09-06-2012, 10:45 PM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
| Speedweigand Customs Wraith front shock mounts
Hello I'm looking for a few Wraith test mules, bashers prefered... They come complete with a big silly alum hoodscoop, winch and CMS mounting holes. Work with up to 125mm shocks, same ones I've been running since last year. Delrin and T6 Aluminum mounts will be available shortly by request. In addition you will need... 2 Wraith body screws 1 40mm axial post or the allthread/brakeline equivalent for a tie bar and/or shock mount You will need to cut a large hole in your hood Also the stinger reinforcements will need cut or new ones made **There is no provision for a panhard mount** Rears will be in a few weeks Price TBA Thanks Speed Last edited by Speedweigand; 10-21-2012 at 12:41 AM. |
09-07-2012, 04:28 PM | #2 |
| Re: Speedweigand Customs Wraith front shock mounts
Only 1 set remains of the new style... one set of handmade ones off my Wraith available too Special thanks to the first 4 that jumped on the deal UPDATE Oct 21, 2012 After over a month none of the testers have broken any of shock mounts! One tester, gabehunt has tried particularly hard and destroyed a pile of Axial parts... this is after the first 24hrs! "Hey man, got the mounts in the mail today, and got them installed, they fit great! Only had to sand a little on the parts that slide over the frame. I haven't made a good hood yet, I'm going to make it in 2 pieces then rivet it together. I didn't realize how awesome these were, until I saw all the options built into them, like the servo and cms mounts and all the shock mounting possibilities. I took it out for a 3s bashing session, and they held up awesome, I was extremely rough with it, I managed to destroy both stock diffs!!! But as far as the mounts go, they are awesome. The only thing I would recommend to you for the retail sets is to: 1) Include set screws for the stinger mounts 2) Include a tie bar with shock mounts 3) Pics in the instructions. I am completely happy with these, and would recommend these to anybody with a wraith. Right now I am using the stock shocks FRONT: new SWC front shock mounts stock lower mounting position. REAR: internally limited 12mm and flipped lower mounts. Its setting dead level (maybe a slight rake to the front) with level links. Whenever I can get my ring and pinion fixed, I'm going to get some different shocks to try. Are you going to start doing those sweet rear shock mounts I saw in one of those pics?" There's 5 more pair ready to ship, the engravings nicer and I changed the optional holes a little. These also include the set screws for modding the stinger braces and the 42mm spacer tube for between the towers. Limited lifetime warranty Available in red, blue and yellow by request Last run of "test" models 25$ a pair shipped in the US 1. 2. 3. 4. 5. Thanks Speed Last edited by Speedweigand; 10-21-2012 at 01:08 PM. |
Speedweigand Customs Wraith front shock mounts - Similar Threads | ||||
Worlds first! Speedweigand Customs scale Lexan oil pan | Speedweigand | Axial Wraith | 30 | 03-06-2014 10:47 PM |
Worlds first! Speedweigand Customs scale Lexan oil pan | Speedweigand | Scale parts | 11 | 10-21-2012 12:16 PM |
New GH Front Shock Mounts | GravelDuster | Axial Wraith | 3 | 07-06-2012 11:41 AM |
Front Shock Mounts | Land Crab | Axial Wraith | 7 | 01-27-2012 12:09 PM |
