RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread Tools Display Modes
Old 03-31-2008, 10:05 AM   #1
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Default Ryan’s FJ40: My BigBaller Buildoff Entry
EDIT: FINISHED PICS ON PAGE 14: http://www.rccrawler.com/forum/showt...12828r&page=14
I was one of the lucky 4 that Ryan picked to build a scaler in his BigBaller Buildoff. Being supplied a whole box of scale goodies and top of the line parts to build a rig is pretty freakin cool
Its going to be a real challenge for me to build a rig that’s comparable to the other 3 builders: Microgoat, Colquit, and 1BadJeepBruiser But I am more than up to the challenge and thought it was a big compliment from Ryan to pick me to build against those guys!
Here is what showed up at my door:
TCS X Trail
Complete TLT kit
All the MSD goodies for the axles
RCP CVD’s up front
Dinky Link out back
R2D2
Pair of 645mg servos
Novak Rooster Crawler and 55t
Proline Bushwacker body
Pair of recaro seats
Wild willy parts tree
5 RC4WD 1.9 Rock Crushers
MSD 1.9 Aluminum beadlocks
MSD Juggster winch
Stainless Steel 3/16 tubing for the cage
Misc 3mm hardware.
Traxxas D Shafts with steel yokes
Traxxas rod ends
I ran across my inspiration for this build when I was searching for a tube bumper for an FJ40 bumper for someone. I found this: http://www.off-roadweb.com/features/..._v8/index.html
That rig immediately reminded me of my original FJ40 Tuber I built over almost 2 years ago http://www.rccrawler.com/forum/showthread.php?t=26095
I had to build another like it! This build for Ryan is the perfect opportunity.
On to the pics!
The inspiration:
Always start off with a clean work space, maybe a redbull or two as well.
__________________
Nor-Calrcrc Forum
Team RCC --- Team Pro-Line Driver --- Axial Driver --- Futaba Driver --- MaxAmps --- Team Tekin
DarkSoul Team Driver
Mayhem Engineering
Holmes Hobbies
Brandon is offline   Reply With Quote
Old 03-31-2008, 10:07 AM   #2
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Time to start on the axles:
First thing to take care of was the cases, took them to the belt sander to finish them.
Locked with the spider gears flipped, also use some threadlock to make sure the diff case never splits.
Got the MSD products ready for installation
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 10:09 AM   #3
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Shimmed the diffs. Traxxas part # TRA1985 works great for this purpose. The ring and pinion will last much longer now, and there is still plenty of room for the e-clip.
Got this little tip from Chino63. The tamiya grease is much more effective when using some WD40 to break it down.
Installed the MSD rear straight axle adapters. Then installed the Dinky Link and TLT link mounts. Always kept the 1:1 example on hand.
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 10:11 AM   #4
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Started on the front axle. MSD C’s, RCP CVD’s and knuckles
Installed the Novak 55t on the R2D2. I have never ran a scaler with dig yet. Actually my comp rig still doesn’t have dig on it This is going to be sweet!
Axles done and I have the TCS X Trail Ready. I love these chassis; this will be my fourth build using one. Bolted up the R2 to determine the skid plate width and servo clearances, as well as a possible bell crank steering setup.
Notice how the holes in the chassis lined up to the R2 perfectly
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 10:20 AM   #5
Jaynen
Looking good. Nice job at planning it out
That r2d looks good in there never thought of using those holes for that.
Jaynen is offline   Reply With Quote
Old 03-31-2008, 10:22 AM   #6
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Thanks. The R2 there might cause issues with the front driveshaft being really short. I figured it will be fine since the front axle will be pushed forward quite a bit anyways.
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 10:43 AM   #7
exesivefire
lIllI!llI!ll
exesivefire's Avatar
Sweet!
__________________
Now taking orders for custom painted lids!
Email XSRChobby@gmail.com
Vendor thread here -->
http://www.rccrawler.com/forum/showt...06#post1912906
MSD Team Driver
Team ASSHOLE
exesivefire is offline   Reply With Quote
Old 03-31-2008, 10:51 AM   #8
AeroSynch
Very nice! I want to see how you mount the TLT axles on that chassis.
__________________
Signature coming soon...
AeroSynch is offline   Reply With Quote
Old 03-31-2008, 10:53 AM   #9
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Quote:
Originally Posted by exesivefire View Post
Sweet!
Thanks
Quote:
It will be very similar to the 1:1. Trying to get everything as close as possible. This build requires a lot of fab'd parts
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 12:44 PM   #10
MoParmonster
Good start, it will look awesome when finished
__________________
Dodge Ram D150 project
http://www.rccrawler.com/forum/showthread.php?t=189750
MoParmonster is offline   Reply With Quote
Old 03-31-2008, 01:44 PM   #11
4RunnerKid
looking sick so far brandon. can't wait to see the finished product.
__________________
-Mikey-
1:1 - 1993 Toyota 4Runner
1.9 - KOH Yota
Polygoats 4WD Club
Poly Performance
4RunnerKid is offline   Reply With Quote
Old 03-31-2008, 02:57 PM   #12
mir4dor
Is this for real ?
mir4dor's Avatar
That's a good find ! Do you add just a drop of it or do you spray much of it ?
mir4dor is offline   Reply With Quote
Old 03-31-2008, 05:11 PM   #13
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Quote:
I just spray the gears with wd40 and add plenty of the white tamiya grease. Works great.
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 03-31-2008, 07:25 PM   #14
zrider
this is goinbg to be a wicked build.
the 1:1 is absolutely sick
zrider is offline   Reply With Quote
Old 03-31-2008, 07:37 PM   #15
RcFanatic92
I like the insparation, I hope it turns out like that, cause thats a awsome build, looks good so far keep it up.
RcFanatic92 is offline   Reply With Quote
Old 03-31-2008, 08:01 PM   #16
NSR_CIVIC
RCC Camera man!
NSR_CIVIC's Avatar
as if your blazer wasnt inspiration enough... lolz im building an fj40 too,,, cept it wont be near as good as this.. looks great!
__________________
NSR Customs
Comp Black Jack 2.2
Super clod tuber.
1.9 yota truggy
NSR_CIVIC is offline   Reply With Quote
Old 04-01-2008, 01:13 AM   #17
Brandon
AKA Nluvwithxlr8ing
Brandon's Avatar
Thanks guys. Here are a few more updates:
Started designing the skid in CAD, this allows me to make the right cuts the first time and not waste any steel. Made the prototype out of paper (Yes I was at work) Then continued to make the final version from steel.
__________________
Nor-Calrcrc Forum
Mayhem Engineering
Holmes Hobbies
Old 04-01-2008, 01:36 AM   #18
pantablo
its all looking amazing, but that steering setup is awesome. whats that part used to mate the linkage from the servo to the knuckle, the part mounted to the front of the chassis rail?
pantablo is offline   Reply With Quote
Old 04-01-2008, 04:07 AM   #19
iwantoffroad
looks good
pantablo
thats is the steering linkage from a highlift.
__________________
OCRCRC
SW2 Comp rig
2.2 Scale Highlift
CR-01 axial plates droop rig
hummer
water proof trail rig
Clod
iwantoffroad is offline   Reply With Quote
Old 04-01-2008, 04:51 AM   #20
guamcrawler
looks good
__________________
trail rig mafia
guamcrawler is offline   Reply With Quote
You may not edit your posts
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
