#1 |
MSD Scale Nats 2010
![]() Join Date: Aug 2005
The goal of this event is to bring SCALE rigs. This is not a USRCCA pro comp. Please keep that in mind. The 1.9 scale class will be limited to all 1.9" rim sized rigs. - This class is for the typical street legal rigs, that you run off road. aka a daily driver / weekend wheeler, something you would drive to and from the trail. - You may cut down and modify a 2.2 tire to fit a 1.9 rim, you will get a point penalty for this , *see below* - All OEM 1.9" tires are legal, any modified tire can be no larger than 4.4" - Track width can be NO more than 9.5" in the 1.9 class - Flywheels brand wheels, CAC 2.0 wheels, 1/18 scale Nylint brand wheels and tires will be allowed. - You must run a complete body, including bumpers, fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained. - A shortened or lengthened body is allowable. A tubed bed must have a Functional bed area capable of carrying a full-size spare laid flat (rear fender and tailgate rules do not apply to tubed beds). - No 4 wheel steer or rear steer at all ! If you have more than 2 axles, the FRONT axles are the ONLY ones that can steer. - No " DIG " of any kind is allowed. - Wheelbase is limited only by your body, and must fit in your fender wells. - Vehicle must have a frame-railed chassis. Tubed frame rails are ok. - Vehicle battery must be mounted on the chassis. You CANNOT mount the battery above the steering servo/axle/upper links. The goal is to place the battery where it is not visible for a more scale appearance. - Vehicle must run a full approved body. Fenders may be cut, but it must resemble a 1:1 rig you'd see on the street. "Iffy" Vehicles must be approved by the Scale Nationals Committee members. - You may add weight to your wheels, but you are only allowed a maximum of 12 TOTAL oz's. You can put it in whichever wheels you want, but 12 oz is the total. If you feel your rig is borderline, be prepared to modify it if it does not pass tech inspection. AND/ OR bring a BACKUP rig just incase. The 2.2 scale class will be limited to 2.2" rim sized rigs. - This class is for the typical trail rigs, that you have modified quite a bit for off road. You would most likely " TRAILER " these to the trailhead. - All 2.2" OEM tires are legal, any modified tire may only be 5.2" tall - Track width can be NO more than 10.5" in the 2.2 class - You must run a complete body, bumpers, including fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained. - A shortened or lengthened body is allowable. A tubed bed must have a Functional bed area capable of carrying a full-size spare laid flat (rear fender and tailgate rules to not apply to tubed beds). - No 4 wheel steer or rear steer at all! if you have more than 2 axles, the FRONT axles are the ONLY ones that can steer. - No " DIG " of any kind is allowed. - Wheelbase is limited only by your body, and must fit in your fender wells. - Vehicle must have a frame-railed chassis. Tubed frame rails are ok. - Vehicle battery must be mounted on the chassis. You CANNOT mount the battery above the steering servo/axle/upper links. The goal is to place the battery where it is not visible for a more scale appearance. - Vehicle must run a full approved body. Fenders may be cut, but it must resemble a 1:1 rig you'd see on the street. "Iffy" Vehicles must be approved by the Scale National Committee members. - You may add weight to your wheels, but you are only allowed a maximum of 12 TOTAL oz's. You can put it in whichever wheels you want, but 12 oz is the total. If you feel your rig is borderline, be prepared to modify it if it does not pass tech inspection. AND/ OR bring a BACKUP rig just incase. " TUBERS " If you plan to run a tuber in EITHER class, here is what you need to know. It must have a full interior, 2 front seats SIDE BY SIDE, a dash, a steering wheel, a hood panel, a roof panel and a left and right side panel. If it is a jeep, it needs to resemble a jeep. The minimum size for the tubers is as follows: Height 5 " , measured from bottom of skid pan to the roof top Width 5 " , measured from the middle of the door bars, side to side length 14" , this does NOT include bumpers or stingers, just the chassis NOTE: this does not apply if you have a truggy or back halfed truck with a conventional frame and cab. BOTH CLASSES, NO COMP OR TVP CHASSIS, NO FRAME EXTENSIONS TO MAKE IT SCALE EITHER, PERIOD, THIS IS A SCALE EVENT GUYS. There will points deducted for these scale items, these will happen at tech inspection and be deducted from your final TOTAL score at the end of the day. " Max deduct points per rig is 25 " 1. Hard body -5 2. Leaf sprung, 1 axle -2, both axles -5 3. Trailer " must be towed during entire comp " -5 4. Interior -3 , with driver -5 5. Spare tire" Functional " -3 , looks only -1 6. Winch for looks only -1 7. Winch Functional - 3 8. Led's of any kind, must be functional during comp -2 9. Bumpers, front -1 , rear -1, both -3 10. Tube frame, exo cage, tube bed, must be made of METAL -3 11. Roof rack, ladder rack, headache rack, must be made of metal -2 12. Boat or canoe, must be removable -3 13. Un-modded OEM tires -3 , this is for 1.9 and 2.2, modded tires, 1.9 class only +2 , 2.2 modded tires will not be penalized. 14. Chassis mounted steering servo -5 , Axle mounted servo +2 15. Cooler, sleeping bags , tent, camping gear, shovel , axe, hi-lift jack, tools, pick, jerry can, Functional tow strap, d-rings, snatch block -1 " ^^^^ You must have 4 of these items on line 15 to receive a -1, you may add more, but no points will be awarded. " Scoring Points : Reverse +1, you will get 1 free reverse per gate Gate +5 Reposition +10 Rollover +5 Touch +5 Repair +10, " no time limit on repair " you will receive 1 minute added to your time when you return to the course Winching / Rescue , you +2, get help +5 * see below * DNF highest score +20 DNS highest score +50 Winching: - if you use YOUR winch on YOUR truck, +2 - if someone winches you or tow straps you , Rescue +5 Courses: - There will be 4 courses and a finals course for the top 5 finishers. - There will be 6-8 gates and a time limit of approx 8 min on each course.
__________________
E-mail: info@montanascaledesigns.com
MSD Team Captain UTE Chassis Factory Driver All of our parts are made 100% in the USA, yeah, I know, it's rare My FEEDBACK Thread MTRCRC Last edited by Unimoger; 01-05-2009 at 10:09 PM. |
| Sponsored Links | |
#2 |
Kickin it old school
![]() ![]() ![]() Join Date: Jan 2004
Damn so now 2.2 tubers... hmm... now what am I going to bring.
__________________
Team PTFO |
#3 |
MSD Scale Nats 2010
sorry, those are for the 2.2 comp
__________________
MSD Team Captain UTE Chassis Factory Driver All of our parts are made 100% in the USA, yeah, I know, it's rare My FEEDBACK Thread MTRCRC |
#4 | |
I'm Badger
![]() ![]() ![]() Join Date: Mar 2004
Quote:
Also, it would be cool to see bonus points awarded to people running unmodified 1.9" tires, or penalties for those who run modified 1.9's (2.2's cut down to 1.9's). That would discourage the use of running a competition compound tire in a scale class making the class on more of an even playing field and more scale IMO. |
#5 |
Concrete Crawlers!
![]() Join Date: Jun 2005
Well Shit, Guess its back to the BFG's for me
That would discourage the use of running a competition compound tire in a scale class making the class on more of an even playing field and more scale IMO. In the dirt and wet most "comp" tires don't really perform any better than a RC4WD
__________________
ALL_ITEMS_ON_SALE!_CLICKY_HERE MSD Customer Support MTRCRC MSD Team Driver Email aaron@montanascaledesigns.com Last edited by slobin3d; 02-11-2008 at 05:04 PM. |
#6 | ||
Management
![]() Join Date: Apr 2004
Quote:
Quote:
I'm not sure about the 9" wide though, again how strict will this be? My truggy will not look right if it's that narrow I think. Of course I'm not sure either cuz I ain't built it yet.
__________________
Team RCC, Team Holmes Hobbies, TCS Crawlers, MSD Team Driver, Reign RC Pimp Crew Gatekeeper Designs, Ace's Doughnuts, Createacrawler Wheels 2009 CORCC 2nd place-Supers 2009 VP Rocas Rojo 4th place-Supers Last edited by Grizzly4x4; 02-11-2008 at 05:12 PM. |
#7 |
I'm Badger
#8 |
'85 SR5 4Runner
![]() Join Date: Jan 2005
Believe that Ben said the RC4WD tires would be legal... I think he forgot to change the wording though.
#9 | |
Concrete Crawlers!
yes, some comp tires clean out a bit better than the rc4wd but the compound does make much difference when the tires are covered with schmutz
Quote:
__________________
ALL_ITEMS_ON_SALE!_CLICKY_HERE MSD Customer Support MTRCRC MSD Team Driver Email aaron@montanascaledesigns.com |
#10 | |
MSD Scale Nats 2010
Quote:
the un-modded tires is a good idea also, i will change that. thanks foe the idea.
__________________
#11 | |
Concrete Crawlers!
Quote:
__________________
#12 |
'85 SR5 4Runner
4.2 inches mounted on a standard Tamiya rim, I could see the height being lower under the weight of a rig. But a tire should not be measured with weight placed on it.
#13 |
But the most scale 1.9 tire ever seen should also not be disqualified for a fifth of an inch of uncertainty.
#14 |
MSD Scale Nats 2010
Tire issues have been fixed.
__________________
#15 | |
I'm Badger
Next issue.
Quote:
TLT Axles + MSD 1.9 beadlocks + 1.9 rock crushers = 8.5" track width, with CVD's it pushes 9"'s. And that's with fairly narrow wheels as well. Food for thought. |
#16 | |
MSD Scale Nats 2010
Quote:
__________________
#17 |
I'm Badger
#18 |
Management
9.5" and 10.5" sounds much better, thanks Ben. My 1.9 may be running un-narrowed 1.9 Moabs and prolly wouldn't fit the 9" category.
Thanks for being a thorn Badger.
__________________
Team RCC, Team Holmes Hobbies, TCS Crawlers, MSD Team Driver, Reign RC Pimp Crew Gatekeeper Designs, Ace's Doughnuts, Createacrawler Wheels 2009 CORCC 2nd place-Supers 2009 VP Rocas Rojo 4th place-Supers |
#19 |
I'm Badger
#20 | |
Management
Quote:
TLT axles with 2.2 Claws, Junfac beadlocks, and blackfoot stubs comes in at 10.38". TLT axles with un-narrowed 1.9 Moabs, 31mm wide/6mm offset HPI stock car wheels, and blackfoot stubs comes in at 9.38". Measured outside of tire to outside of tire. Seems to me like the width thing is nailed now.
__________________
Team RCC, Team Holmes Hobbies, TCS Crawlers, MSD Team Driver, Reign RC Pimp Crew Gatekeeper Designs, Ace's Doughnuts, Createacrawler Wheels 2009 CORCC 2nd place-Supers 2009 VP Rocas Rojo 4th place-Supers Last edited by Grizzly4x4; 02-12-2008 at 09:30 AM. |
| Thread Tools | |
| Display Modes | |
