01-10-2008, 06:32 PM | #1 |
Newbie Join Date: Jan 2008 Location: Wilmington
| Droop vs Sprung set ups...
I have a SW3 2.2 with shocks & springs... this I know is a sprung set-up. I am looking to buid up a tuber & have been told to try a droop set-up on it. How does this set-up work & what are the ins & outs of setting it up???? THANX FOR ANY HELP!! |
Sponsored Links | |
01-10-2008, 10:50 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: westminster
the droop involves setting up the suspension so that it does not have up travel it has down travel instead. you put the spring on the inside of the shock under the piston. from what i have heard it is the way to go. but i have yet to try it. it also allows you to articulate out more.
01-11-2008, 07:22 AM | #3 | |
Picky Fab'r/Acetal Junky Join Date: Jul 2006 Location: Arizona Desert/AJ
| Quote:
01-11-2008, 10:35 AM | #4 |
I guess I don't understand how, if the shock has no spring, the suspension works in a droop set up. :? The shock is bottomed out because of the lack of a spring, so what causes the shock to extend out? Do you run the same weight shock oil in both set ups? If I just take off the springs from the shocks-is it now a droop set up??
01-11-2008, 10:50 AM | #5 |
Rock Stacker Join Date: Mar 2005 Location: Louisville
I just finished a tuber, and I run a droop setup in it, but I do not run springs. Rather I control the compression, or decompression, with different weight oil. What I have noticed is that gravity controls the shock, if there is place for it to fall, or extend, then it will. the weight of the car will re-compress the shock once the car levels out or if pressure is applied. Also, you have to be careful of your angles if you are making a tuber, when mine was first finished, the rear end would creep up closer to the from because the suspension angles were a bit off and there was no spring to keep the rear end under the truck. hope this helps, and I am a noob too, so if I am wrong I am sure an admin will correct me. |
01-11-2008, 12:03 PM | #6 |
Newbie Join Date: Dec 2007 Location: Heltonville
So then, do you run thicker oil in the shocks to slow down the travel speed? (so it doesn't just flop from side to side) I can understand what you guys are doing with this set up, I just don't see how it helps, other than lowering the GC. |
01-11-2008, 01:21 PM | #7 | ||
| Quote:
Many people that run droop, do run internal springs UNDER the valve disk inside the shock. This spring is trying to close the shock rather than open the shock as it would on a regular sprung setup. I don't run a spring at all and just regulate the shock movement with the oil weight/thickness and the valve disk inside the shock (more holes in the disk, the faster the oil can pass from one chamber of the shock to the other, and vise versa). Quote:
It helps mainly the center of gravity...and that's a BIG factor. Center of gravity and stability is a huge part of getting your rig to perform. I'd rather drag my belly skid over some rocks and have the tires droop out to meet the ground than having too high a center of gravity and rolling over all the time, just to have more underbelly clearance. IMO, it also gets rid of any bounce you may get when running a spring. Also, you have to realize that even if you're running droop with an internal spring, you are not able to use the full extension of the shock. Now that there is a spring inside the shock under the valve, this keeps the shock from extending all the way cause now the spring is acting as a stop or spacer. You'd have to run a bit longer shock to get the same travel as a shorter one. | ||
01-12-2008, 02:15 PM | #8 |
Newbie Join Date: Feb 2006 Location: Longmont
Post #7 is bad ars!!!! Everything said well. I run a tuber and droop is the way to go. I tried sprung but droop is a lot more stable, conforms better to the rocks to find the perfect bite. I run thin oil, small pistons, soft springs.
01-12-2008, 02:24 PM | #9 |
Newbie Join Date: Aug 2007 Location: Kelowna
Offroad5, what weight Oil are you using?
01-12-2008, 02:32 PM | #10 |
TEAM MODERATOR Join Date: May 2004 Location: Tennessee
Offroader did explain things nicely. In my super,I ran 1000 weight diff oil in my shocks. No internal springs,nothing. In a couple 2.2's I built with a droop set up,even 10 weight oil was TOO THICK. Point is,you gotta set the oil weight to the shocks piston and valving. With a droop rig,weight and shock valving is key to getting it to "flow" smoothly. I like the droop on my super but have gone back to a sprung set up on my 2.2 |
01-12-2008, 06:51 PM | #11 | |
| I have settled on 30 wt. oil. This is with no spring and the stock valve disk in the Proline shocks I am running. Quote:
Just takes some time to tweak it in the beginning is all | |
