06-06-2008, 07:55 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
| 55t vs 70t
I'm running a Integy 55t right now at 7.2 volts. I have in my spare parts box an Integy 70t v10. At 7.2 volts which should have more torque? In the meantime I have a 40t Crawl Max coming from JP Custom RC - just so that I can do some more comparison testing . |
Sponsored Links | |
06-06-2008, 08:29 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
higher the turn more torque....lower the turn higher speed.................bob .... |
06-06-2008, 08:33 PM | #3 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Between the 55 and the 70, you probably won't notice any real difference in torque. You should notice a difference in wheelspeed and runtime though.
06-06-2008, 08:40 PM | #4 | ||
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
| Quote:
Quote:
At 7.4 volts the 40 turn will have the most torque, the 55t doesn't max out untill slightly over 12 volts. THe 70t is more than that. In my opinion a 27t or the 35t is the best crawling motor for 7.2 volts. | ||
06-07-2008, 07:04 AM | #5 |
"At 7.4 volts the 40 turn will have the most torque, the 55t doesn't max out untill slightly over 12 volts. THe 70t is more than that. In my opinion a 27t or the 35t is the best crawling motor for 7.2 volts." That's what I was thinking - just looking for confirmation. I guess at 7.2 volts the 70t is a bit of a white elephant. |
06-07-2008, 12:59 PM | #6 |
owner, Holmes Hobbies LLC Join Date: Nov 2004 Location: Volt up! Gear down!
Yes, too low of a voltage for that motor IMO too. The 70t will produce more torque per amp (more efficient torque production, but high voltage must be used to get power back). The 35t will just pull more amps period, and make more power until the batteries give out. Whether you use the power as torque (geardown) or wheelspeed is up to you. |
