RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread Tools Display Modes
Old 10-15-2009, 08:04 PM   #1
rik
Question PTI no more???
Hello all, first let me say that this is my first time posting in a forum. So if this is posted wrong or whatever, I apologize. I have two questions. #1. Is PTI out of business? I ordered a spur gear 2 months ago for my GRC12 and still have yet to receive it! I have tried to call the # listed on ptiracing .net, but to no avail. I have also sent them numerous email's but still have not received even one reply. #2 Is there an alternate spur gear i can use in this rig? I am a CNC machinist so modifying another spur gear is no problem at all. Any help in this matter would be greatly appreciated. Thank you for taking the time to read this post. Crawl on ppl!
rik is offline   Reply With Quote
Old 10-15-2009, 08:17 PM   #2
K_B
K_B's Avatar
There is nothing special about the spur. It's just a basic 48p gear. Many others will fit. I believe the stock one is actually a Kimbrough brand spur:
http://www3.towerhobbies.com/cgi-bin...B%3E+gears+48p
But others work as well. I've used Robinson "stealth" spur gears before:
http://www3.towerhobbies.com/cgi-bin...=robinson+spur
The trick is to make sure it has the holes for the outdrives to key into, make sure the tooth-count is correct and make sure it's 48 pitch.
As for PTI still being in business, I have no idea.
__________________
www.907rc.com
K_B is offline   Reply With Quote
Old 10-20-2009, 05:46 PM   #3
rik
K_B, Thanks for the reply! Much Appreciated. I believe you are correct about the Kimbrough being the stock one. Looks like it to me. Did you have to modify the Robinson "stealth" spur or was it just a "bolt and go" deal? thanks again
Old 10-21-2009, 11:00 AM   #4
fordtoys88
you can use a team associated 48p spur gear also. there the excate same thing. i keep stripping mine out so i use a aluminum one from a kyosho rock force. had to bore out the pin holes ever so slightly but is works.
fordtoys88 is offline   Reply With Quote
Old 10-22-2009, 02:52 PM   #5
K_B
K_B's Avatar
The Stealth is a direct fit. I would recommend the Kimbroughs if you can get 'em. The Stealths are designed for low rotating mass and are milled out significantly. They tend to tweak under stress and strip. They're also kinda spendy.
The trick to keeping the spur from stripping is to support the motor. Fab up a crossmember of some kind to put between the framerails to help hold the motor up. That will keep the motor plate from flexing and screwing up your gear mesh. I think zipties strapped across the framerails would work.
__________________
www.907rc.com
Old 10-25-2009, 10:12 PM   #6
Natedog
Originally Posted by K_B View Post
The Stealth is a direct fit. I would recommend the Kimbroughs if you can get 'em. The Stealths are designed for low rotating mass and are milled out significantly. They tend to tweak under stress and strip. They're also kinda spendy...
X2, Kimbrough is much better under high load such as a crawler. No idea about PTI in or out of businesss...
__________________
The Savage Nation
Brushed motor powah>
Natedog is offline   Reply With Quote
Old 10-26-2009, 10:39 AM   #7
KRAWLR4life
From what I heard, PTI is kinda done (for now) but I also heard they were gonna still try to help support their customers with whatever parts they had left in inventory.
__________________
TEAM RCP CRAWLERS
TEAM KILLER VINYL
TEAM K4L
www.SOCALRCRC.org
KRAWLR4life is offline   Reply With Quote
Old 10-26-2009, 01:53 PM   #8
NaZ-T
Yeah I figured it was just a matter of time before the official "out of business" popped up. I've had a pending order from them sense Febuary
Any one know where I can get a couple of PTI Jeep bodies
__________________
801RCC
crawling forward
$$ T-Money $$
801rcc.com
wvhobbies.com
NaZ-T is offline   Reply With Quote
Old 10-26-2009, 04:06 PM   #9
motorman1600
Cantrelax
motorman1600's Avatar
Default Metal gears are still available
Mike Poulson and I have the metal gears for sale. Fits the PTI axles and the TC3 Diff.
__________________
Bill's Mini Crawler Motors
Hand Wound Mini Crawler Motors
Hand Wound 540 and 550 Motors
Poulson axle metal gears
PTI metal gears
motorman1600@aol.com
motorman1600 is offline   Reply With Quote
Old 10-26-2009, 05:26 PM   #10
Skeeno
XRC Cronie
Skeeno's Avatar
I've got one. How much are they worth?
__________________
Loose = not tight
Lose = misplace, opposite of win
Skeeno is offline   Reply With Quote
Old 10-26-2009, 08:20 PM   #11
jwo
I had to order some parts for mine a while ago.i also emailed but i got a responce, but it took a few day's it took me a month to get my stuff. as of the spur gear. axial ones work to. im running the 87t in mine.i did have to knotch out the bottom plate a tad for it though. plus there are a few different sizes to. just adding to the list of parts. the only thing on mine thats pti is the tranny and axles along with a couple stickers to sport of the pti pride.
jwo is online now   Reply With Quote
Old 10-27-2009, 02:12 PM   #12
NaZ-T
You got PM
__________________
801RCC
crawling forward
$$ T-Money $$
801rcc.com
wvhobbies.com
Old 10-27-2009, 04:46 PM   #13
rik
Smile Thanks!!!!
Wow! Thanks for all the replies! Very much appreciated! You ALL have pointed me in the right direction. A side note to any one wondering about the in or out of business matter.. It does look like PTI is done. I have a claim opened thru pay pal againts them. Ya know, since they had no problem taking my money, but a problem giving me my gears. :( They have had ten days to contact pay-pal and didn't. So i will let all of you do the deductive math. Again, many thanks to all who replied to this thread!
Old 11-01-2009, 07:37 PM   #14
bubbaracing
I eat rocks for lunch!
bubbaracing's Avatar
Great they are folding up? If any of you PTI guys have an extra axle housing you'd be willing to part with please LMK??? Help
Thanks!
Matt
__________________
bubba rocks
bubbaracing is offline   Reply With Quote
Old 11-14-2009, 10:53 AM   #15
ReignMan
I actually called PTI and got a number disconnected recording.I need front diff gears and shock mounts.....
__________________
There Is No Charge For Awesomeness.....
ReignMan is offline   Reply With Quote
Old 11-14-2009, 12:45 PM   #16
K_B
K_B's Avatar
Front diff gears are easy. You can get the ring/pinion set, but you'll have to auger out the hole to fit on the spool, if you're running one. It's a direct fit for the open diff.
http://www3.towerhobbies.com/cgi-bin...&I=LXNZ99&P=ML
Or, you can get just the diff gear that's designed for the spool with a bigger opening.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSG37&P=7
I would suggest getting the metal gears from Mike Poulson on this board. They're a little spendy at around $45/pr, but chances are, you won't strip 'em...
For shock mounts, if you're talking about the little angled pieces that connect to the axle, you'll have to fab those yourself or come up with an alternate mounting method...
__________________
www.907rc.com
Old 11-16-2009, 10:44 AM   #17
ReignMan
Thanks for the Info K B ,This is my First Crawler Rig and I have been disappointed in PTI's Axles thus far,especially when I found that support from the company was no more,I also have a bent dogbone inside the axle housing.Just not having a good experience with PTI.
__________________
Old 11-16-2009, 12:42 PM   #18
K_B
K_B's Avatar
The Goliath was really the first company to market an actual crawler. The problem is that the crawler was based on the MMT which was never really designed to handle the rigors of crawling and when you compare it to what's out now, makes that even more apparent. I had to do some serious modifications to mine to get it crawler capable. Including upgrading the dogbones:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLV96&P=7
Also check out "how do I get more steering?" thread for info on installing CVDs, which would be a worthwhile upgrade if you plan on sticking with the Goliath.
__________________
www.907rc.com
Old 11-17-2009, 07:40 AM   #19
the_ghetto_rig
RUST IS THE NEW BLACK
the_ghetto_rig's Avatar
[QUOTE=ReignMan;,I also have a bent dogbone inside the axle housing.[/QUOTE]
I've got some NIP PTI dogbones for ya...PM me your addy and I'll send 'em to you..
__________________
The harder you try, the dumber you look.
the_ghetto_rig is offline   Reply With Quote
Old Today, 07:06 PM   #20
ASSASSINO
I'm running HPI Super Nitro dogbones on my axles and haven't broken one since 2007. They are slightly large in diameter compared to the PTI units.
Part number: A553
__________________
Machinist and Goliath MMT owner.
ASSASSINO is offline   Reply With Quote
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
