07-25-2005, 01:37 PM | #1 |
Quarry Creeper Join Date: Feb 2004 Location: Mobile AL
| Update 8/10/05!!!
Ok guys, I started the summer off with a Twin Force project, but that was quickly scraped in favor of another clod crawler, out of the 4 crawlers I've had my last clod kicked all there butts, so here we go: I had a good night to start after I got off work at 6pm saturday, so I figured I'd see what I could get done. The chassis is actually 2 RC10GT carbonfiber rear shock towers (lol) so the biggest part was already made for me, so I drew up some quick 4-link mearsurments and started cutting, and here is what I came up with after that night. Let me know what you guys think, Later Jake Last edited by JakeDaSnake; 08-10-2005 at 03:21 PM. Reason: UPDATE |
Sponsored Links | |
07-25-2005, 01:42 PM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
Looks good!!! What time did you finish her?
07-25-2005, 04:25 PM | #3 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
That looks really cool! Keep me posted on the progress of it.
07-25-2005, 05:10 PM | #4 |
owner, Holmes Hobbies LLC Join Date: Nov 2004 Location: Volt up! Gear down!
sweet! premade cheap chassis that looks trick! what is your plan for electronics? |
07-25-2005, 06:24 PM | #5 |
Thanks Guys, yea the shocktowers turned out to be a better chassis than I thought, lol. but I finished up about 12:00a.m. haha long night but it was worth it seeing the truck take shape that quick, ... as for electronics I plan on Lathe motors, Super Rooster, and Hobbico CS-70 servos (unitl I can get some robot servos, lol). I'm gonna try to get some more done tomm. I'll keep you guys posted Later Jake |
07-25-2005, 07:16 PM | #6 |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
that is just AWESOME!!!!!!!!!!!! For someone who can make their own links and spacers, i think that will be one of the easiest, best looking, and good performing chassis.
07-25-2005, 08:13 PM | #7 |
kevinlongisland: Thanks Man! the only hole I drilled is the lower chassis bar and the rest were already there, but you have to enlarge them for 3mm hardware cause Associated is standard 4-40. Im have a problem with the chassis twisting with the suspension anybody got any ideas??? Later Jake |
07-25-2005, 08:26 PM | #8 | |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| Quote:
as i was reading this, i was planning to say something about that, then i got down to the bottom and saw you already noticed it....... build a skidplate that mounts to each cross brace.... or you could triangulate it..... | |
07-25-2005, 08:37 PM | #9 |
| soemthing like that...... |
07-25-2005, 10:20 PM | #10 |
Pebble Pounder Join Date: Apr 2005 Location: Australia
is that hole in the towers big enuff to take a stick pack?
07-25-2005, 10:26 PM | #11 |
it dont look like it..... JakeDaSnake, would you mind if i "borrow" your idea? i was wanting to do the same thing with some LST bulkheads, but i can only find them in aluminum and they are like 40 dollars a piece......the ones you used are like half that.....and you can get fiberglass ones for less than $10 a piece...... |
07-26-2005, 01:08 AM | #12 |
Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
That is a pretty nifty idea. Definitely saves a bunch of time.
07-26-2005, 07:54 AM | #13 | |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
First off, Great job on that! Very innovative thinking there! Quote:
Or have you found some other bolt on rc part to use for the skid? | |
07-26-2005, 08:10 AM | #14 |
Thanks for kind words agian guys, SlammedMini469: yea that was my plan then I decided to go with just 2 titanium turnbuckles to make an "X" right under the upper supports, sure man go ahead and try it! Pullstarter: If you look close at the second pic you can see were I marked with a sharpy what material will need to be removed to use a stick pack. cman_1500w: Im gonna make a skidplate with some "tuf-lack" I found at Home Depot. not really sure how much rigidity that will give it, I might wind up goin with an aluminum. Thanks Agian, Jake |
07-26-2005, 10:09 AM | #15 |
MODERATOR™ Join Date: Jul 2004 Location: Ohio
You wanna know what I think? I think that's a totally cool truck Jake. It doesn't get much easier than that! Pefect for the new guy. Small battery pack on one axle, ESC on the other. The only thing on the chassis is the reciever. |
07-26-2005, 10:13 AM | #16 |
Rock Stacker Join Date: Jul 2005 Location: connecticut
I was thinkin bout tryin that and i have a couple questions. 1.) how much for each shocktower 2.)where did you get them, your LHS? and 3.)where did you buy the appropriate links for the chassis? Thanks chris |
07-26-2005, 10:41 AM | #17 |
Chris, you have the most powerful search engine right in front of you, the computer. Search on Google. http://www2.towerhobbies.com/cgi-bin...?&I=LX3389&P=7 And two ways to make links: http://www.rccrawler.com/tech.htm |
07-26-2005, 10:43 AM | #18 | |
| Quote:
1.) they are like 15 dollars a piece 2.) Tower Hobbies has them 3.) he made his own links im guessing Tower also has fiberglass ones for less than 7 dollars a piece...... i think im going to buy a fiberglass one and use it for a template to make some out of 1/8" aluminum....... | |
07-26-2005, 10:58 AM | #19 |
Yea Chris I got them at my LHS, but I work there so I got them for like 7 bucks for the graphite ones... I made my own links, lowers are fiberglass and uppers are steel brake line (gonna be graphite tubing soon). EeePee: thanks man Later Jake Last edited by JakeDaSnake; 07-26-2005 at 05:02 PM. |
07-26-2005, 05:00 PM | #20 |
| Update: 7/26/05
SlammedMini469: I think the fiberglass ones would work fine, the main reason I got the Graphite is because of looks and the price for me, lol. UPDATE: Chassis Flex is solved. I used the "X" brace idea, and it works flawlessly, I used same Hangar 9 titanium pushrods and GS Racing 5.8mm ball cups and studs. I also moved the 2 upper chassis supports lower right below my upper link mounts, and Im gonna move the upper link mounts up one hole. here are some pics: Later Jake |
Thread Tools | |
Display Modes | |
