#1 |
I have been searching the forum about shocks and the angles at which you mount them I found one good post that applies to my situation and wanted more info. here is the link of the post that I found.
I have a new chassis that I built and want to know how to kill the chassis twist. I was wondering if mounting the shocks inward like this O-/---\-O would work to elimintate the chassis from twisting? the O are the tires and the - are the axle the / \ are the shocks. I have noticed that if I push the left or right ( front and rear ) side of the axles towards each other the chassis flops to the opposite side I am applying pressure to. This is what I am trying to fix. Any help would be greatly appreciated!
| Sponsored Links | |
#2 |
2006 2.2 National Champ
![]() Join Date: Dec 2004
The more you stand your shocks up vertically, the more it'll stiffen up your suspension. Same thing applies when laying them down more, your suspension will soften up. Link position plays a big roll too.
Search for "torque twist", it'll yeild a ton of results, there's some good info on the first couple pages. Do you have any pics of your set-up to post? |
#3 | |
Quote:
Call me after you listen to my voice mail.....you homo! |
#4 |
I posted a pic of what I am talking about...
#5 |
Looking at that pic, it looks like the shocks need to be spread apart more. Try to get the lower shock mounts as far out on the axle as possible, then lean the uppers in just so the shocks have a slight angle to them.
Go a pic from the side, are your upper links flat? |
#6 | |
Quote:
I'll call you in a little bit, I'm going in for round two!! |
#7 |
here is a side pic of it. btw I am getting a set of tmaxx shocks for it. I plan on putting 60 wt in them.
#8 |
here are some shots of it when I push the axles towards each other. The first one is normal and the second pic is what the chassis does when I push them towards each other.
![]() This is a shot of it when I push the axles towards each other.
#9 |
#10 |
The Maxx shocks will be better then the stockers for sure, I think 60wt might be too heavy for a TLT. I run 15w in mine with soft Losi springs.
Your link set-up doesn't look bad. Do your axles sway side to side as the suspension cycles? I double triangulated my links and mounted the uppers flat, it's stable, doesn't have any axle steer and almost zero torque twist. There's a bunch of pics of my TLT's link set-up here: http://www.rccrawlermedia.com/rcc-ga...n-Wagon-my-TLT |
#11 |
#12 | |
Quote:
#13 |
Big Brother
![]() Join Date: Sep 2004
re mount your links so you triangulate both upper and lower mounts..
V and ^ ....?make sense? right now you have |V| make the | | = ^ technical.. i know |
#14 | |
Quote:
#15 | |
Quote:
#16 | |
Quote:
#17 |
Kickin it old school
![]() ![]() ![]() Join Date: Jan 2004
or are you this stump?
__________________
Team PTFO |
#18 |
It looks like the frame may be the problem have you tried bracing it like this
http://cbioffroadfab.com/RC/shockmount.jpg |
#19 |
#20 |
Big Brother
bring the upper mounts to the center of the axle... problem solved
| Thread Tools | |
| Display Modes | |
