RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread Tools Display Modes
Old 12-11-2008, 05:34 PM   #1
carver
carver's Avatar
Default Carver's MThead comp rig
Finally got around to this build, It will be my 2009 series contender. So far I have got a roller, I will be installing the electronics as soon as I get some free time. Some HB Rovers are on there way and will be hitting the rocks soon. Check it out!
Enroute/Berg Axles (Clocked front)
MThead Delrin chassis
Kamikaze Kustoms HC links and steering rod
Rocksmith TI. Upper links and steering linkage
JP Customs Rear lockouts
Revo rodends
Losi 4" Crawler shocks, Grappler
HB Rovers Whites
Mayhem Eng. AL. 7's
Holmes Hobbies 45T Handwound Torque Masters
Tekin FXR
Castle Creations BEC
Hitec Dig switch servo
KOPropo Steering servo
Spectrum DX3R w/Mini RX
Thunder Power 3c 1320mah Lipo
Robinson Racing 12tooth mod .06 pinions
These are awaiting some sweet rubber.
__________________
JP Customs Team Driver
Team Black Label Crawlers
carver is offline   Reply With Quote
Old 12-11-2008, 06:00 PM   #2
dieselfuel
nice looking build so far. you know you have your tie rod installed wrong right? you're supposed to re-drill the knuckles so the tie rod mounts much closer to the axle tubes and gearcase.
__________________
...D.G.F - Crawler Design Works - Mayhem Engineering - RC Axle Master - Trailhound Smokers BBQ...
dieselfuel is offline   Reply With Quote
Old 12-11-2008, 06:08 PM   #3
carver
carver's Avatar
Yeah, I know that. This was much easier to do and I did not want to lose steering angle.
__________________
Old 12-11-2008, 06:27 PM   #4
akguanja
carver, break down and drill it. you can always dig around corners like i do! lol
rigs lookin good man. nice n clean
- tre
__________________
[CENTER][I][COLOR=Lime]2009 AROARA 1.9 Winter Points Series Champion
3rd Place 2.2 - Alaska State RCC Championships[/COLOR][/I]
[URL="http://aroara.org"]AROARA[/URL] RC Crawlers
[URL="http://akrcc.com"]AKRCC[/URL] Team Driver[/CENTER]
akguanja is offline   Reply With Quote
Old 12-11-2008, 06:30 PM   #5
Kamikaze
Kamikaze's Avatar
Quote:
You will actually turn sharper, cause it makes the Ackerman angle better. That's why its wider. Your outside tire will come around farther.
__________________
Kamikaze: 2 Trace: 1
TCSCrawlers.com
RC4WD.com
MayhemEngineering.com
HolmesHobbies.com
Rccrawlergraphics.com
Kamikaze is offline   Reply With Quote
Old 12-11-2008, 06:40 PM   #6
Red Rockcrawler
Go buy a Skeeter
Red Rockcrawler's Avatar
Nice build so far. On mine I filed a angle on the outer edge of the lower link slot on the skid plate. So the lower links dont bind up and can move freely.
__________________
Fubar Crawlers Team Driver
Brians Bodies Team Driver
Team MOO-volution Driver
Vanquish Products
Holmes Hobbies
EWRCRC
Red Rockcrawler is online now   Reply With Quote
Old 12-11-2008, 06:56 PM   #7
carver
carver's Avatar
- tre
Thanks Tre!
Quote:
Thats weird I was looking at raul dukes and, Correct me if i'm wrong dave it looked as if he lost some sterring angle.
[quote=Red Rockcrawler;1470074]Nice build so far. On mine I filed a angle on the outer edge of the lower link slot on the skid plate. So the lower links dont bind up and can move freely.
There was no binding on my rig there. Only were the shock cup meets the lower link does it rub a little but, Not enough to stop articulation.
__________________
Old 12-11-2008, 08:39 PM   #8
JIA's Dad
JIA's Dad's Avatar
I like everything but the oversized rear lockers. Too much drag possibility.
JIA's Dad is online now   Reply With Quote
Old 12-11-2008, 09:57 PM   #9
bigflex
TEAM BWD
bigflex's Avatar
I have my tie rod in further and it has better steering than my sons in the stock location.
__________________
Team BWD Driver
Team Anger Inc. Driver
Team Jwalker Designs Driver
Team Crawler InNOVAtions driver
Holmes Hobbies
TCS
bigflex is offline   Reply With Quote
Old 12-11-2008, 10:03 PM   #10
62 bugzilla
62 bugzilla's Avatar
Default berg
nice comp berg very clean job. Didn't the 2 top guys in the series run bergs aswell. I'm building a 2.2 comp clod to try since I just don't have the money for the bergs right now but wish I did. See ya at the first comp.
62 bugzilla is offline   Reply With Quote
Old 12-11-2008, 10:19 PM   #11
treday619
Moonbuggy Berg
treday619's Avatar
Back to a Berg I see. I guess the shafty wasn't good enough. Nice looking rig.
__________________
Lifestyles of the Poor and Unfortunate....
treday619 is offline   Reply With Quote
Old 12-11-2008, 11:02 PM   #12
bcrofts
TEAM RCC
bcrofts's Avatar
looks sweet i like the chassis
bcrofts is offline   Reply With Quote
Old 12-12-2008, 12:14 AM   #13
Rockcrawler
Waiting on Nats 2010
Quote:
I will know when I get home but I believe that more than half of that will be inside the wheel.
__________________
4th Place Worlds 2009
TEAM TEDROCKZ!
TEAM TCS
jpcustomrcs.com
TEAM VANQUISH
HBJ INC!
Team Crawler InNovations
Brian's Hobbyland
Old 12-12-2008, 12:50 AM   #14
e-hills4x4
Gavyn is my BFFL
e-hills4x4's Avatar
Quote:
exactly, and they are still no larger than the stock knuckle. plus they have no play at all
__________________
TEAM RCCRAWLER - TEAM LOSI - TEAM HOLMES HOBBIES - TEAM MAXAMPS - TEAM VANQUISH PRODUCTS - TEAM RC4WD - TEAM BLC
e-hills4x4 is offline   Reply With Quote
Old 12-12-2008, 12:52 AM   #15
Rockcrawler
Quote:
Now that I am sure about. Very tight fit......and I dont see them wearing out any time soon.
Nice build by the way.
__________________
TEAM TEDROCKZ!
TEAM TCS
jpcustomrcs.com
TEAM VANQUISH
HBJ INC!
Brian's Hobbyland
Old 12-12-2008, 06:20 AM   #16
carver
carver's Avatar
Quote:
Thanks, See you there!
Quote:
Thanks, I am over the shafty. Too much tuning, This rig will be the toughest of them all.
Quote:
Thanks!
Correct. These lockouts are very trick.
__________________
Old 12-12-2008, 07:22 AM   #17
Stormin2u
Incredible Taylors Falls
Stormin2u's Avatar
I've been a MThead fan for some time and your rig is well crafted nice job.
__________________
Team Slow Ass Builder
Stormin2u is offline   Reply With Quote
Old 12-12-2008, 08:55 AM   #18
bullet1231
nice buddy! another competitive rig and looks good at the same time . im wondering why u didnt use mtheads lockers?
__________________
All we are is dust in the wind.....................
bullet1231 is offline   Reply With Quote
Old 12-12-2008, 09:47 AM   #19
PROTOTYPE
Nice build, dont sweat the lockouts i have them and have yet to bust them up. .No drag possibilty unless your in some wicked upside down opsie daisy angle .
What wheels are they ?
__________________
www.crispycrittershobbyshop.com
When competing remember ,
"Don't pull a blinger"
PROTOTYPE is offline   Reply With Quote
Old 12-12-2008, 10:48 AM   #20
dboy1k
THE Y-TOWN OG
dboy1k's Avatar
i use those same lockouts and not once in any situation have i ever even hit them . so that being said keep on keepin on!!!!
dboy1k is offline   Reply With Quote
You may not edit your posts
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
