#1 |
2006 2.2 National Champ
![]() Join Date: Dec 2004
I've been slowly picking away at modding my RTR AX10 into a rock racer. There's a lot of them popping up here in Colorado, so I had to have something to join in on the mayhem with.
Here's a few pics in stock form........ |
| Sponsored Links | |
#2 |
Swagger of a cripple
![]() Join Date: Jul 2004
Location: Sending illegals home one Hayabusa at a time.
.....Subscribed......
Very interested in seeing what you do with it.
__________________
~ TEAM Futaba ~ TEAM Vanquish ~ TEAM TCS ~ TEAM Asshole ~ TEAM MaxAmps ~
I know my PM Box is full! Harley0706@gmail.com www.HarleyDesigns.com |
#3 |
Axial Team Driver
![]() Join Date: Feb 2005
And then?... Thanks for posting pics of your stock RTR axial
JK, I am looking forward to seeing what you do with it as well. |
#4 |
Moderator
![]() Join Date: Feb 2004
Wtf ?Stock pics of axial....unacceptable
#5 |
i remember when mine looked nice and purdy like that, now the bitch is chopped up and modded every week! i should have just bought the kit!
__________________
Sun City Rock Mulisha ***WESTSIDE POWERHOUSE*** |
#6 |
Here's a list of mods I made so far.........
1. Drilled 2 small breather holes in each wheel, and punched one hole on the inner sidewall of all 4 tires. 2. Swapped to a 24t pinion on the motor, which is as big as you can run with the stock spur. The gear mesh was actually a little snug at first. 3. Batteries. Been running a 3 cell 2300mah A123 pack, and a 3 cell 2800mah lithium-ion pack. I also have a 3 cell lipo that I will be trying too. So far stock ESC and motor are holding up fine, but the do get pretty warm. 4. Axial's super soft red springs out front, part #AX30213. 5. Trimmed and lower the body. 6. Added Axial's aluminum shock bodies, part #AX30122. I also limited the travel internally to lower the ride height and articulation a little more. 7. Locked the front axle. 8. Installed Axial's optional front servo/battery plate, part #AX30486. 9. Replaced stock plastic lower rear links with aluminum for strength. 10. Beefed up steering with parts from the optional rear steer kit, part #AX30492. For those that missed it, here's a link to a video of this rig in action before most mods were in place. I will do more videos as I progress with the build. http://youtube.com/watch?v=YEWCLbKgthU A couple pics during/after mods so far........ |
#7 | |||
Quote:
Quote:
Hang in there, more mods are coming. Quote:
#8 |
Great, now Bender is going to make this into a rig that will probably outperform mine even after I have spent 4x's as much. Oh well, money can't do it all (sponsor sure help though, lol). I am eager to see where this goes.
#9 |
Are you runnig the stock Electronics from the Axial? Youa re telling me the stock ESC can handle the Lipo?
Dima |
#10 |
owner, Holmes Hobbies LLC
![]() Join Date: Nov 2004
Can you measure the length of that battery pack?
__________________
www.HolmesHobbies.com
Your Source for High Power Electronics Team RCC Sponsor midwestrcc.com Team Futaba |
#11 |
i too am curious to see what the mysterious mind of bender will do to this poor truck
__________________
QUOTE: "taht thing shud be so fats if u have the rite batery KRO wat battery do u use" |
#12 | |||
Quote:
Quote:
The lipo is 2 5/8" long. Quote:
#13 |
Excellent sir, thank you.
__________________
#14 |
What is the mah on that Lipo? 1290?
__________________
#15 |
It's 1100 mah. It's actually one of my 2.2 comp packs. I need to find something with a little higher discharge rate for this rig.
#16 |
Just a BIT more! 2100 is my recommendation, or you could stack two of those packs in parallel if you have em.
__________________
#17 |
I don't like it.
#19 |
Friend
![]() Join Date: Nov 2005
Great, I have a high dollar comp rig, and I am sure you will beat me with this!!! I need to practice!!!!
__________________
#20 |
![]() Join Date: Nov 2007
Hey guys, As john said using two of the 1100 in parallel would work but I am currently seeing what are manufacuterer can do for us in the smaller cell range with a higher c rating. I'm hoping they can do a 20 or 25C 1100 cell with the same current cell length and width. Thickness will increase with C rating but it shouldn't affect the pack to much. As soon as I can come up with something I will test them out. I have a 27T motor in my X-Trail scaler that I currently run on a 2S 10000 pack or a 25 4200 3S the 3S is nuts. Bender what pinion are you runing in the RTR? I've got my scaler on a 15T.
Jason
__________________
MaxAmps.com Vendor section: http://www.rccrawler.com/maxamps If you have Li-Po or Battery Questions ask away!! www.MaxAmps.com |
| Thread Tools | |
| Display Modes | |
