RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread Tools Display Modes
Old 12-02-2008, 12:46 PM   #21
JUSTGOINGSLOW
I would move your upper shock mounts to the inside of the chassis, this will line your shocks up a little better. That is a very impressive chassis set-up though.
__________________
venom creeper X
MiRCa
USA
JUSTGOINGSLOW is online now   Reply With Quote
Old 12-02-2008, 02:25 PM   #22
JOOTZ
DIAF
JOOTZ's Avatar
Quote:
Originally Posted by Up and over View Post
What extra hardware did you need to build. My chassis should get here tomorrow and I got a bunch of endlinks. Is that all I need? Do I need anything else. Your build looks good man.
i used traxxas 3mm end links, m3x12 , m3x16, m3 lock nuts and i 3mm tap
Quote:
Originally Posted by slip408 View Post
what is your current wheelbase? Nice looking chassis BTW
look at pics below
Quote:
DNA chassis is 5mm narrower than stock, however i am still using the stock battery and am holding from using the lipo till i hear from JRH about the ESC i am mulling about using i coud maybe inboard the shocks.
when i first installed on this chassis i inbounded the shocks, looking over at the guy thread who comps with the same chassis i just followed suit, same with his advice for shocks to be used.
JOOTZ is offline   Reply With Quote
Old 12-02-2008, 03:02 PM   #23
JOOTZ
DIAF
JOOTZ's Avatar
update on this build, i have since installed the stock electronics and servo, fabbed the long steering link till i get my JSSuper steering links for the 645. moved the shocks to one more hole back and moved the front 4 link to the bottom hole, altitude adjustment is all it is for now.
here is a question for the more experienced here.
1.Tekin FXR is the ESC i have been looking at. DO I NEED THE HOTWIRE ?
2. do i need a BEC, and do i have it programed at the 7.4 volt output of my lipo ? or can i go without, as i said comps will be way down the road as i got bigger fish to fry right now. TIA
Old 12-02-2008, 03:04 PM   #24
JOOTZ
DIAF
JOOTZ's Avatar
and the flex shots...
Old 12-02-2008, 04:10 PM   #25
Tanis
Having FUN!!!
Tanis's Avatar
Go with the Mamba Micro Pro, cheaper and perfect for these trucks, IMO. If you get the FXR, you will need the Hotwire to get all of the programming out of it.
You will need the Castle Link to get all the programming features from the Mamba, but both of them together is the same price as just the FXR.
Oh, BTW, wheelbase means length, not width
__________________
Is 180* of articulation 2 much?
Axial
Cheapbatterypacks.com
Holmes Hobbies
TheCrawlerStore
Retired Vanquish Team Driver
YCC yo!
Tanis is offline   Reply With Quote
Old 12-02-2008, 04:28 PM   #26
JOOTZ
DIAF
JOOTZ's Avatar
thanks for the info on the ESC, gonna look into that. being a car guy i should have known about the wheelbase/LOL, however my doubts were the reason for putting the measuring tape against it. good looking out.
Old 12-02-2008, 04:31 PM   #27
Xtant3150c
Why am I here?
Xtant3150c's Avatar
Man this thing looks "KillahZ"
I think the FX-R would work really good for you. It does'nt seem like you really need the HotWire to get the FX-R to work good in a crawler (although I am sure it will open up more options) I am thinking you also would'nt need a BEC if you use the FX-R.
The Mamba Micro Pro is a nice esc but thinking you may need a BEC with it especially with a Standar Size servo like the 645mg. And a Mamba Link is a must have.
Either way you should be covered, but I think the FX-R is more versatile.
__________________
www.crawlerx.net , www.punkrc.com
R.I.P Gary Ferreira Jr. 9/25/71-8/3/09
You will be missed Brother.
Xtant3150c is offline   Reply With Quote
Old 12-02-2008, 04:35 PM   #28
Tanis
Having FUN!!!
Tanis's Avatar
I am running a 645 on my mamba micro with no BEC, but I am going to install one, just to get 6v to the servo and to handle the 8711 I'm about to install
Either ESC is a good choice really
__________________
Axial
Holmes Hobbies
TheCrawlerStore
YCC yo!
Old 12-02-2008, 04:38 PM   #29
JOOTZ
DIAF
JOOTZ's Avatar
looks like price, adjustability and longetivity would be deciding for the ESC. thank you for the input.
Old 12-02-2008, 11:08 PM   #30
JOOTZ
DIAF
JOOTZ's Avatar
went ahead and ordered the Tekin FXR. switched the axle placement of the links and shocks to fix the shock angle.
Old 12-03-2008, 08:18 AM   #31
Pdog7
E.T.R.C.
Pdog7's Avatar
Talking Get the FXR
I have the fxr on my mini. I am running the ht645 servo and hh torque master mini and 1650 lipo. The fxr has a built in BEC that can handle up to 2c lipo. The fxr also has a programable lipo cutoff built in. I bought the hotwire since I use the fxr in my mini as well as my 2.2. (this thing is awesome). The hotwire give you more adjustability for the settings such as drag brake, reverse type/strength, and lipo cutoff. In my opinion, save your 35 bucks for the hotwire. You get great adjustability from the pit tune mode.
Pdog7 is offline   Reply With Quote
Old 12-03-2008, 10:10 AM   #32
JOOTZ
DIAF
JOOTZ's Avatar
^^^ good to know more about the FXR, pretty sure i made a good decision when i ordered it. thanks bro.
Old 12-03-2008, 10:29 AM   #33
JOOTZ
DIAF
JOOTZ's Avatar
painted bronko body, switched position of shock and link on the axles.
Old 12-03-2008, 10:36 AM   #34
Pdog7
E.T.R.C.
Pdog7's Avatar
Thumbs up
Dude, that Bronko is BFA!!!
Old 12-03-2008, 12:59 PM   #35
Crawl It
Default jootz DNA slingshot
Did you tap the lower link mounts out to 3mm on the axles?
__________________
Losi MRC - Mixer chassis proline flat irons FXR 1.9 pro comps.
Crawl It is offline   Reply With Quote
Old 12-03-2008, 01:16 PM   #36
JOOTZ
DIAF
JOOTZ's Avatar
^^^ didnt tap the axle mounts, i re-used the stock bolts, the recomemded shocks for this chassis is the mini-t rears, fitment is one reason why. handling is much better from the switch.
i would like to get it out there that i learned all this just by going thru this forum and all the threads i found related to what i had in mind, and i would like to give a big SHOUTOUT to rccrawler forums.
as a background on me i`m a car guy, below is link to a vid of what i do with an exclusive mitsubishi evolution club i belong to. i can post pics of my ride when not in competition if you guys are interested.
http://videos.streetfire.net/video/T...ent_203181.htm
Old 12-03-2008, 02:06 PM   #37
JUSTGOINGSLOW
Looking good bud, shock angle is alot better now. And you can never go wrong with a bronco body.
__________________
venom creeper X
MiRCa
USA
Old 12-03-2008, 02:44 PM   #38
210solomon007
ATi
210solomon007's Avatar
Loooking real good Jootz. all the input helps...
__________________
ATi Performance
210solomon007 is offline   Reply With Quote
Old 12-03-2008, 03:32 PM   #39
JOOTZ
DIAF
JOOTZ's Avatar
your post about the shock angle got me wrenching/LOL
Quote:
the most important inputs came from your guys giving me advice on specs i thought i would not be privy to. hats off to DNA staff.
__________________
color-up
Old 12-04-2008, 02:26 PM   #40
JOOTZ
DIAF
JOOTZ's Avatar
got bored waiting for parts so i went to my LHS and picked up a bug body to paint. and slapped on my CAC wheels.
__________________
color-up
You may not edit your posts
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
