RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread Tools Display Modes
Old 11-04-2009, 09:51 PM   #21
4xFord
4xFord's Avatar
Originally Posted by Cruzin Illusion View Post
I would love to see video of a single stage set up versus the two stage set up so you can see the difference on how the foam and tire reacts in the same situation.
Hopefully I can put some vids together for the peeps soon.
__________________
Team Black Label Crawlers
Team Crawler Innovations
Team Krawler Hobbies
4xFord is offline   Reply With Quote
Old 11-04-2009, 10:58 PM   #22
toy4crawlin
Toyota Forward Twin Stick
toy4crawlin's Avatar
Needing some inners.
These foams sound great.
what do you guy s have to say about the Proline 2 stage memory foams ?
toy4crawlin is offline   Reply With Quote
Old 11-04-2009, 11:08 PM   #23
miller
miller's Avatar
The reason I did not go with memory foams is because they are temperature sensitive. The last comp I placed 3rd...and I jumped up a few places just because some guys left in their memory foams in for the comp...they turned to rocks and were totally useless.
__________________
09/10 Axial Bully
miller is offline   Reply With Quote
Old 11-04-2009, 11:08 PM   #24
4xFord
4xFord's Avatar
They get hard when its cold outside, and soft when its hot outside. Nova's foams are non memory foam, they stay the exact same no matter how hot or cold.
__________________
Old 11-05-2009, 08:17 AM   #25
swell searcher
learning to crawl again..
swell searcher's Avatar
Originally Posted by Nova's Ark View Post
You need to either trim the width of your inner foams in your Panther Tires or channel the inner foam. If you channel the inner foam where it meets up with the soft outer, it will give you more forward bite. I suggest a 1/4 inch deep channel and I would use either a Dremel with a grinding stone or the round sand paper attachment. If you can't do that, a sharp razor blade will do. Just cut a 1/2 inch wide, 1/4 inch deep V into the foam. If you want the maximum effect out of my foams, tuning is required. It's impossible to make a one size fits all foam for every application. There are way too many variances involved with RC rock crawlers.
any pics of the trimming for us visual sensitive peeps?
__________________
Team RCC Driver * VARCOR OG
swell searcher is offline   Reply With Quote
Old 11-05-2009, 07:27 PM   #26
dbledeuce
DARKSIDE KRAWLER
dbledeuce's Avatar
Swell searcher i agree i would like to see the channeling my self. I would like to see just the inner foam for sell i need 2 more of them. So i can set up different tires.
dbledeuce is offline   Reply With Quote
Old 11-06-2009, 10:04 AM   #27
Nova's Ark
Dream... Think... Create.
Nova's Ark's Avatar
My current schedule does not allow me the time to do that. Maybe I can get a Team Driver to do that for me later. The channeling of the inner foam is no different than what drivers were doing to the Panther F400 foams for use in the Cougars. If you do a search on that you will see many posts and pictures. 4xFord (Shelby) post about making a lite weight Eritex wheel has the centered channeled out which is the same process needed for the firm inner Nova Foam. Just remove some of that inner material in between the firm inner and soft outer if you are looking for more forward bite.
Another thing to consider is that these foam break in after use. Put several battery packs and they soften slightly. I personally don't channel the foams used in my bergs. I am running siped soft compound Rovers and the siping makes the tire so soft any more forward bite would cause trouble. The same goes for my Panther Leopards.
Every truck, every driver, every terrain is unique. I can't account for every variable. I am trying to produce a product that will give competitive drivers an edge and the opportunity to tune them perfectly for them. I have more products in the works. Some of them are currently being tested nationwide and they are designed specifically at making tire foam tuning easier. It took four production runs to get the current 5.5 tall 2.2 dual stage foam where it is. Now that I have some drivers I trust and are helping, I am not going to release new product for sale until it's proven in multiple situations in multiple regions. Slowly everything will come together. I am very hands on and I love rc rock crawling. I want to be an innovator and make the sport grow and draw new people into it by producing products that make it easier for someone with little experience to be competitive. Everyone wants to get the most from whatever RC it is they own.
__________________
- Give 20 people the same chassis & axles, and they'll build a crawler 20 different ways. -
TXRCRCA
Custom tire work & Panther Tire Dealer
2.2, 1.9 & Super Dual Stage non-memory tire foam
Nova's Ark is offline   Reply With Quote
Old 11-08-2009, 01:31 AM   #28
DeweyCJ5
i have the proline 2 stage and they are almost to soft... from watching the video on here and having ran lines like that my pl's would fold under or squish down to almost the rim
DeweyCJ5 is offline   Reply With Quote
Old 11-08-2009, 08:26 PM   #29
toy4crawlin
Super fast shipping, ordered late Wed, got them Sat am just in time for some practice. Great Foams , what a great improvement.
Thank you
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
