Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX-10 Scorpion
Loading
Thread: Axial's AX10 Scorpion RTC
Old 04-20-2009, 04:36 PM   #1
2006 2.2 National Champ
BENDER's Avatar
Arrow Axial's AX10 Scorpion RTC
AX90011
AX10 SCORPION RTC (READY-TO-CRAWL)
Based upon the award winning AX10 Scorpion - KIT!
FEATURES
• Complete Ready-to-Crawl (RTC) out of the box
• Full Time 4 Wheel Drive
• Mount a standard stick pack to get up and running quickly, or use the included upper link plate to mount smaller batteries lower in the chassis for improved crawling performance
• 14T pinion paired with an 87T spur gear gives you a decent amount of wheel speed and great low-end torque.
• True beadlocks
• Hi-quality composite plastic and metals
• 55T electric motor
• Durable (ESC) Electronic Speed Controller: Hi-quality forward and reverse speed controller.
• Hi-torque Metal Gear Servo help hold your line when rock crawling
• Solid rear axle lockouts improve ground clearance when crawling
• Slipper clutch: Allows motor to work more efficiently and greatly enhances the durability of the drivetrain.
• Aluminum chassis plates with a molded nylon skid plate provide a solid and rigid chassis
• Full ball bearings
• Overall gear ratio range from 15:1 to 74:1
• Transmission: Ultra compact and lightweight with a 2.6:1 ratio
• Differentials: Locked Front and Rear
• Tires: Pro-Line Hammersฎ with Pro-Lineฎ Memory Foams
• Wheels: Axial 2.2 8 hole satin chrome beadlocks
• Suspension: 3 Link
• Drive Shafts: Universal front and rear
• XC-1 Body included
ALL NEW SHOCKS
• 72-103mm shock length, helps lower the center of gravity
• Threaded shock body for easier pre-load adjustments
• 3.5mm shock shaft reduces lateral movement
• Cartridge style bottom helps reduce lateral movement while providing a better steal for less leakage
• Silicone diaphragm provides more consistent feel and better seal to prevent leakage
• Silicone bushing in cap holds shock in place while allowing freedom of movement to prevent binding and prevents the shock cap from popping off
CHASSIS
• Wheelbase: 316mm~332mm (12.4”~13”)
• Width: 254mm (10”)
• Height: 156mm (6.125”)
• Weight: 1588g (3.5 lbs)
• Articulation: 70ฐ
• Ground Clearance: 68mm (2.7”)
ELECTRONICS
• Radio: 2 Channel
• Servos: 1 hi-torque metal gear (standard size)
• Forward/Reverse ESC
• Motor: 55T 540 Size
Click here for more info on the new RTC
BENDER is offline   Reply With Quote
Old 04-20-2009, 04:40 PM   #2
So where are the detail shots? Those lower links look like beef. Are they plastic? What about them new shocks? Plastic or aluminum?
2JSC is offline   Reply With Quote
Old 04-20-2009, 04:53 PM   #3
Hateraide
Code454's Avatar
they are plastic, but they have more meat on the sides of them to make them stiffer
Code454 is offline   Reply With Quote
Old 04-20-2009, 04:56 PM   #4
BENDER's Avatar
Quote:
Here's a link to the press release on Axial's website. I'll try and get some better detail shots up soon.
http://www.axialracing.com/ftp/ax90011_ax10_rtc.html
This new RTC kit offers beefier plastic lower links, beefed up plastic steering tie rods, a 55t motor instead of the RTR's 27t, and new 4" shocks. The shocks do have plastic bodies, but they are still one of the smoothest shocks I've ever tried. The shock shafts are 3.5mm instead of the standard 3mm stuff.
Old 04-20-2009, 04:58 PM   #5
Spec class
TEDROCKZ is offline   Reply With Quote
Old 04-20-2009, 05:20 PM   #6
Quote:
Originally Posted by TEDROCKZ View Post
Spec class
That would be pretty cool, I would about have to but one.
Hillcrawler is offline   Reply With Quote
Old 04-20-2009, 06:26 PM   #7
Location: You will never find a more wretched hive of scum and villainy
shock pics please, love to have my axial ...um all axial
any price on the truck yet?
DeweyCJ5 is offline   Reply With Quote
Old 04-20-2009, 06:33 PM   #8
I called Axial today
they told me the link are thicker plastic
and the shock are shorter and threaded plastic
it still all plastic
sally1800 is offline   Reply With Quote
Old 04-20-2009, 08:21 PM   #9
I'm running all plastic traxxas shocks now but if they are the same or better id change out...time will tell , i like the fact they are threaded
Old 04-20-2009, 11:09 PM   #10
when can we see them in the stores what store will be the first to have them
zach is offline   Reply With Quote
Old 04-21-2009, 06:38 AM   #11
Definitely a nice intro to crawling rig!
goldmember is offline   Reply With Quote
Old 04-21-2009, 08:19 AM   #12
Hmmmmm, something to help against the Losi coming out. Good idea Axial.
O.C.D. is offline   Reply With Quote
Old 04-21-2009, 09:32 AM   #13
i want the shocks.
where can i buy them shorties?
it'd be real compentitive w/ the losi if it had a dig.
BEELZEBOB is offline   Reply With Quote
Old 04-21-2009, 10:44 AM   #14
BENDER's Avatar
One thing I forgot to mention in my initial post is the new stronger driveshafts. We modified the molds to add more meat around the yokes, which made a huge difference. I've been running the new prototypes in the rear of my SCX10 with a 12t motor, and I've haven't had any issues with breaking or twisting them.
Old 04-21-2009, 11:32 AM   #15
Diggin' the new SCX10 II!
badger's Avatar
Matt did a live interview with me down at RCX this last weekend, he went into detail on the new RTC Crawler. The new crawler looks great with there improvements.
You can watch the live interview here:
http://www.rccrawler.com/rcx2009.html#Axial_RTC_Crawler
badger is offline   Reply With Quote
Old 04-21-2009, 11:41 AM   #16
Very nice intro rig. Wish there was something like that when I started out, would have saved a lot of money. Cannot see why plastic parts are such a bad thing in a starter vehicle, plus if it is as they say beefier than previous versions (shock shafts, drive shafts, links etc.) then they will probably hold out quite OK in the hands of anyone who just wishes to try his luck in crawling. Not everyone buys a truck with the intent of destroying it asap! As far as I am concerned I had great luck with stock AX10 plastic parts.
MadForce is offline   Reply With Quote
Old 04-21-2009, 06:13 PM   #17
We had this car at the NRHSA show last week. This car is awesome. All you need is a front battery tray and some weights and you're comp ready. Hobby store owners were drooling over it.
RobiUSA-James is offline   Reply With Quote
Old 04-21-2009, 06:40 PM   #18
Quote:
This is good info! I'm sure everyone can use more drive shaft options!
Old 04-21-2009, 07:05 PM   #19
Those shocks are nice. I saw some on Benders rig and they were nice and smooth and the shock shaft was BEEFY. He was pimping the aluminum versions but I can't imagine the plastic body version being too far off performance wise.
P1choco is offline   Reply With Quote
Old 04-21-2009, 11:08 PM   #20
Axial dose it agian.
Creepy Inc. is offline   Reply With Quote
You may not edit your posts
