#1 |
Making some delrin links for some buddies and me and would like to know how to bend delrin.
pics would be a bonus, any help would be great thanks
__________________
[img]http://www.danasoft.com/sig/SheedysSign382567.jpg[/img] http://www.EWRCRC.com/ |
| Sponsored Links | |
#2 |
Team Up Hill
![]() Join Date: Jul 2009
put it in a vice (soft jaws) heat up the delrin till it starts to bend, it bends its realy easy
__________________
UTH team driver
#3 |
No rest for the Wicked!!!
![]() Join Date: Sep 2008
an adjustable heat gun is your friend..
__________________
Losi-Holmes Hobbies-CheapBatteryPacks Vanquish Products-Crawler InNovations-Panther Rockthrasher R/C Paint&Graphics |
#4 |
SCRC Vice-President
![]() Join Date: Jan 2008
I use a jig (built not bought) so that my links are all bent consistently in terms of angle and placement within the link.
1. Cut Delrin to length. 2. Insert threaded stud (This method of "stud" can vary due to personal preference...I use 4mm threaded rod all the way thru my links.) 3. Insert link into jig and secure. 4. Use heat gun to soften the delrin at the bend location 5. Bend in the jig. 6. let cool for a few seconds before removing from the jig. If you are just building these for yourself, then a jig is just a luxury...and a vise will work fine. BUT, if you are going to be building them more often for pals, or whatever...then a jig is nice. IT allows you to reproduce the SAME link again and again. I started just using the vise....but now the jig is the only way for me.
__________________
"Xirtic" a.k.a. Josh XIRTIC - Remote Control Rock Crawling Products "Team RCSLOT" Suburban Chicago Rock Crawlers BigSquidRC Last edited by xirtic; 11-05-2009 at 07:16 AM. |
#5 |
Addicted to Placebos
![]() Join Date: Mar 2008
Got a pic of that jig?
__________________
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” ~ Dr. Seuss ~ Axial ~ CDW ~ Eritex ~ Holmes Hobbies ~ RPP ~ Wheel Works ~ |
#6 |
SCRC Vice-President
Pardon the poor BlackBerry Camera quality....but these pics show the jig that I use.
__________________
"Xirtic" a.k.a. Josh XIRTIC - Remote Control Rock Crawling Products "Team RCSLOT" Suburban Chicago Rock Crawlers BigSquidRC |
#7 |
You'll have to excuse me for being retarded, but could you lay a link in the jig? I can't quite tell by the pics what exactly is going on there...
__________________
#8 |
SCRC Vice-President
OK....I do not build my Delrin links like 99% of the builders out there. Most people do the following:
1. Buy 5/16" or larger Delrin ROD stock 2. Bend it 3. Drill a hole in the ends 4. Screw in a STUD 5. Put on an end I do this process: 1. Buy 1/4" Delrin TUBE stock 2. Cut to length 3. Upen the Inside Diameter of the tube to accept full length threaded rod stock 4. Push the threaded rod thru the tube 5. Where you see the aluminum angle with the threaded rod in it in the pic...that is where the unbent link gets bolted to the angle. The threaded rod in the pic is just to hold the wing nuts so I do not lose them between link builds. I use a wing nut on each end of the unbent link to hold the link in the jig, as well as keep the delrin from moving around while being bent. 6. Heat the Delrin (with the steel threaded rod inserted in it) at the bend point (The steel round piece to the right of the aluminum angle). That steel round piece is my bend point. 7. Bend until the long (free) end is parallel with the top of the jig. 8. Remove both wing nuts....the link is done. I prefer 1/4" Delrin TUBE stock built this way because: 1. It adds weight LOW. 2. The thinner diameter allows more flexible link placement without hitting gear cases, shocks, ect. 3. The steel all the way thru makes these links next to unbendable under driving/fall conditions. I have seen other delrin links deform over time...these do not. 4. Studs can pull out of the Delrin....these cannot. (The REVO ends are still a weak point) 5. They cannot just crack...I have seen studded links crack under impact at the stud. This was long-winded...but I hope that it helped.
__________________
#9 |
It was the threaded rod with the wingnuts that was throwing me for a loop...lol
I think I'm on the same page now, thanks for the info.
__________________
#10 |
![]() Join Date: Dec 2008
Love the jig...usually heat will bend most anything...lol just watch those temps cuz you could melt your rod!!! lol
__________________
It's just a game and we're all the pawns... |
#11 | |
SCRC Vice-President
I have made probably close to 40 sets of links (minimum) with this jig...I have the process down pretty good. Before this jig...my previous one saw about 30 sets....but it was wood based...and did not survive mass production. On a Saturday of production, I make about 10 sets (4 links) in just about 2 hours.
__________________
#12 |
thanks for the information guys, really helped.
im thinking a jig and a heat gun would do the trick to be consistent. i plant on selling the links if they turn out to be top notch
__________________
[img]http://www.danasoft.com/sig/SheedysSign382567.jpg[/img] http://www.EWRCRC.com/ Last edited by sheedy126; 11-05-2009 at 04:54 PM. |
| Thread Tools | |
| Display Modes | |
