04-29-2008, 12:26 PM | #1 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
| 3PM 3-speed Shift possibility
I think I got it figured out but would like some addition verification from you other 3PM owners. I was searching around here and all I could find was 4ws setup, nothing on 3 positions for the 3rd channel. I've got a High Lift coming in the next couple days so I was playing around with one of my 3PMs trying to get a 3 position setup. With just a servo sitting on the bench it looks like it will work for the 3-speed trans with 2nd gear as the default/centered position. There's no reason why it shouldn't work with Dig too. Shifting - Shifting between 3rd and 2nd - just hit the Cond2 Switch Shifting between 1st and 2nd - Use the SW2 switch -SW2 off (against the wheel) / Cond SW off (normal) - Second Gear / Centered servo -SW2 on (away from wheel) / Cond SW off (normal) - First Gear -SW2 off / Cond SW on (LED Blinking) - Third Gear I was using a 27mhz 3PM with a HPI SF-1 servo. I just had that and an AI Runner ESC for power sitting on the bench, hitting buttons until something worked. I started with the 4ws tutorial on here and in the controller's system setting I started with a fresh profile and then I set SW2 to 3C (pg 54) and tuned on the Cond 2 switch (pg 56) from here on out it was more like a monkey with the proverbial football but here's what I came up with. PMX Screens w/ Cond2 off PMX Rt = (LFU) -100 PMX Rt = (RBD) 0 PMX-MS = CH3 PMX-SL = CH3 PMX-MD = on PMX Screens w/ Cond2 On PMX-RT = (LFU) -50 PMX-RT = (RBD) +50 The rest is the same And on the 3rd ch EPA's EPA-3C (LFU) 100% EPA-3C (RBD) 50% I managed to trim the servo throw down to what should be close but I don't have anything to try it on just yet. If anyone comes up with a better config please post it. |
05-01-2008, 04:01 PM | #2 |
The 3PM can shift the Highlift 3 speed trans. Got it installed and shifting. I had to reverse the servo because of how it's mounted and recenter it using the 3ch sub trim but it works fine.
05-21-2008, 06:14 PM | #3 |
Newbie Join Date: May 2008 Location: clifton
| Futaba 3pm Help
Thank You So Much For The Help..!!! I Will Try That Myself And See If I Cant Get It To Work. I Was Trying To Go This Route Rather Than Spending Money On A New Radio. So Thans Again For Your Help.!! Anything New Pops Up Please Let Me Know..!!
05-21-2008, 06:38 PM | #4 |
RCC Addict Join Date: Feb 2005 Location: Guam
Thanks also man! I am getting me another highlift here soon. I was just reading the tutorial last night on the 3PM also and set my 3PM for 4WS |
05-28-2008, 04:28 PM | #5 |
RCC Addict Join Date: Mar 2008 Location: SSF
| Mriswith, this works with the factory thumb button? Or did you install a toggle? Very nice info if it's factory components since I'm ready for dig and don't like the thought of tearing apart a new 3PM. Thanks for the info. |
05-29-2008, 12:44 AM | #6 | |
| Quote:
05-29-2008, 01:04 AM | #7 |
Quarry Creeper Join Date: Jun 2007 Location: Waipahu
Great write-up! I programmed my 3PM according to your instructions for my VF dig and IT WORKS!!! The button on the handle will place the dig in free wheel and the SW switch would operate the 4wd and dig. Thanks! 80. |
05-29-2008, 12:07 PM | #8 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
OH man..... saving this thread to my favorites. so when I do my dig.....soonday Thanks |
06-03-2008, 05:47 PM | #9 | |
Rock Stacker Join Date: Sep 2007 Location: Canada
| Quote:
06-03-2008, 06:11 PM | #10 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
I'm glad I found this thread, I bought a Futaba stick radio for my highlift and I am not really liking it, the throttle/gear shift stick has no return spring which makes it a pain in the ass:-( |
06-03-2008, 08:42 PM | #11 | |
| Quote:
Don't get me wrong there are way better radios than the 3PM but I like all my adjustments in a 2.4 freq for a reasonable price and I'm sick of 27mhz. That and I have 2 of 'em | |
06-03-2008, 09:55 PM | #12 | |
| Quote:
06-04-2008, 07:26 PM | #13 |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
Mriswith, Thanks for posting up that info. I've read the 3pm manual and I couldn't figure it out, so thanks for explaining it. |
06-11-2008, 08:14 PM | #14 |
I wanna be Dave Join Date: Mar 2008 Location: In the Dark Edges of your Mind
Still not working for me. When I try to turn the PMX-MD from off I have "inh" instead of "on". With all other settings as described... Here is what I get. SW2 only switches Ch3 between 100 left trim and 100 right trim. When I hit SW1, it switches to Cond 2, but nothing happens, and if I hit SW2 while in condition 2 it still does the same thing as condition 2 off. So basically I am getting 2 positions and I can't adjust the servo throw. I get about 1/4 inch from one side to the other. I'm about to pull out my hair. Can anyone straighten me out? Thanks |
06-12-2008, 09:32 AM | #15 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I tried to do the 3 position programming last night for my son's VF dig in his GC1. He wanted to try the free wheel option. So I printed out Mriswith's instruction in the first post and went out to the garage with the 3PM FM instruction manual as well. I was able to get it to perform the 3 positions, however I was unable to get it to work properly for me. I was trying to get the 3 position to work this way: SW2 switch off = 4WD SW2 switch on = Free wheel SW2 switch off and 3rd channel button on = Dig That did not work. It would work properly with SW2 switch on and 3rd channel button on, but since we use dig more than free wheel, I don't want to have to go through a special procedure to get into dig. I was hoping to be able to get from 4WD to Dig with one button like it was before I attempted this. Please keep in mind this a 6 year olds comp rig. He knows how to use every part of it and drives well, but I am still trying to keep it as simple as possible. I tried every possible combo last night. I tried switching it to this and still no luck: SW2 switch off = Free wheel SW2 switch on = 4wd drive SW2 switch on + 3rd channel button on = dig No luck. The biggest problem I encountered, was I getting four distinct servo positions. If you did not follow the exact order to engage or disengage, or if you pressed the 3rd channel button out of sequence, the servo moved to a unknown position causing complete disruption. About an hour later, I thought I had it right. So I attached the dig linkage to the servo to begin the final tuning of it. Within minutes the Hitec 645MG servo burned out:-(. I am / was extremely disappointed to say the least. I should have left it the way I had it with a 2 position 3rd channel. I would not recommend this programming for a comp rig or an adolescent. It could be very confusing during a comp and take attention away from your driving line and if you get out of sequence in the 3rd channel operation you could possibly burn up the servo. I think I will be looking into a DX3 with a 3 position switch instead. For a scaler this would be fine like how Mriswith has it. But if you ever engage the 3rd channel button out of sequence it moved the servo to a fourth position. Has anybody else experienced this? Is there something wrong in the way I programmed it? |
06-12-2008, 05:24 PM | #16 |
Never said it was the best radio or that it would be easy to operate, just that I had got it work with 3 positions. And yes if you get the sequence out of wack you get like 4 positions. I would assume that those who have gotten it to work for Dig are switching something like this .. SW2 off / Cond Sw on - dig SW2 off / Cond SW off - freewheel SW2 on / Cond SW off - 4wd Freewheel being the centered servo horn position It's definately not the best solution for a comp, I think I mentioned something about cumbersome too. If you already have one it just happens to save you a few bucks and buy you some time before upgrading to something like the DX3. Milage May Vary. |
06-12-2008, 06:25 PM | #17 | |
| Quote:
07-24-2008, 07:04 AM | #18 |
Newbie Join Date: Jul 2008 Location: philippines
thanks! i was able to make it work on my winch |
07-29-2008, 08:43 PM | #19 |
Newbie Join Date: May 2008 Location: Santa Barbara
Such a great thread!!!!!! it worked for me i had to reverse the servo and adjust the end points to not burn up the servo but could have never done this in a year of triying on my own thaks so much!!!!!!!
08-21-2008, 08:53 PM | #20 |
Newbie Join Date: Aug 2008 Location: Coweta
| Thanks!
Mriswith- You are MUCH SMARTER than I! I spent an hour or so messing around and decided I couldn't make the radio do this. I see you figured it out! Thank you very much. I see its a little long, but much better than buying another radio, as I have only had this one about 1 month! Wife wouldn't be happy at all about another new toy showing up..... THANK YOU VERY MUCH!!!!!!!!!!!!! |
