Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Formula Offroad Picture Archive
Old 03-20-2011, 11:42 AM   #1
2006 2.2 National Champ
BENDER's Avatar
Exclamation Formula Offroad Picture Archive
Ok guys, lets get a thread started for pictures of your Formula Offroad builds (aka FOFF). This thread will be a quick/easy reference guide to finding FOFF builds. Post a couple pics of your completed FOFF's in action here with a brief list of the parts used. Please include a link to your build thread as well, so people can find more details on the builds they really like.
This thread is not for questions on the builds, no chit chat please.
For those that don't know what Formula Offroad is. FOFF vehicles are extreme hill climbers. Usually events are held in giant sand pits. There are multiple courses with gates, just like rock crawling. The gates must be cleared in a specific order, and points are awarded for each gate cleared. They usually run multiple gated courses and one timed course, where speed determines the winner.
1:1 FOFF event
BENDER is offline   Reply With Quote
Old 03-20-2011, 11:52 AM   #2
BENDER's Avatar
Here is my SCX10 based FOFF build.
Specs:
Axial SCX10 kit
Futaba 4PK
Futaba S9157 steering servo
Traxxas VXL brushless system
MaxAmps 5250mah 3S lipo
Pro-line Sand Paws - front
Panther paddles - rear
2.2 Axial 8 hole beadlock wheels
Link to build thread:
Formula Offroad SCX10 - Video
Old 03-23-2011, 09:08 PM   #3
Ofna Hyper 10
Novak HV4.5
MMP
CAC beadlocks
Sand Paws
Hyperion 4000mAh 4s
CS-170 servo
Locked diffs
Sleeved shafts
Info Linky
JeepinDoug is offline   Reply With Quote
Old 03-24-2011, 02:32 AM   #4
pnm
Default Foff comp rigs
Here is Koillinen Hiippakunta`s comp rigs for Rc Foff Finland Cup 2011
The good old Pikku-Pastori ( since 2008 ) for modified-class
-custom carbonfiber chassis with HPI Bronco body
-MM+4600 kv , 3s 2500mah 30c & 3s 1050mah 40c lipos
-Savöx servo 12kg
-Axial tranny+ axels, overdrive in front
- 2.2 kg weight
- Panther tires
- more here... http://rc-foff.net/smf/index.php?topic=626.0
Unlimited-class Kanttori (1/8 Truggy, Mugen based)
- Extented alu.chassis , WB 45 cm
-Torsen in centerdiff, open front&rear diffs
-MaxxPaddle tires
-MMM+2200kv, 4-5s 2200-5000mah lipos, 4s 2200mah 40c is mainly used in comp.
-Savöx servo 20kg
-Custom body
-weight 5-6 kg
- more here... http://rc-foff.net/smf/index.php?topic=1235.0
pnm is offline   Reply With Quote
Old 03-24-2011, 07:51 PM   #5
Gotta thank Brad and Sparky J for planting the bug.
Put my little tinker toy together with stuff I had layin around.
Link to build thread;
skid plate's F-OFF
Sure is a blast to run.
Specs;
K2-3S Chassis
Axial axles, transmission and wheels
Shocks-Big Bore XSpede
Mamba Max ESC, Castle BEC
Spektrum RX and Radio
C4 5700kv Motor
JR DS 8611 Servo
Proline Sand Paws Front
Panther Paddles Rear.
Maxx Shafts
A few shots at the playground.......
A couple of body off shots
A couple action shots.
Plenty of good times ahead.
JC
skid plate is offline   Reply With Quote
Old 03-24-2011, 09:21 PM   #6
Did realize this was a crazy that was just starting, but I happened to see Bender's and it inspired me to build one. Just got it Finished. Haven't got any detailed Pics yet but here you go. Will get some better one later.
Chassis is a SCX10
Stock axle servo for now
Mamba Max Pro w/3800kv 4pole motor running 3s
Panther 2.2 paddles on Axial wheels
Tranny has all metal RR gears and Slash 4x4 pinion and Spur
Running the XC-1 Body cause the one I wanted was on backorder.
paulwf150 is offline   Reply With Quote
Old 03-25-2011, 10:24 PM   #7
Default High then LOW
MR.VERTICAL is offline   Reply With Quote
Old 03-26-2011, 07:47 PM   #8
Here's mine
Formula off-road "Wild Wheely"
Morten
SnoopMaxx is offline   Reply With Quote
Old 03-27-2011, 12:03 PM   #9
Default 5700kv HPI Wheely King
chongdigga is offline   Reply With Quote
Old 03-31-2011, 10:17 AM   #10
My fromula offroad racer.
-Axial based
-Proline sandpaw
-Norwegian design chassi
-Castle BL 5700kv
-MambaMax
-3cells lipo
-Over and under drive in axles
-Body is half Tamiya and half r2jspeed outlaw
Some pictures
shortlux is offline   Reply With Quote
Old 03-31-2011, 10:33 AM   #11
Im Brandon
Brandon's Avatar
Build in progress!
Link to build thread: Brandon's Formula Offroad Build
Brandon is offline   Reply With Quote
Old 04-01-2011, 12:06 PM   #12
Hpi mini trophy desert truck
Fuze esc/vxl motor
32p gearing 13/54 (ae v2 spur & slipper pads, omg I have a proper slip!!!)
Rpm wide 2.2s w/ sand paws
Hpi attk w/ slingshots
Older 3906 rear shaft/4x4 slash front shaft
Novak bec
Traxxas 2075 wp servo
Locked font diff/open rear
12.5" wb
Hvrc is offline   Reply With Quote
Old 04-02-2011, 09:07 PM   #13
Allright here is the RuffNeck Crawlers "DRAMA KILLER" just finished Tonight..................................
Bigpopa is offline   Reply With Quote
Old 04-04-2011, 10:38 AM   #14
Spec sheet
Axial Scx10 modded
Futaba 3mx
Traxxas VXL system
Panther paddles f&r, rims Vanquish Pro comp with 850,foams stock modded
Axial axles front Stage 3 locker Vanquish highrise knuckles,overdrive .Rear stage 3 lockers Vanquish lockouts and overdrive.
Axial trans all RRgears and alum trans housing, running gear is 22t,87t.
Shocks Acc. 54mm or 2.5in
Servo Hitec 5995
Body RJ SPEED
Old 04-09-2011, 02:57 PM   #15
suzuki is offline   Reply With Quote
Old 04-14-2011, 11:21 AM   #16
Talking Sand King IV
Old 04-14-2011, 05:36 PM   #17
Here's one of mine...link to thread BWD FOFF build 1 of 2...AX-10 based
Proto BWD "Whiplash" 12.5" WB chassis setup
Traxxas big bore shocks limited to 3.625"
Castle Mamba Max Pro
Castle 1406 4 pole 4600 KV
Hitec 7955
Maxamps 3250 3s
Jato drive shafts
Electric Stampede front wheels
Panther Paddles
50/20 32 pitch
Modded Falsenfest knuckles
CVD's
BW
billet works is offline   Reply With Quote
Old 04-15-2011, 01:03 PM   #18
My other Formula offroad rig
E-Maxx 3906
2" extended WB
Titan 775 motor
Maxx Paddle or swamp dawg
Morten
Old 04-25-2011, 05:08 PM   #19
As usual a build always gettin' tinkered with...
Build thread
BWD Wedge Chassis.
Axial front axle; Al. C's & Knuckles, Axial Comp. Universals, overdrive gears.
Axial rear axle; underdrive gears, VP Razor mounts.
Axial tranny w/slipper, metal gears and RR one piece steel output gear.
MIP driveshafts.
Traxxas 3S VXL System.
Hitec 5645 Servo.
Front shocks; unknown, Rear shocks; Integy MSR11's.
Proline 2.2 Sand Paws on 2.2 Titus Beadlocks.
Robotboy is offline   Reply With Quote
Old 05-05-2011, 09:33 AM   #20
Default heres mine
scx10 panther paddles proline beadlocks cc mm 5700kv motor 2s batt 12 3/4 wheelbase
romperstomper is offline   Reply With Quote
