie King, as well as almost any other vehicle that uses a separate axle design. AXLES The Komodo axles are a realistic looking, strong metal design with solid construction for added weight and durability. They feature a 4 gear differential for maximum strength and power transfer. Also included are locking pins to lock the differential for extra traction when needed. The axle features multiple mounting points that can accommodate leaf springs as well as a multitude of link attachments. At the ends of the axle there are simulated brake drums that can be modified to look like disk brakes. The drive hexes incorporate a set screw that holds them on the axle when wheel is not attached. Full ball bearings are included with each axle. A CNC cut steel ring and pinion gear are the heart of this durable and rigid axle. Like the rest of the parts on these vehicles these axles lend themselves to the custom builder because of their flexibility of installation and extreme quality. CHASSIS The Komodo chassis is a class leading design. The chassis is a sturdy 6061 aluminum ladder frame design that is CNC cut to our rigid specifications. The 6mm thick chassis rails can accept leaf springs as well as virtually any axle and transmission design currently offered for maximum adaptability. There are 3 cross members made of 6mm thick 6061 aluminum. The battery mounting cross member incorporates a proven ventilation slot design for lower battery operating temperatures and longer run times. The other cross members are 6 mm thick for maximum strength. The cross members are secured with countersunk flat head 3mm screws for a clean look and less chance of hang up. There are 5 points to mount shocks to for maximum flexibility. The chassis is 17 1/8 inches long and 3 3/8 wide all holes are 3mm. Our chassis alone is an excellent starting point for any custom built RC scale truck project. TRANSMISSION The Komodo transmission has high strength built in to it. Featuring a 35 tooth pinion gear to an 87 tooth spur the range of pinion gears it can except is unmatched by any similar transmission. It is compatible with many other aftermarket parts. It alone can be an upgrade for other vehicles. It is also an excellent starting point for any custom built RC scale truck project. WHEELS The 1.9 wheel has an aluminum rally style rim with a realistic looking on-road and off-road designed tire. These tires will make any vehicle look more realistic. The 1.9 tire is made of a soft compound that offers high grip in most situations. The rim is a 12mm drive hex for maximum compatibility with other vehicles. Stylish looks and 12 mm compatibility make this wheel an easy bolt on upgrade for any type of vehicle with 12mm drive hexes (touring cars too!) SHOCKS The Komodo shocks have realistic looks. Features include an internal spring, CNC aluminum bodies with aluminum rod ends. They also can be painted for a more custom look. Komodo shocks are offered in a 120mm and 90mm length. The 120mm shock compresses to 85.5mm and the 90mm shock compresses to 70mm. The rod end and shock cap feature a 3mm pivot ball for direct bolt on compatibility with most other vehicles. LINKS The Komodo links are CNC cut from 6061 aluminum and polished to a shine. They are 6.3mm in diameter. Komodo links come in pairs and can be usefully applied to other vehicles. INCLUDES: Komodo 1.9 or 2.2 scale truck, 2-ch radio, 27T motor, ESC, and free lexan body REQUIRES: Radio Batteries: ( Battery: 7.2V 6-cell stick pack with standard connector Charger: AC/DC timed or peak for 6-cell battery Misc. Items: Building and track equipment ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ ___________________ Komodo axles $119.99 pr The Komodo axles are a realistic looking, string metal design with solid construction for added weight and durability. They feature 4 gear differential for maximum strength and power transfer. Also included are locking pins to lock the differential for extra traction when needed. The axle features multiple mounting points that can accommodate leaf springs as well as a multitude of link attachments. At the ends of the axle there are simulated brake drums that can be modified to look like disk brakes. The drive hexes incorporate a set screw that holds them on the axle when wheel is not attached. Full ball bearings are included with each axle. A CNC cut steel ring and pinion gear are the heart of this durable and rigid axle. Like the rest of the parts on these vehicles these axles lend themselves to the custom builder because of their flexibility of installation and extreme quality. Includes 1 complete pair of metal axles with steering. ![]() ![]() __________________________________________________ __________________________ Komodo 1.9" aluminum wheels and tires $27.99 pr. The 1.9 wheel has an aluminum rally style rim with a realistic looking off-road designed tire. These tires will make any vehicle look more realistic. The 1.9 tire is made of soft compound that offers high grip in most situations. The rim is a 12mm drive hex for maximum compatibility with other vehicles. Stylish looks and 12mm compatibility make this wheel an easy bolt on upgrade for any type of vehicle with 12mm drive hexes. Includes: Two 1.9 aluminum wheels and tires ![]() __________________________________________________ ________________________ Komodo 2.2 Aluminum Crawler Wheels with tires (4) $89.99 pr The 2.2 wheel is an all aluminum 3 piece beadlocking rim with an aggressive tread designed tire. The all aluminum rim is fully compatible with most 2.2 tires currently available. The 2.2 tire is made of a soft compound that offers high grip in most situations. The wheel also features a 12mm hex drive for easy bolt on compatibility with most other vehicles. Includes: 4 wheels and tires ![]() www.ckrccrawlers.com |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2009 Location: western ny
| Heres some pics of my Komodo scale truck . Its got a 55 turn motor , the tires are Tamiya high lift tires mounted on Thunder Tech Racing beadlock wheels , and the body is a J-Concepts Ford F-150 Raptor . http://s714.photobucket.com/albums/ww150/sb4pro/komodo/ |
| Thread Tools | |
| Display Modes | |
