01-06-2009, 11:07 AM | #1 |
I wanna be Dave Join Date: Aug 2005 Location: G6'N
| * Official Rules for 2009 Scale Nationals * The goal of this event is to bring SCALE rigs. This is not a USRCCA pro comp. Please keep that in mind. The 1.9 scale class will be limited to all 1.9" rim sized rigs. - This class is for the typical street legal rigs, that you run off road. aka a daily driver / weekend wheeler, something you would drive to and from the trail. - You may cut down and modify a 2.2 tire to fit a 1.9 rim, you will get a point penalty for this , *see below* - All OEM 1.9" tires are legal, any modified tire can be no larger than 4.4" - Track width can be NO more than 9.5" in the 1.9 class - Flywheels brand wheels, CAC 2.0 wheels, 1/18 scale Nylint brand wheels and tires will be allowed. - You must run a complete body, including bumpers, fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained, Fenders may be cut, or flat fendered, but it must resemble a 1:1 rig you'd see on the street. If you remove the tailgate, you must have a complete floor and drop bed. If you want to remove your doors, you must run a full interior. "Iffy" Vehicles must be approved by the Scale Nationals Committee members. - A shortened or lengthened body is allowable. A tubed bed must have a Functional bed area capable of carrying a full-size spare laid flat (rear fender and tailgate rules do not apply to tubed beds). - No 4 wheel steer or rear steer at all ! If you have more than 2 axles, the FRONT axles are the ONLY ones that can steer. - No " DIG " of any kind is allowed. - Wheelbase is limited only by your body, and must fit in your fender wells. - Vehicle must have a frame-railed chassis. Tubed frame rails are ok. - Vehicle battery must be mounted on the chassis. You CANNOT mount the battery ON the steering servo/axle/upper links. The goal is to place the battery where it is not visible for a more scale appearance. - You may add weight to your wheels, but you are only allowed a maximum of 12 TOTAL oz's. You can put it in whichever wheels you want, but 12 oz is the total. - You may only run 1 truck in each class, you Cannot run the same truck in both classes. If you feel your rig is borderline, be prepared to modify it if it does not pass tech inspection. AND/ OR bring a BACKUP rig just incase. The 2.2 scale class will be limited to 2.2" rim sized rigs. - This class is for the typical trail rigs, that you have modified quite a bit for off road. You would most likely " TRAILER " these to the trailhead. - All 2.2" OEM tires are legal, any modified tire may only be 5.2" tall - Track width can be NO more than 10.5" in the 2.2 class - You must run a complete body, bumpers, including fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained, Fenders may be cut, or flat fendered, but it must resemble a 1:1 rig you'd see on the street. If you remove the tailgate, you must have a complete floor and drop bed. If you want to remove your doors, you must run a full interior. "Iffy" Vehicles must be approved by the Scale Nationals Committee members. - A shortened or lengthened body is allowable. A tubed bed must have a Functional bed area capable of carrying a full-size spare laid flat (rear fender and tailgate rules to not apply to tubed beds). - No 4 wheel steer or rear steer at all! if you have more than 2 axles, the FRONT axles are the ONLY ones that can steer. - No " DIG " of any kind is allowed. - Wheelbase is limited only by your body, and must fit in your fender wells. - Vehicle must have a frame-railed chassis. Tubed frame rails are ok. - Vehicle battery must be mounted on the chassis. You CANNOT mount the battery ON the steering servo/axle/upper links. The goal is to place the battery where it is not visible for a more scale appearance. - You may add weight to your wheels, but you are only allowed a maximum of 12 TOTAL oz's. You can put it in whichever wheels you want, but 12 oz is the total. - You may only run 1 truck in each class, you Cannot run the same truck in both classes. If you feel your rig is borderline, be prepared to modify it if it does not pass tech inspection. AND/ OR bring a BACKUP rig just incase. " TUBERS " If you plan to run a tuber in EITHER class, here is what you need to know. It must have a full interior, 2 front seats SIDE BY SIDE, a dash, a steering wheel, a hood panel, a roof panel and a left and right side panel. If it is a jeep, it needs to resemble a jeep. The minimum size for the tubers is as follows: Height 5 " , measured from bottom of skid pan to the roof top Width 5 " , measured from the middle of the door bars, side to side length 14" , this does NOT include bumpers or stingers, just the chassis NOTE: this does not apply if you have a truggy or back halfed truck with a conventional frame and cab. BOTH CLASSES, NO COMP OR TVP CHASSIS, NO FRAME EXTENSIONS TO MAKE IT SCALE EITHER, PERIOD. THIS IS A SCALE EVENT GUYS. Example of these chassis are: SWX, J2-TT, GC-2, etc.... also, NO MOA axles in ether class. There will points deducted for these scale items, these will happen at tech inspection and be deducted from your final TOTAL score at the end of the day. " Max deduct points per rig is 25 " 1. Hard body -5 2. Leaf sprung, 1 axle -2, both axles -5 3. Trailer " must be towed during entire comp " -5 4. Interior -3 , with driver -5 5. Spare tire" Functional " -3 , looks only -1 6. Winch for looks only -1 7. Winch Functional - 3 8. Led's of any kind, must be front and rear and functional during comp -2 9. Bumpers, front -1 , rear -1, both -3 10. Tube frame, exo cage, tube bed, must be made of METAL -3 11. Roof rack, ladder rack, headache rack, must be made of metal -2 12. Boat or canoe, must be removable -3 13. Un-modded OEM tires -3 , this is for 1.9 and 2.2, modded tires, 1.9 class only +2 , 2.2 modded tires will not be penalized. 14. Chassis mounted steering servo -5 , Axle mounted servo +2 15. Camping stuff - Cooler, sleeping bags , tent, camping gear, shovel , axe -1 16. Recovery stuff - hi-lift jack, tools, pick, jerry can, Functional tow strap, d-rings, snatch block -1 " ^^^^ You must have 4 of these items on line 15 and or 16 to receive a -1, you may add more, but no points will be awarded. " Scoring Points : Gate progress -1 Reverse +1, you will get 1 free reverse per gate Gate +5 Reposition +10 Rollover +5 Touch +5 Repair +10, " no time limit on repair " you will receive 1 minute added to your time when you return to the course Winching / Rescue , you +2, get help +5 * see below * DNF highest score +20 DNS highest score +50 Winching: - if you use YOUR winch on YOUR truck, +2 - if someone winches you or tow straps you , Rescue +5 Tire Modding: - What we consider a tire mod, narrowing, sectioning, reducing, sanding down, sipping or cutting, putting two styles together. - Any of these things will constitute a " MODDED " tire and will receive the penalty points in the 1.9 class. Courses: - There will be 4 courses and a finals course for the top 5 finishers. - There will be 6-8 gates and a time limit of approx 8 min on each course. Last edited by Unimoger; 04-09-2009 at 10:45 AM. |
Sponsored Links | |
01-06-2009, 03:04 PM | #2 |
I wanna be Dave Join Date: Aug 2005 Location: NE Ohio
Just making sure, LARGE tired 1.9's still good to run in the 2.2 class?
01-06-2009, 03:15 PM | #3 |
01-06-2009, 03:16 PM | #4 |
Sweet! that sucked last year taking a penalty to run a smaller tire |
01-06-2009, 04:46 PM | #5 |
I wanna be Dave Join Date: Feb 2005 Location: Cleveland, OH
Does the tire-mod penalty apply to 1.5's? Or is it only modified treads that get the penalty? Also, what about stock Slash tires/wheels? They have a 2.2 outside, but a 3.0 inside. Legal or no? |
01-06-2009, 04:50 PM | #6 | |
| Quote:
slash tires and wheels are NOT legal, sorry. | |
01-06-2009, 04:53 PM | #7 |
01-06-2009, 05:06 PM | #8 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
| " TUBERS " If you plan to run a tuber in EITHER class, here is what you need to know. It must have a full interior, 2 front seats SIDE BY SIDE, a dash, a steering wheel, a hood panel, a roof panel and a left and right side panel. If it is a jeep, it needs to resemble a jeep. The minimum size for the tubers is as follows: Height 5 " , measured from bottom of skid pan to the roof top Width 5 " , measured from the middle of the door bars, side to side length 14" , this does NOT include bumpers or stingers, just the chassis NOTE: this does not apply if you have a truggy or back halfed truck with a conventional frame and cab. You guys rock. I think i have a trip to plan. |
01-07-2009, 03:07 PM | #9 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Well, crap. 10.5 in max track width restriction knocks out my 2.2. Looks like I'll run 1.9 only. |
01-07-2009, 07:23 PM | #10 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
01-07-2009, 08:29 PM | #11 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
01-07-2009, 11:03 PM | #12 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
01-08-2009, 08:08 PM | #13 |
Quarry Creeper Join Date: Jan 2007 Location: HAY CAPITOL OF THE WORLD!!!!! weeeeeeeeee
is the trackwidth going to be to the center to center or outside to outside?
01-08-2009, 08:19 PM | #14 |
01-11-2009, 11:03 PM | #15 |
What will the gate widths be for each of the classes? Narrower than USRCCA 2.2 gates? I see the 1.9 class as a track width limit of 9.5 inches and the 2.2s are only allowed 10.5 inches. |
01-12-2009, 09:10 AM | #16 |
| gates will be the same as last year, 12" in the 1.9 , 14" in the 2.2.
01-12-2009, 09:58 AM | #17 |
PapaGriz Yo Join Date: Apr 2004 Location: In the garage building the wife a crawler
I think my 1.9er is going to get a set of 4.4" tall tires. That's awesome! I assume the max of 4.25" was changed to 4.4" for a reason.....a new 1.9" tire? |
01-12-2009, 12:03 PM | #18 |
I wanna be Dave Join Date: May 2006 Location: akron
01-12-2009, 05:34 PM | #19 |
01-12-2009, 08:11 PM | #20 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
With reguards to the "roof panel" in the tuber rules; My scaler doesn't have any roof panels at all, neither does the 1:1, just a tube frame over the cab. Am I going to have to just throw some lexan on the roof, or what?
