08-12-2012, 07:05 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Solo Adventure
I went out this morning with nothing in particular in mind other than to test out some recent changes to the rig. Since I was alone I decided it would be good to break out the camera. Figured I should start working on setting up better transitions between clips and also work on my scale driving. I linked some things in the video that were a transitions on the same lines and others were nowhere near each other but had similar lighting or backgrounds. Anyways, let me know what you think. Lonely road - YouTube Last edited by Big Daddy; 08-14-2012 at 02:35 PM. |
08-12-2012, 07:41 PM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: Solo Adventure
Looks good, but what is that grinding noise? Is your gear mesh too tight? Just sounds a bit odd to me.
08-12-2012, 09:05 PM | #3 |
| Re: Solo Adventure
Not sure, gear mesh is fine. I've been chasing the noise but haven't found it yet. I've rebuilt trans and both axles and it still whines.
08-12-2012, 09:50 PM | #4 |
| Re: Solo Adventure
I went through your build thread, was the noise there before the OD gear install? Are you running 32p spur/pinion? My buddy's Wraith and Ridgecrest are rather noisy on 32p.
08-13-2012, 06:40 AM | #5 |
| Re: Solo Adventure
On 48P. Without a pinion on the drivetrain is quite and moves freely. Running an 18 tooth pinion it is pretty quiet and the 16 tooth pinion is noisy. I though the mesh was tight at first so I backed it off and destroyed a spur gear. I shimmed the O/D gear so it runsas it should now too.
Solo Adventure - Similar Threads | ||||
solo blazer beating | greggreg2011 | Scale Videos! | 1 | 06-27-2012 12:47 AM |
Sweet guitar solo | EeePee | Chit Chat | 15 | 05-20-2012 11:00 AM |
Red Solo Cup | RANOVRU | Chit Chat | 26 | 12-29-2011 11:38 AM |
Montana Scale Adventure Club Adventure Series | montana.matt | Montana | 9 | 03-17-2010 09:22 AM |
Dual or Solo Motor? | CrawlinNMuddin | Traxxas Crawlers | 8 | 03-27-2006 09:43 AM |
