Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Loading
Thread: Building a Maxx crawler
Old 07-17-2005, 03:27 AM   #1
Colt Python/SR9c
TwistedCreations's Avatar
Arrow Building a Maxx crawler
As you all know, a Maxx in stock form is not very capable.To turn a Maxx into a capable crawler, you will need to do a few things to it.There is no need to go out and do a complete rebuild just to make it go.
first you can only use 4 shocks( 1 per corner) and stiffen the springs up( due to suspension sag)
Then lock the diffs with either spools(highly suggested),JB weld( not the quick stuff ) or moose doo Does anyone have any photos of a Locked Emaxx Diff
TIP* DO NOT only lock one diff at a time. It will raise havock with your driveline and break axles.
next is to upgrade your steering servo. The stock Traxxas 2055 servo is only 80oz torque and is not up to the task of crawling. Alot of people run Hitec 645mg's with good results.Anything that's 130oz torque and more should work.
Then to save some weight,convert your EVX over to one battery http://www.rccrawler.com/evx.htm
Be sure to also gear down your truck. go with a bigger spur gear(72 tooth) and a smaller pinion( 9 tooth )- make sure both are 32 pitch gears
But with those little things done, you will be able to go more places than you thought.
Now if your ready to fab stuff up and spend more money and make a real crawler,then next section is for you
Lock your Emaxx tranny into first gear
(Tech) How to lock an Emaxx trans into 1st gear
Locking your Tmaxx tranny
Search button creation
Locking out your factory a-arms or build custom axles
(factory a-arm lockouts)- Soya's maxx is going solid.
(custom axles)- Hybrid Straight axle info
(custom axles) - first crawler...prototype Stein Hünd - 6061
(custom axles)- Maxx Crawler started
(custom axles) - New Project Begins!!!
(custom axles) - A complete start to finish Maxx build.
2.2 Builds
TwistedCreations' 2.2 buildup
On The Farm's 2.2 w/ PVC axles
SlowToyota's 2.2 comp crawler
Building a Custom chassis
Tube chassis - http://www.rccrawler.com/tuber.htm
Get more ideas here - Maxx Crawlers Gallery
and here - Members' Rides - No talking
Building your suspension links
http://www.rccrawler.com/customlink.htm
http://www.rccrawler.com/links2.htm
Rod ends
CHEAP METAL ROD END BIBLE
Other things needed for a build
CVD's - http://www2.towerhobbies.com/cgi-bin...&I=LXDXN7&P=ML
Revo driveshafts - http://www2.towerhobbies.com/cgi-bin...&I=LXHFY3&P=ML
Installing Revo shafts - I've seen lots of posts asking about Revo shafts...
Revo knuckle and shafts swap...
CHEAP, MUST HAVE steering upgrade....Check it...
Rear steering - rear steering for maxx
To do the rear steer- you can either get a Y harness with a reverser or get ahold of Kevin at http://www.thecrawlerstore.com/ and get your TQ3 radio modded for independant steering
Installing EPA pots on your TQ3 radio
FritoBandito shows how to install them to help with End Point Adjustments
My Modded TQ3 Update - Added EPA pots
GD600 ( if needed ) - http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML
With running a GD600, you will need to have a motor set to 0* timing and switch the + and - wires or get a reversed motor like Magnetic Mayham motor. Also with buying a Gd600, you will need to have the shaft turned down to 1/8"
Lathe motor - http://integy.automated-shops.com/cg...55105189936.2e ( 0* timing)
http://integy.automated-shops.com/cg...55105189936.2e (adjustable timing)
To find out your final gear ratio - gear ratio help
Top 2 tire choices
(Moabs) http://www2.towerhobbies.com/cgi-bin...&I=LXJGS0&P=ML
(LST's)
Tire listing
**ULTIMATE TIRE SIZE LISTING**
RCCRAWLER tips, cheap tricks / parts guide
RCCRAWLER tips, cheap tricks / parts guide.
So this is just a few things to get you started at building a Maxx crawler.There are so many things to do, this list would go on forever.
I will continue to add helpful tips and tricks to build a Maxx Crawler. If anyone feels something should be added, please feel free to post it up here.All non tech will be deleted
Thanks
TwistedCreations is offline   Reply With Quote
Old 01-07-2006, 08:34 AM   #2
Moderator Rule Breaker
eric113's Avatar
eric113 is offline   Reply With Quote
Old 01-22-2006, 05:13 PM   #3
Free TQ3 independant rear steer mod
!!!! FREE rear steer mod for TQ3 !!!!!
TMXONR is offline   Reply With Quote
Old 02-03-2006, 07:37 PM   #4
eric113's Avatar
mantis chassis
http://www.rccrawler.com/forum/showthread.php?t=15894
Old 09-25-2006, 09:49 PM   #5
Quote:
Whats the best method for doing this? Should I use preload spacers, or different springs? If springs are the way to go, what color/weight do I need?
RivBlueNoma is offline   Reply With Quote
Old 10-23-2006, 06:11 PM   #6
it dosent really matter
my self i use preload spacers
it also depends on your weight
MaXX_CrAWlER7 is offline   Reply With Quote
Old 01-13-2007, 11:36 AM   #7
Whats the purpose of locking out the factory A-Arms? Sorry noobi question but Im trying to figure out which platform I wanna start with, and I like the E-Max. If you lock out the A-Arms then do you still use shocks?
Thanks Everyone
tq_racing is offline   Reply With Quote
Old 01-14-2007, 03:56 PM   #8
the steering links i have seen some that are straight and some that are bent for clearence would like to know how to make the bent ones thanks
usa1man is offline   Reply With Quote
Old 01-14-2007, 05:44 PM   #9
Depending on the amount of bend you need use a brake line bender, or you can use your leg to bend over.
Old 10-31-2007, 12:49 PM   #10
another way to lock out your axles is to make a link to go from the lower a-arm where the shock mounts to the upper hinge pin, this requires you trim some material from the bulkhead and possibly the upper a-arm unless you shape the link to go around it.
here is an example
http://img73.imageshack.us/my.php?im...wler006lp9.jpg
mounted
http://img73.imageshack.us/my.php?im...wler005or9.jpg
in this pic you can also see on the front axle how i did my driveshafts. I put the long female shaft twards the differential and a shortned female shaft twards the hub carrier with a male piece glued to one side in between. it is very strong and i did it with peices that of broken parts i had laying around
spookyseven is offline   Reply With Quote
Old 03-06-2008, 09:41 AM   #11
Default i am a neewbie
what is the standad length for the 2.2 suspension links
matrat is offline   Reply With Quote
Old 07-02-2009, 04:17 PM   #12
what is the cheapest way to turn a emaxx into a crawler i have a stock emaxx laying in my room
dunerdude69 is offline   Reply With Quote
Old 12-17-2009, 09:38 AM   #13
Cool glad to see this still around for I've forgotten about it
I've been hoping that this very tread was still around for i got two Emaxx' that are to become crawler's soon and I'm very thankfull for all the info and great tip's & etc' that ive found in this and other link's that have been posted into this very tread'... Thank's brotha' for all the advice and great tip's and help,...ol'Scoot'er.
scootertrash is offline   Reply With Quote
Old 04-12-2011, 11:42 AM   #14
Hi i know this is randum but i dont know much about traxxax, but i bought the VXL3s water proof esc and motor system, traxxax doesnt recommend it submergining it in water, thats the whole reason i bought it. you see people n u tube doing it and it fine, is it really water proof?? anything i need toi know about it?
im putting it on a scx10 dingo.
Dingotron is offline   Reply With Quote
Old 04-13-2012, 08:23 AM   #15
Default Re: Building a Maxx crawler
hi guys just on a whim i bought some 17 mm whele nuts for a cheep chinese 1/8 scale rc from nitrorcx and thay fit my old
e-max perfect and for $14 + shipping it was a great find and ther mad torque wheels work perfict with thim. here are the part numbers you will need.
Item# 63P-BS936-003
Item# 63P-BS936-002
you will have to order 4 of each pice but its a perfict plug and play change.
gohstwrighter is offline   Reply With Quote
Old 09-08-2012, 02:23 PM   #16
great thread. keep up the good work. i would love to see some videos of one crawling posted up. thanks
DemetriM is offline   Reply With Quote
Old 04-14-2016, 04:55 PM   #17
I joined the Band!
Here
twissted is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/traxxas-crawlers/12386-building-maxx-crawler.html
Posted By For Type Date
E maxx crawler This thread Refback 10-05-2011 02:15 PM
You may not edit your posts
HTML code is Off
