#21 | ||
That's how I roll!
![]() Join Date: Sep 2008
Before it was in the Berg I ran it on 4S in my converted REVO. Had to pull it out of the REVO because of the heat... Maybe it needs to go back to Castle to be looked at.
__________________
J. B. Team Panther Driver Team RECON Driver WARCRC 09/10 Series 2.2 Class - 2nd WARCRC Comp Committee Member |
| Sponsored Links | |
#22 | |
DECEMBER 31st
![]() Join Date: May 2004
A crawler is a bit different since the gearing is typically low and it's not wide open throttle all the time. Did the time run on 4 cells ruin the ESC or create the heat issue?...Maybe.
__________________
#23 |
![]() Join Date: Oct 2005
If you where running a 1/8th scale brushless with a Mamba max on 4 cells you where well over the limit for that esc....... Thats what the monster is for. Don't bash a product because you couldn't read the directions....
__________________
Kamikaze: 2 Trace: 1 TCSCrawlers.com RC4WD.com MayhemEngineering.com HolmesHobbies.com Rccrawlergraphics.com |
#24 | |
Colorado
![]() Join Date: Nov 2005
Operator error I would have to say. |
#25 |
That's how I roll!
I'm not saying heat was the reason I swapped in a FX-R for my Mamba...
I swapped my Mamba out for the FX-R for motor brake reasons, that was it! I'm not bashing Mambas, I run two of them on my Super and am completely happy with them. And yes, there is a Monster in the REVO now. I could try to defend myself, but why... Live and learn, right?! Not suggesting I know it all! toy4crawlin, sorry for mucking up your thread!
__________________
#26 |
CRAWLED THE BOX
![]() Join Date: Apr 2009
I run the fxr in my comp rig and my scx10, the updated software is definetaly smoother for the throttle. Almost everyone I know is running one! But the new castle sounds pretty sweet!
__________________
NORTHBAY RC CRAWLER'S NOR-CALRCRC HOBBYTOWN CRAWLERS/CONCORD CDW-CHUMP-BERG HATER TIRES
#27 |
Thanks you everyone for your Opinions, feedback , suggestions and such.
How can you update the firmware/software on the FXR ? I really leaning towards FXR because of the direction of Dual ESC's and size and some day I'll build my 6ch 2.4 pistol to run them. I saw a Brushless MOA in the Nationals
__________________
Spektrum DX6i Pistol 1/8 Scale Rock Buggy, MP3 6Watt Stereo Revo-Losi to 1/5 4wd 6s |
#28 |
![]() Join Date: Jan 2008
[QUOTE=toy4crawlin]ooowwh this is toughf to decide.
Wow a first I heard to stick with castle. I love there ESC's and customer support /QUOTE] i dont know if you know this about the holmes hobbies xl-br but it is in a sidewinder case, comes with castle motor wires and and can be programmed with the castle link via castles programming. the xl-br is great. im putting one in my berg right now |
#29 |
well max is 12 cell nimh, or over 12v ish never understood the 3s lipo limit unless it was a programming issue with the lipo cut or such. many on 4s, and have seen them on 8ths with fans
berg very low load on the motor so running 2 and the esc doesnt see the load of both at max. lcc moa, load with worms MM is seeing temps just curious but why did the sidewinder not make the list ? several say they are on 4s with it as well as a option, |
#30 | |
For sidewinder I figure the Tekin and Castle were better, most popular.
__________________
#31 |
just get the holmes hobbies esc and be done. can handle 2-6s lipo, a built in bec with enough power to power a super, great stock drag brake, and can be adjusted with the castle link. what more do you need
#32 | |
What?
![]() Join Date: Feb 2009
Sidewinder is castle. All ya need in a brushed crawler, just poor castle drag brake. Not sure if the new mamba software works in the sidewinder? I'll stick to my fxrs until I go 5s.
__________________
HR Axles, KK zero 4.0, Big bore shocks, 45t, dual fxr, jr 8711, lipo 3s, DNA assassns front, CKRC skinny rears, rovers, 4pk NEEDS A DRIVER RECON Sacramento Chapter |
#33 | |
Is the updates done by castle ? if so I'm sure Castle is working on it. ? If all of these ESC's Mamba, FXR and Holmes-castle are firmware upgradeable then the drag's can be improved so then it's just a matter of size and the bec right ? Last edited by toy4crawlin; 11-02-2009 at 02:14 PM. |
#34 | |
What?
I also have no idea how much the drag brake can be improved with software. I do know castle has taken a couple years to change their software for crawling so I wouldn't hold my breath for the next one.
__________________
#35 |
DECEMBER 31st
From the runs I've made with my new Holmes ESC....it does feels better/stronger than my Max as far as drag brake. Not needing a BEC is an awesome feature. Less junk to worry about and saves space in small chassis's. I like the fact that I can put the ESC in dang near any RC car and run just about ANY brushed set up I want.
__________________
#36 | |
#37 |
My overview of what I am hearing and read here:
Holmes- Torque master ESC $98. no complaints no need for BEC. 6volt 5amp. Has been on the market for (unknown months) Tunable via castle link-PC handles 2s- 6s lipo Drag brake is said to be better than Mamba max Castle- Mamba Max $115. Well known reliable company Great customer service internet access firmware updates. Very reliable Runs both Brushed or Brushless Some say Drag brake not as strong as FXR Some say Drag brake improved with new beta update. Some say smoother throttle than FXR. Tekin- FXR $97. Great small size no need for PC to program, but best to properly tune via Hot wire ($30.) Said to have better Drag brake than Mamba x. Some have had failures. Once it has been tuned it's a great ESC. Unknown: if Hot wire-028 or 029 is needed to properly tune for crawling or has updates ? |
#38 |
Could John Holmes Chime in and tell us why he is running dual Fxr's and not his Torque master XL ESC ?
or it that an old setup Please tell us more about the features and function of the new Trq master thanks Last edited by toy4crawlin; 11-03-2009 at 12:38 PM. |
#39 | |
DECEMBER 31st
One thing,the Holmes ESC has felt like it's got a stronger drag brake for me compared to my Mamba Max. That may or may not be because I've not updated my Mamba Max with the latest firmware. Come to think of it,I've not updated that particular Mamba Max in almost 2 years.
__________________
#40 | |
owner, Holmes Hobbies LLC
![]() Join Date: Nov 2004
I swapped to dual TM esc's actually, I was tired of the wiring nest with the BECs and such. Just don't update my threads often. Currently the feature list is short- 25v max, onboard switchmode BEC, Castle link compatible Software list is short at the moment- low voltage cutoff, drag brake adjust Future firmware features will include a hold brake, some different modes, throttle and brake profiles, and maybe a few more features if you want them. I basically wanted a simple, light, and reliable controller for crawling duty. It can be put into an emaxx if you wanted. I hit up Castle to be included in their Castle link. They don't control the updates, but they will roll future firmware upgrades into their Castle link.
__________________
www.HolmesHobbies.com
Your Source for High Power Electronics Have a Question? Ask it here in the largest Q@A thread on RCC Team RCC Sponsor midwestrcc.com Team Futaba |
| Thread Tools | |
| Display Modes | |
